Old March 18th, 2011, 07:06 AM   #1
Jaysep
Pinoy
Motorcycle(s): Ninja 250r, KMX, mio soul
Gasoline question
Hi, what is the best gasoline to use for our 250r? Currently, am using 100 octane rating gasoline. I figured it has a better burn but am worried about the diaphram. Will that high octane level ruin my diaphram faster? Your expert thoughts please. Thanks!
Jaysep is offline   Reply With Quote
Old March 18th, 2011, 07:11 AM   #2
Bueller999
Oldie but a goodie
Bueller999's Avatar
Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC
Run the lowest octane possible without the engine pinging, octane does not = power.
At my altitude (5000'+) there is no reason to run anything higher than regular 85.
Search the web and get the facts.
ABRacing
Bueller999 is offline   Reply With Quote
Old March 18th, 2011, 07:23 AM   #3
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
Lower octane gas has a higher energy density. You should be using the minimum octane that you need to prevent pinging, which would be 85-87 octane. Using higher octane than that and you're just throwing your money away.
warlord is offline   Reply With Quote
Old March 18th, 2011, 07:30 AM   #4
Jojah17
Jojah17's Avatar
Motorcycle(s): 2008 Honja
Hard to avoid a soapbox with this question but I find it ironic that oil companies charge excessive amounts of money for a product that is less efficient and more harmful than it was 20 yrs ago (I was 6 20 years ago so I totally know what Im talking about). Thanks for all the Ethanol! *Steps down from soapbox*
Jojah17 is offline   Reply With Quote
Old March 18th, 2011, 08:05 AM   #5
dubojr1
dubojr1's Avatar
http://www.ninjette.org/forums/showt...ght=gas+octane
Old March 18th, 2011, 09:30 AM   #6
SSR
Motorcycle(s): 2009 Ninja 250
Use what your user guide says. I don't know if it changes in different parts of the world, but mine says to use 87.
Remember, when manufactures create an engine, they create it from the start to run on a certain Octane level. Putting a higher level of Octane in probably won't do much simply because the engine wasn't designed to combust at that level. Wasted potential.
Higher octane ratings correlate to higher activation energies. Activation energy is the amount of energy necessary to start a chemical reaction. Since higher octane fuels have higher activation energies, it is less likely that a given compression will cause autoignition.
It might seem odd that fuels with higher octane ratings are used in more powerful engines, since such fuels ignite less easily. However, an uncontrolled ignition is not desired in a spark ignition engine.
A fuel with a higher octane rating can be run at a higher compression ratio without causing detonation. Compression is directly related to power and to thermodynamic efficiency (see engine tuning), so engines that require higher octane usually deliver more motive power and do more work for a given BTU or calorie of fuel. Engine power is a function of the fuel, as well as the engine design, and is related to octane rating of the fuel. Power is limited by the maximum amount of fuel-air mixture that can be forced into the combustion chamber. When the throttle is partially open, only a small fraction of the total available power is produced because the manifold is operating at pressures far below atmospheric. In this case, the octane requirement is far lower than when the throttle is opened fully and the manifold pressure increases to atmospheric pressure, or higher in the case of supercharged or turbocharged engines.
Many high-performance engines are designed to operate with a high maximum compression, and thus demand high-octane premium gasoline. A common misconception is that power output or fuel mileage can be improved by burning higher octane fuel than specified by the engine manufacturer. The power output of an engine depends in part on the energy density of its fuel, but similar fuels with different octane ratings have similar density. Because switching to a higher octane fuel does not add more hydrocarbon content or oxygen, the engine cannot produce more power.
http://en.wikipedia.org/wiki/Octane_rating
From here...to everywhere!
SSR is offline   Reply With Quote
Gasoline in the exhaust 2012NewRider 2008 - 2012 Ninja 250R Tech Talk 5 March 9th, 2013 12:54 PM
exhaust smells of gasoline eddiekay General Motorcycling Discussion 13 August 21st, 2012 04:13 PM
Gasoline in the Air Box?? Buffalony 2008 - 2012 Ninja 250R Tech Talk 3 November 20th, 2010 05:40 PM
what kind of gasoline do y'all use? poo poo 2008 - 2012 Ninja 250R Tech Talk 9 January 11th, 2010 08:57 AM
Gasoline types CrzyFstMnM 2008 - 2012 Ninja 250R Tech Talk 24 April 3rd, 2009 07:36 AM
