Old March 19th, 2011, 03:08 PM   #1
NicoleH28
NicoleH28's Avatar
Motorcycle(s): 2011 Ninja 250r Special Edition White & 2006 Suzuki GSXR 600
Speed/RPM
I am wondering if this seems right. I have a 2011 250R and when I am in 6th gear traveling at 40mph is it right for the bike to be at about 6RMP's? It seems high to me. I obviously know that I can't shift again. When I get to highway speeds of 55+ I'm assuming I'll be running at 8 or 9RPM's...is this normal? Do these bikes run high like that? I'm new to this so I just want to make sure....
NicoleH28 is offline   Reply With Quote
Old March 19th, 2011, 03:14 PM   #2
Boosted139
Motorcycle(s): 2009 Ninja 250R SE, 2009 Triumph Daytona 675
In 6th gear @7500 rpms im at ~60mph indicated on the speedo. I'm sure everyone will chime in and attest that you will be that high, I mean the bike gets fun at 8000+ rpms.
Boosted139 is offline   Reply With Quote
Old March 19th, 2011, 03:26 PM   #3
Cuongism
Cuongism's Avatar
Yea, it's a small engine so rpms will definitely be high (redline is over 13k). If you're going freeway/highway, chances are you'll be 10-11k. Most of the power kicks in above 9k as well.
Old March 19th, 2011, 03:27 PM   #4
the 250 loves revving and what you are seeing is perfectly normal. get used to it and enjoy it. zoom...
Old March 19th, 2011, 03:53 PM   #5
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I only run at red-line!
Not really but doesn't it sound cool.
Old March 19th, 2011, 04:27 PM   #6
mj23retired
Motorcycle(s): green 2010 ninja 250r
am I the only one who is never going 40 in 6th gear?
mj23retired is offline   Reply With Quote
Old March 19th, 2011, 04:36 PM   #7
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Hi, Nicole! Welcome to ninjette.org. These bikes aren't happy until 6k RPMs, and riders most don't even shift until 7-8k for casual riding, 8-9k in twisties. Not at all uncommon to get up to 10 or 11k, as that is where you get the peak horsepower. Just don't do that during the break in period. Here is the Ninjette's power curve, with the red line being the stock pipes:
If you want to have some fun, check out the Ninja Speed Calculator. Here is another Ninja Speed Calculator. According to the calculators (though built for old gen, it should be close), you should be at 7100 RPMs in 6th when your speedo indicates 60mph. At 6000 RPMs in 6th, you should be going 50. You may notice that the calculator shows "real" vs. "indicated" speed. Yup, your ninjetted exaggerates how fast you are going by about 8%.
Old March 19th, 2011, 04:48 PM   #8
DaBlue1
DaBlue1's Avatar
Originally Posted by NicoleH28 View Post
...I am wondering if this seems right. I have a 2011 250R and when I am in 6th gear traveling at 40mph is it right for the bike to be at about 6RMP's? It seems high to me. I obviously know that I can't shift again. When I get to highway speeds of 55+ I'm assuming I'll be running at 8 or 9RPM's...is this normal? Do these bikes run high like that? I'm new to this so I just want to make sure....
If your bike is stock, your gearing should be 14/45 (14 tooth front sprocket / 45 tooth rear sprocket). @ 5000 rpm you should be doing approx 40 mph in 6th gear, because the speedo reads a little high it my read an indicated 45 mph +/- 1-2 mph.
So to answer your question 6k rpm for 40 mph in 6th gear is high. However 40 mph @6k rpm in 5th gear is more in the ball park.
The 250 ninja is a high revving lil beast it will do well at hwy speeds in the 8k range, but if you grow tired of the high speed buzz, a sprocket change is probably in order. I suggest a 15/42 or 15/41 gear set up. This will make the bike run at lower rpms, slightly improve mpg, make the bike ride longer in any given gear, and takes advantage of the available HP the bike has without always riding WOT.
Doing the sprocket change (15/42) will make the speedo read 70 mph @ 7k rpms. Your actual speed will be 65.2 mph.
