March 12th, 2011, 11:13 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250R Posts: 49
Help Oil lights flickering
Hello, I'm new here. Been hanging around and finally registered . Hopefully one of you guys could help me out. I have a 09 Ninja 250r. Earlier today after I went out for a ride. I came back home and stopped at my driveway which is at a slight angle. I pressed my front brakes a little to hard and did a bit of a nose dive and saw oil lights flicker. Then I noticed when I would tilt the bike left and right the oil pressure/water temp lights would come on (replicated it 3+ times by tilting bike). Any idea what may be causing this?
Last futzed with by mrscbw; March 14th, 2011 at 10:41 AM. |
March 13th, 2011, 02:06 AM | #2 |
im a NinFo!....
Join Date: Jan 2011 Motorcycle(s): 00000000000000000 Posts: 19
does your bike have enough oil in it? might wanna check.
March 13th, 2011, 02:23 AM | #3 |
Yea oil is good about 1.7~1.9 but I did forget to put the washer on the oil filter..Could this be why?
March 13th, 2011, 02:37 AM | #4 |
im a NinFo!....
doubt it. the washer is just for keep the spring from digging into the rubber seal on the filter. you should still be fine without it. if your oil is ok, then it sounds to me like you have a loose connection somewhere, maybe in back of the dash, and the connections are sliding in and out of connection when you brake. ya know, momentum, force forward. i could be wrong. is it still under warranty?
March 13th, 2011, 02:42 AM | #5 |
I replicated it by tilting the bike left and right it would come on and off dimming as I stand up and brightening as I leaned it further. Any ideas where to check?
March 13th, 2011, 03:05 AM | #6 |
im a NinFo!....
ya got me. only thing i would know to say is to start at the battery and check all the connections down the line. it may not even be a loose connection, it was just a thought. hows the battery? if it brightens when you lean it, maybe the battery is slightly damaged, and is connecting better when the fluid is moving or sloshing. i really dont know other than that without seeing it.
March 13th, 2011, 03:11 AM | #7 |
Hmm..its possible for a bad battery connection to cause the oil lights to light up? I'll check the connections tomorrow morning.
March 13th, 2011, 04:06 AM | #8 |
recheck your oil level in the sight glass window. is it at the proper level with the bike perpendicular (fully upright) to the ground?
also, what oil weight are you using? |
March 13th, 2011, 04:12 AM | #9 |
The oil glass is about 90% to the full line with the bike upright also 10W40. I'm really thinking this is a wiring problem since tilting the bike makes both the lights flicker? From what I understand the light should either be ON or OFF there is no in between? Since its dimming and flickering I'm guessing the contacts are moving or something. I done some researching and found this diagram: http://i50.tinypic.com/j78cia.png which shows that the 2 lights share the same circuit? Where can I find these connectors?
March 13th, 2011, 04:44 AM | #10 |
Go Pack Go!
Join Date: Feb 2011 Motorcycle(s): 09 250R, 07 XL1200L Posts: 39
the service manual has the following troubleshooting guide.
Oil Pressure Warning Light Goes On:
i hope this helps.
09 Ninja 250R (commuter) 07 XL1200L (weekend fun) 02 SV650S (totaled by an idiot cager) & others |
March 13th, 2011, 07:46 AM | #11 |
Also check your idle speed. Too low idle speed can result in low oil pressure. How long was your ride and how hot was your bike? Has it done the same thing cold? The oil pressure switch diode and temp switch diode is located on the wiring harness on the left side behind the upper cowling.
