#1 |
Not dead yet!
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250R Posts: 315
Emergency Shifter Holder Onner Bolt Thingy Replacement DIY
On a nice, leisurely ride about 50 miles from home, I pull off the highway and start shifting down for the red light, but something isn't right. The normal satisfying 'clunk' that accompanies each gear change is conspicuously absent. I look down, and my shifter is flopping around. Oh crap. I think I'm in fifth, and as the light turns green, I gun the engine, make like the Moto GP guys, pushing off with my feet, and slowwwly let the clutch out. It's not pretty, but I manage to limp my bike to a parking lot to inspect the damage. I see... this.
![]() I punch 'hardware store' into my phone and come up with a Lowe's less than a mile away. I limp my poor bike to Lowe's, and after a couple of trips to the metric bolts bin, I come up with this: ![]() It was ugly, but after wrenching the shifter back and forth several times, I was (relatively) confident it would get me back home, which it did. Anyway, if this happens to you, you can use a 7x40mm bolt and a bunch of 7mm washers to hold that thing on while you get your butt home. Not sure if 7mm is really the "right" size, but it seemed to go in there without feeling like I was rethreading the hole. If I discover otherwise, I'll edit this thread. Also, I really really wish I had read this before today! http://www.ninjette.org/forums/showthread.php?t=74042 |
#2 |
Join Date: Apr 2011 Motorcycle(s): 2009 V-Strom 650 ABS Posts: 166
Nice work! Glad you were able to figure something out.
I think I'll go retorque all my bolts now.... |
#3 |
#4 |
Not dead yet!
Now that I've gotten my replacement parts, I think it's an 8mm bolt that goes in there. I may stop at a hardware store and grab an 8mm bolt just to see. Regardless, I will be checking that bolt often, and probably using some Loctite to keep it in there!
#5 |
Join Date: Oct 2010 Motorcycle(s): 09 ninja 250 Posts: 131
did you take that bolt off in the past?
ride it like you stole it! |
#6 |
M7 would be a very odd size. M6 uses a 10mm wrench. M8 uses a 12mm. It should be one of them. Bolts are measured by the thread diameter, not the head size.
Use just a dot of blue loctite, not red or you'll regret it later. ![]() |
#7 | |
![]() Perhaps a thin dab of grease on the new part would help? Mine never came loose but it sometimes buzzed and puttin a dab of grease in there stopped it. When you downshift, you're pushing in the direction to loosen things up, some lube might help to keep the shifter from having friction in there when down shifting. Just a thought.
Always get a second opinion because most of these people are makin' this stuff up ![]() |
#8 |
Not dead yet!
PSA: check your shifter bolt once in a while | Jax1512 | 2008 - 2012 Ninja 250R Tech Talk | 65 | June 14th, 2019 02:23 PM |
HELP! Shifter linkage bolt fell off! | The Red Scourge | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 9th, 2013 07:20 AM |
Bolt on gear shifter? | aaron15 | 1986 - 2007 Ninja 250R Tech Talk | 5 | August 6th, 2013 12:22 AM |
Bent Shifter Replacement | Sushilover | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 22nd, 2011 11:57 AM |
DIY: Brake Pedal Replacement | OldGuy | 1986 - 2007 Ninja 250R Tech Talk | 1 | December 31st, 2008 10:27 AM |