Stock gearing the speedo would be 69/70mph( indicated) @ 8k rpm. Actual 65 mph.
You can use this calculator to check any sprocket combos. For rear wheel size check other then put in 75.92 in the circumference box. Type in sprocket size, rpm and gear. http://ninja250.kingston.net/speed.html
If you feel the bike is still running high for an indicated gear speed. Have the dealer check it. it could be a faulty IC igniter. They will be able to check what the actual rpm output is against what the tachometer is reading.
Last futzed with by DaBlue1; March 19th, 2011 at 07:26 PM.
Old March 19th, 2011, 05:12 PM   #9
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
this bike loves 80mph@ 11k rpm and can stay there all day, it loves you back for it. it's actually just cruising there, no matter what sound is, (so many pipe systems).
coondog is offline   Reply With Quote
Old March 19th, 2011, 05:52 PM   #10
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
In 6th for me my Tach is 1500rps over speed. So 60 puts me at 7500 or so. What is your idle speed set at?
Havok is offline   Reply With Quote
Old March 19th, 2011, 07:51 PM   #11
Sixringz
Sixringz's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
I just started riding and I am always cruising between 6-7 grand. Is that too high to be cruising at? Anything above 7 sounds too high. I understand people say they shift at high rpms, but what about cruising?
Sixringz is offline   Reply With Quote
Old March 19th, 2011, 07:59 PM   #12
DaBlue1
DaBlue1's Avatar
I have a 15/42 setup and I cruise in that range alot. For me that is 55-65 mph. it is like the comfort zone on my bike. On a real good day around 9k feels real sweet as well. if you look at your tach, your bike is only at 1/2 its max capability.
Old March 19th, 2011, 08:52 PM   #13
Havok
Internet Slut
Havok's Avatar
I run from 7k up. When I take off in first I take it up to 10-11 befor I shift and hardly ever drop under 7 k unless I am stoping lol. Our bikes are ment to run that high and in that rpm range. Have trust and faith in that little parallel twin it loves to rev high and scream. The engine can take it just have to get use to it is all.
Old March 19th, 2011, 09:00 PM   #14
setasai
setasai's Avatar
It may sound high but like some of the other posters say, power doesnt kick in till 8-11k so if you need that extra boost, it's nice to be somewhere near that range. If you cruise at 4-6k and you need that extra power to go around someone or get out of a dangerous situation, you will need to spend that extra second to downshift a couple times even to get to use the peak power of the engine.
Just ride and try to get used to the bike. Every bike is different, like a person that you live with. Takes a little while to get used to their schedule and adjust so that the both of you get along.
Old March 19th, 2011, 09:49 PM   #15
NicoleH28
NicoleH28's Avatar
Thanks everyone for the info! Looks like Monday is the next time Ill have it out. Only gonna be 40 tomorrow with rain! Monday it'll be a whopping 50 lol
Posted via Mobile Device
Old March 31st, 2011, 02:47 AM   #16
Hitman
Hitman's Avatar
Motorcycle(s): 2010 Ninja 250r Special Edition (Red/Black) / 2008 Suzuki GSXR 600 (Silver/White) / Ducati Diavel Carbon Red
I have mine set at 15/41 gearing and just as DaBlue1 said it is roughly 1K RPM to 10MPH.
At 70MPH I run 7K RPM on my gauges or fairly close to that but I have alot of power left to go as fast as I need.
Took it to 100MPH already and it was just starting to stretch its legs running at 10K RPM. However the flip side is that you will be a little slower taking off from a stop. I am fairly light so my bike does not struggle taking off.
Saves me alot on gas too.
2010 Ninja 250r Special Edition Blk/Red, Pazzo controls, Lowering kit, Roaring Boyz Toyz risers, Corbin seat, Shogun frame sliders, Yoshimura Full Exhaust 2008 Suzuki GSXR 600 Silver/White
Hitman is offline   Reply With Quote
Old April 4th, 2011, 08:23 AM   #17
mj23retired
This 15/41 gearing set-up I hear about...is there a DIY for this?