March 13th, 2011, 02:00 PM | #12 |
Hmm.. I just went out to try and replicate it again and it didn't turn on. When it did happen, it was after a 2 hour ride about 1.5 hr in the back roads and .5 on the freeway home going about 70~80 mph which is about 8-10k rpm? After the freeway coming to a stop i notice it flickered but didn't think anything of it. Then when I stopped in my driveway I seen it again, so I showed my friend. I stood the bike upright and it would go away, tilt left or tilt right, light flashes on. Bike has 500 Miles, 2009. Recent changes to bike: Swapped to 2011 exhaust, Pulled Carb to clean jets, 2 #4 washer shims, and adjust fuel/air mixture screw. Any ideas?? I increased my idle a bit, its at about 1500 BTW
March 13th, 2011, 02:10 PM | #13 | |
Link to original page on YouTube. |
March 13th, 2011, 02:12 PM | #14 |
Brakes revving the motor..haha how ironic
March 14th, 2011, 09:38 AM | #15 |
Is it common for the oil pressure and water temp lights to come on at the same time?
March 14th, 2011, 10:09 AM | #16 |
March 14th, 2011, 10:52 AM | #17 |
Feel free to click on the edit and compare revisions..Only changed one thing and thats..oil temp to water temp
March 14th, 2011, 11:00 AM | #18 | ||
ModMy250.com
As far as your lights are concerned, if they didn't flicker on while the engine was cold, I would suggest changing your fluids.
The www.ModMy250.com guy |
March 14th, 2011, 11:07 AM | #19 | |
What really gets me was tilting the bike made the lights come on. Not just the oil pressure but water temp light at the same time. And they would dim/flicker as well. |
March 14th, 2011, 11:14 AM | #20 |
March 14th, 2011, 11:20 AM | #21 |
Barry,
I've deleted my offensive posts. I suggest you (and others) go back and do the same. You need to understand this forum is a bit different than others and the members here deal with each other on a more personal level. We value and appreciate the great atmosphere Alex has provided us with and I do my part to keep it that way. Stick around and I'm sure you'll learn a lot about your bike. Like I suggested in my PM, check for a loose/corroded ground or a chafed wire where those two lights share a common circuit. I may be completely wrong and I'm sure if I am, someone will tell me so and provide you with the answer to your problem. That's the way it is around here. welcome to the forum. |
March 14th, 2011, 11:23 AM | #22 |
Hey Kelly, No hard feelings man. You got way more knowledge than me and I'm here to learn from you. No offense to you bro seriuosly.
Just fix this light for me lol |
March 14th, 2011, 11:27 AM | #23 | |
Now lets start fresh with this light issue... Welcome aboard Barry!
March 14th, 2011, 11:40 AM | #24 | |
you need to start digging around/examining the cluster area to check out the wiring, if it's both of those lights flickering together. the fact that you can affect it by moving the bike side to side indicates to me that something might be loose causing an intermittent short or ground. |
March 14th, 2011, 11:44 AM | #25 |
Okay let me try to explain this to the best that I can. First of all these are some things that I done which may or may not affect it. Pulled carb, removed battery tray and majority of the connectors around it. Shimmed needles with 2 #4 washers each. Replaced exhaust with 2011 OEM exhaust. Adjusted Air/fuel mixture screw to 2 turns out. Oil changed 1.7~qts 10W40 (forgot to put the big washer back on, going to put it back on next oil change).
Onto the scenario: 2 Hour ride, 1.5 hr in the backroads, .5 hr on the freeway going about 70~80 mph. When exiting the freeway coming to a stoplight is when I first noticed the oil pressure/water temp light flicker. Coming to the driveway which is sort of a dip before going up to the garage. I stopped at the driveway dip with bike angling down. Tilt the bike left or right and those 2 lights would come on at the same time and at the same brightness. The more I leaned the bike the more brighter the light would get until it reaches a full ON light and would stay on if I held the bike in that angle. When lifting bike back to upright light disappears but as I lift it back up the light would dim/flicker. Oil glass is about l---------l--l when standing upright more towards the full side. I tried to replicate this with a few rides around the block and it did not happen. So I'm worried its not electrical and may be mechanical =[ Would the air/fuel mixture have a possibility of causing the bike to overheat when coming to a idle? (say if I adjusted it to lean) Or maybe one of the connectors is loose? I pulled majority of the connectors near the battery tray don't know if any of those reflects those warning lights. If you guys need more details, I can try to provide it. |
March 14th, 2011, 11:50 AM | #26 |
Alright going to check the wires again..so because both of these lights are coming on at the same time. I'm safe to say this is most likely electrical?
