Old April 10th, 2011, 11:20 AM   #1
red
Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3
remove and reinstall carbs - stock airbox
Soo how far back do you need to get the stock airbox to get the carbs out?
I assume the carbs need to go out the left side once they have been just slightly popped out of the inlets and intake rubbers? There is no more room to gain?
Any tips on these little bits that seems to be absent from the vids (vids without the stock airbox) would be appreciated. I have the airbox loosened and just barely out of the carb intakes. Seems like a terribly tight spot.
red is offline   Reply With Quote
Old April 10th, 2011, 11:25 AM   #2
http://www.kawiforums.com/ninja-250r...ll-re-jet.html
http://www.ninjette.org/forums/showthread.php?t=69403&
Old April 10th, 2011, 11:38 AM   #3
red
read those. Still a pain but thanks.
I will try adouglas tip about pulling the left inlet rubber completely out, that may help.
Old April 10th, 2011, 12:24 PM   #4
use some muscle... it will come out.
Old April 10th, 2011, 01:05 PM   #5
red
The carbs are out. Unless I did something incorrect, the airbox inlets never truly clear the carbs, or the inlet rubbers on the engine side. Sort of a jam fit and extraction.
I found nothing amiss in the carbs, they were clean inside and the pilots were clear. Floats lined up with each other and all vac and connections were tight.
So I reset the mixture screws to 2 3/4 and put a couple #4 shims under each needle and will proceed to re-assemble the puzzle.
Anyone having any other tips for reassembly would be appreciated.
(I see only FI bikes in my future...)
Old April 10th, 2011, 01:07 PM   #6
that depends... what was wrong with your bike?
Old April 10th, 2011, 01:12 PM   #7
red
The main issue is it seems terrible cold blooded and strangled down low. Take 10 minutes to idle well, or even run well without full choke. Takes 10-20 seconds to slowly return to idle. Almost unrideable for a new rider.
Old April 10th, 2011, 01:18 PM   #8
what year is your bike and has it been sitting for a prolonged period of time without being used?
Old April 10th, 2011, 02:30 PM   #9
red
It may turn out to be a binding/misadjusted throttle close cable not completely seated in its yoke. It seemed to be too loose and catching a bit.
The carbs look great - the bike is a used '10 with no miles on it to speak of. Had plenty of stabil in over the winter, but still got run anyway. The carbs and pilots were squeeky clean.
In process of getting it put back together and adjusting everything and will probably mount the tank and seat and see if there is any improvement.
Old April 10th, 2011, 02:32 PM   #10
where exactly are you looking at? the throttle or carb end of the cables?
Old April 10th, 2011, 02:40 PM   #11
red
After pulling the carbs and going over them, when reinstalling everything it looks to me like the return/idle cable was not adjusted properly. It appears to have had enough slack to hang the barrel kittywampus (technical term) in the yoke on the carb end where the cable barrel would bind.
I have adjusted the slack out to where the idle cable has some slack but won't bind.
Of course I have not run it yet so I reserve the right to change my mind, or be schooled the the error of my thinking.
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade.
Old April 10th, 2011, 02:47 PM   #12
So, I'm assuming you're talking about this do-hickey that the throttle cables hook up to??
Old April 10th, 2011, 03:00 PM   #13
red
Yes, the idle/return cable side. Not the pull/open cable.
The metal barrel on the end of the idle cable would bind/catch in the yoke slot and would not sit squarely because it was too loose.
Last futzed with by red; April 10th, 2011 at 04:23 PM.
Old April 10th, 2011, 03:17 PM   #14
red
Happy day. The bike is running perfectly now, none of the problems it had before. Thanks Kim for the help and watchful eye.
I put a couple of #4 washers under each needle so I am going to take it for a spin and see what that does.
Old April 10th, 2011, 03:21 PM   #15
Old April 10th, 2011, 03:39 PM   #16
red
All in all its a night & day transformation, especially down low. I had swapped front sprockets last year for a little more leg, but with a lousy throttle and off idle personality, it only made it worse. All the reviews I have read on these never complained that they were problems like this so it had to have been something misconfigured like that binding cable.
I think this must have been why the PO sold it as it was a crappy runner below 4k the day I picked it up. It must have been that way from the factory since I can see no evidence it was ever serviced (had 400 miles) and all the paint marks on the bolts weren't broken.
Runs like a dream now. Does not need much choke for long. Off to put the plastics back on.
Old May 25th, 2011, 07:50 PM   #17
2fiddy
2fiddy's Avatar
Motorcycle(s): 2010 Red Ninja 250r
Should i bring it back to the shop that did my 600 mile service? To my understanding this should have been checked and adjusted.
2fiddy is offline   Reply With Quote
Old May 25th, 2011, 07:55 PM   #18
what specifically are you referring to?
Old July 16th, 2013, 06:14 PM   #19
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
Getting the same issue and just wanted to confirm this was just how it was.
The service manual states to pull back the air box but it barely moves, is that incorrect as well?
Any pointer for getting the suckers back in, should they go into the engine side then slip to air box or vice versa etc?
Runeknight95 is offline   Reply With Quote
Old July 16th, 2013, 06:38 PM   #20
sLick415
The airbox is held in place by 2 bolts (top right towards the rear, bottom left towards the front). You should be able to move it back at least an inch after removing the battery.
These are my steps to removing the carbs:
1. Remove battery and its holder.
2. Remove both bolts holding down the airbox.
3. Loosen all clamps on the engine boots.
4. Pull airbox back as far as you can so carbs clear the boots.
5. Remove engine boots.
6. Loosen airbox boots.
7. Slide carbs forward to clear boots.
8. Slide carbs through the left side. (Bracket for idle adjuster must be removed)
Putting them back in is exactly in reverse.
sLick415 is offline   Reply With Quote
Old July 16th, 2013, 06:44 PM   #21
Runeknight95
I did all that except 5. Did you find it easier to remove the engine boots, how did you do that while the carbs were still on there?.
and yea I just wanted to confirm that the air-box barely moves after i took out it's bolts.
Do you put the boots back on the carbs first then insert into the engine or put the boots on the engine and try to wiggle the carbs in?
THANKS so much man lol
Old July 16th, 2013, 06:55 PM   #22
sLick415
I did all that except 5. Did you find it easier to remove the engine boots, how did you do that while the carbs were still on there?. Only way that I found was to remove those boots. If you pull the airbox back with the carbs still attached to it, you should have enough room to remove them.
Do you put the boots back on the carbs first then insert into the engine or put the boots on the engine and try to wiggle the carbs in? Carbs go back in, attached to airbox, then engine boots. Like I said, exactly in reverse.
Old July 16th, 2013, 07:09 PM   #23
Runeknight95
Thanks a ton
How to remove the carbs cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 1 July 1st, 2014 07:10 PM
Another way to remove the carbs.... Soujyu 2008 - 2012 Ninja 250R Tech Talk 6 August 26th, 2013 12:36 PM
How do I get the carbs off of the stock airbox? Ben M 2008 - 2012 Ninja 250R Tech Talk 11 September 28th, 2012 11:21 PM
Trying to remove the airbox.... jboyd12 2008 - 2012 Ninja 250R Tech Talk 9 April 5th, 2012 11:29 PM
FI Bike Remove Airbox or performance air filter menno 2008 - 2012 Ninja 250R Tech Talk 3 October 5th, 2010 02:01 PM