Old April 27th, 2011, 01:02 PM   #18
Pyro
Motorcycle(s): EX-250K
Ours got 43/14 on the front sprocket... Maybe they changed the gearing slightly on the fuel injected model.
Mine has a slightly smaller diameter tyre (150-60-17), but I should get:
Code:
Gear	RPM@60	RPM@80	RPM@100	RPM@120
1	12826	17101	21376	25652
2	8827	11770	14712	17655
3	6951	9268	11585	13902
4	5722	7630	9537	11445
5	4933	6577	8222	9866
6	4404	5873	7341	8809
mph	37.5	50	63	75
Torque is pretty good from 6000, so I've been trying to stay above that.
Last futzed with by Pyro; April 27th, 2011 at 02:47 PM.
Pyro is offline   Reply With Quote
Old April 27th, 2011, 01:10 PM   #19
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
sigh......
15/45 here - 85mph (indicated) at 9k rpm all freaking day......
like others have said, this is where our bikes are MOST happy.
ride it like you stole it............and enjoy
want1sobad is offline   Reply With Quote
Old April 28th, 2011, 03:25 PM   #20
Hitman
Hitman's Avatar
I didn't do it. I ordered the parts and had the motorcycle shop install it.
Old April 29th, 2011, 08:26 AM   #21
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
no notice in powerband change until 7k or higher, Nicole give a ride report after you have had some fun red lining. Did you feel you had better response/throttle control like I do in high revs? The throttle is your most important riding control play with the diff rpm's in the same gear and you will see.
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods
Cali619 is offline   Reply With Quote
Old March 6th, 2013, 04:41 PM   #22
LNasty
Daily Jap rider
LNasty's Avatar
Angry So f***ing annoyed right now!
So I have been to 2 dealers that say my rpm/speed range is normal, the hell it is!! At 60mph the tach is showing 8900k....WTF do I do! Call Kawasaki? Dealer just told me to change to a 15t sprocket if I don't like it. Well if I do that (just to get the RPM's to normal range) I als have to buy new chain and new rear sprocket to make the wear even. Anyone else riding at these rpm's on their 2012 250r? or am I the only one?
Old March 6th, 2013, 04:44 PM   #23
Joshorilla
Bass Master General
Joshorilla's Avatar
I know the ninja 250r has different teeth count on the rear sprocket depending on regions, so this may play a factor for some people.
Old March 6th, 2013, 04:46 PM   #24
LNasty
Daily Jap rider
LNasty's Avatar
I am stock 14/45
Old March 6th, 2013, 04:51 PM   #25
LNasty
Daily Jap rider
LNasty's Avatar
Plus when it is cold out or i am just starting out my ride the rpm's are about 100ok lower than what i normally see (Prob right where they should be) asked the dealer about the cdi, he said that they haven't seen that issue with the 2012's. Well ****...how about checking it a-hole. The won't even check the things that i feel are wrong with it. I even have the extended warranty, I know they dont get paid for warranty work, but this sucks if I have to play through hoops with Kawasaki just to get one of their dealers to play fairly. I depend on this bike to get to work everyday, can't afford for something to be wrong with it, especially when it is brand new. harumph
Old March 6th, 2013, 04:53 PM   #26
xaple
xaple's Avatar
At 50MPH -80MPH I'm usually at an RPm = 100x my speed. after 80MPH its about 1.5-2x my speed ascending according to speed.
Just for reference.
xaple is offline   Reply With Quote
Old March 6th, 2013, 05:03 PM   #27
LNasty
Daily Jap rider
LNasty's Avatar
Just for reference.
So at 60mph your only at 6000 rpm's? how is that possible?
Old March 6th, 2013, 05:39 PM   #28
DaBlue1
DaBlue1's Avatar
You still having problems convincing a dealer that your readings are off?
What you need to do is call, write or e-mail Kawasaki Consumer Services. Tell them you have an extended warranty on a 2012 Kawasaki Ninja 250 that has a faulty tachometer and no dealer will fix it or trouble shoot it. Demand that they remedy the situation by contacting a local dealer that will. You need to take them proof the tach is faulty. Inquire of Kawasaki what the exact RPM reading should be for 60 mph. And see what they say. Some one has to answer you.