March 14th, 2011, 11:51 AM | #27 | |||
Lower your idle back down to 1300-1350 (since you have shims). Try changing your sprocket sizes to help reduce your rpms. You can also run 20w-50 oil as well. (will help in cooling) |
March 14th, 2011, 11:55 AM | #28 |
first.. are you sure both lights are coming on and just not one light coming on and perhaps its light bleeding over into the other indicator?
the oil flickering light problem has been reported before and the cause seemed to have been too low an oil level when the oil bunches up towards the front of the engine during hard stops or on inclines. how are you getting your oil level indication in the sight glass? is the bike perfectly perpendicular to the ground when reading? It can't be just "approximately" perpendicular, as I've seen a very small amount of lean affecting the sight glass reading significantly. I'm just trying to make sure you're getting an accurate oil level indication. also, when you reassembled the bike after shimming, are you sure you got any chassis ground wires you may have removed back into place and are providing a good, solid connection to ground? |
March 14th, 2011, 12:03 PM | #29 | |
March 14th, 2011, 12:10 PM | #30 | |
March 14th, 2011, 12:16 PM | #31 | |
Barry: Is there any other mods done. Maybe LED turn signals or any other changes to the electrical system/wiring? Is the bike new or new to you?
March 14th, 2011, 12:17 PM | #32 | |
March 14th, 2011, 12:21 PM | #33 |
kkim:
Is there any harm in intensionally grounding one of the switches to see if both lights illuminate again?
March 14th, 2011, 12:23 PM | #34 |
I just purchased this bike about 2 weeks ago with 250 miles. There was no mods done to the bike everything looked completely stock. The bolts on the fairings looks like they have never been touched. So I was the only person to take this thing apart. I haven't done any mods except the ones listed. Is there any grounds being removed in the process of removing the carburetor/airbox ? or any wires I may have altered in this process that may cause this problem? This was my first attempt and I kind of just went at it with a laptop and KKim/Vex DIY's.
March 14th, 2011, 12:27 PM | #35 |
March 14th, 2011, 12:30 PM | #36 |
sorry... dunno for sure, but I would think not... as long as the switch is indeed using a chassis ground (which I'm pretty sure all electrical does on this bike).
March 14th, 2011, 12:36 PM | #37 |
I really doubt that a bike with 250 miles on it has a major electrical problem. The lights flickered and did not stay on. You put any 250 Ninja on a steep angle to the front with the engine hot and the oil pressure light will flicker. Not only that a temp loss in oil flow may cause to temp light to flicker as well. Just my 2 cents.
http://faq.ninja250.org/wiki/My_oil_..._heavy_braking |
March 14th, 2011, 12:47 PM | #38 |
March 14th, 2011, 12:51 PM | #39 | |
Barry: Can you replicate the lights by leaning it side to side?
March 14th, 2011, 01:06 PM | #40 |
Ya when I first came back to the drive way, I replicated it 3+ times by leaning it left and right. My friend witnessed it and said "thats crazy". So the next day I took it around the block a few times and came back to the same spot, same angle and tried to lean it again left and right..no light. bummmmer
Dash lights flickering no starter ?!?! | jamasda | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 6th, 2014 08:06 PM |
Dash lights/ front headlights flickering? | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 17 | February 27th, 2012 08:42 AM |
2007 won't start, not even getting neutral or oil warning lights! | davidfriend | 1986 - 2007 Ninja 250R Tech Talk | 13 | May 6th, 2011 09:51 PM |
Flickering headlight and stuck blinkers | dyeforever | 2008 - 2012 Ninja 250R Tech Talk | 20 | December 22nd, 2010 02:50 AM |
Flickering HIDs | The_beanz | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 1st, 2010 03:17 PM |