Mailing Address:
Attn: Consumer Services
Kawasaki Motors Corp., U.S.A.
PO Box 25252
Santa Ana, CA 92799-5252
Our Consumer Services Department is also available at (866) 802-9381. Our hours are Monday-Friday 8:00-5:00 Pacific Time.
http://www.kawasaki.com/OurCompany/ContactUs.aspx
15/41 or 15/42 sprockets will get you to run approx 60 mph(indicated) @ 6000 rpms
Use Gearing Commander to find various information on gearing for your bike.
Old March 6th, 2013, 07:37 PM   #29
LNasty
Daily Jap rider
LNasty's Avatar
Thank you blue, I will be contacting them asap.
Old March 8th, 2013, 05:51 PM   #30
xaple
xaple's Avatar
sorry i meant to type 100x + 1000 so like 50 mph is 6k 60mph is 7k
Old March 8th, 2013, 07:25 PM   #31
LNasty
Daily Jap rider
LNasty's Avatar
Still that is low, what gearing are you using? Am I the only one on here that is at 9k rpm@ 60mph?
Old March 8th, 2013, 07:35 PM   #32
xaple
xaple's Avatar
9k seems high, i have stock gearing but i know nothing about whats high or low, i thought my 10k at 80 was high. Maybe is your speedo really off? Drive next to a 07+ civic and look through the window lol to check your speed, or get a GPS
Old March 8th, 2013, 07:35 PM   #33
..........Am I the only one on here that is at 9k rpm@ 60mph?
I don't know if you are the only one.
I know that your clutch is slipping.
Are you sure that the clutch cable is lubricated and has some slack?
Old March 8th, 2013, 08:01 PM   #34
LNasty
Daily Jap rider
LNasty's Avatar
Dealer said clutch is good when I took it in
Old March 8th, 2013, 08:06 PM   #35
LNasty
Daily Jap rider
LNasty's Avatar
Dealer said clutch is good when I took it in. The rpm isn't bouncing around, like its slipping, just high for the speed I am going
Old March 8th, 2013, 08:18 PM   #36
If your tachometer and speedometer are working properly, the dealer was wrong.
At 9K rpm, your bike should be doing 70~75 mph.
From the pistons to the rear wheel, the link is solid as a rock, except for the clutch, where some slip can occur for several reasons.
The most common reason is improper adjustment, which keep some pressure on the pusher bar and don't allow the discs to press to each other all the way.
Other reasons are bad oil, weak springs and warped discs.
You need to verify that the clutch cable is not putting any pressure on the lever by the clutch cover after the hand lever is released.
Old March 8th, 2013, 08:27 PM   #37
LNasty
Daily Jap rider
LNasty's Avatar
Damn I am a newb with this ****. I .mp3 that I have the right amount of play in my clutchlever, are you talking about the adjustment down by the actual clutch on the engine?
Old March 8th, 2013, 08:35 PM   #38
The regulation by the hand lever should be sufficient to get the proper play.
I was referring to the lever that enters the clutch cover.
That lever should have some play when the cable is not pulled up by hand.
Sometimes the play at the hand lever is correct, but the cable needs lubrication and does not release that bottom lever completely.
Please, check these links out:
http://faq.ninja250.org/wiki/Lubing_the_cables
http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
Old March 8th, 2013, 08:44 PM   #39
LNasty
Daily Jap rider
LNasty's Avatar
Thanks moto, hopefully it just needs adjustment. I don't do wheelies our anything crazy so the clutch itself should be fine. Have 3000 miles on bike.
Old March 8th, 2013, 08:56 PM   #40
Your are welcome
Yes, please, check the play and lube the cable and report back to see if that solves the rpm's issue.
Best !
Best RPM range at speed... robski11500 Riding Skills 9 December 11th, 2015 11:44 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Highway speed in relation to rpm.. Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 3 August 5th, 2013 04:10 PM
RPM-Speed ratio; Update. blink General Motorcycling Discussion 19 January 29th, 2013 05:48 PM
