October 23rd, 2011, 01:45 PM | #1 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
While Filling the Gas Tank
I recall reading somewhere on this forum that said that you should not put your helmet over the gas tank because the fumes can eat the foam inside the helmet.
So when I go to the gas station, I normally leave my helmet on, leaning over the bike a bit while looking inside the gas tank while I fill it to watch the level. Would this be bad, since I can see and smell the fumes as they come out, right into my face? I'm just curious if other people notice this or if you take off your helmet when you fill the tank. |
October 23rd, 2011, 01:47 PM | #2 |
everything damages your helmet. it's why you don't wear a helmet for 20 years. just get a new helmet every few years
October 23rd, 2011, 01:50 PM | #3 |
But are the fumes excessively bad? Since the tank needs to be filled pretty regularly, will the constant exposure to fumes reduce the life dramatically, say like less than a year of use?
October 23rd, 2011, 01:58 PM | #4 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Personally I found out you shouldn't stand over the gas tank whilst filling it the hard way, face full of fumes FTL. That being said I don't think you have anything to worry about as long as you're not like directing the fumes straight into your helmet, and in that case I'd be more worried about what the fumes are doing to you not your helmet. I also found out you shouldn't leave your helmet on your tank because I did it once and my helmet smelled like gas afterwards... Didn't realize it harmed the foam in it though, my helmets like 5 years old anyways I should probably get a new one....*rambles on*
October 23rd, 2011, 02:24 PM | #5 |
I fill up with my helmet on while keeping nozzle at arms length. You can also keep your helmet visor down/shut. If there's a breeze, you can put your back to it. Then the breeze will blow the fumes away from you.
October 23rd, 2011, 10:30 PM | #6 |
So, where's the reverse?
You probably expose your helmet to more fumes driving in traffic. These helmets are tough. During ECE or SNELL certification, they first subject the helmets to solvent, temperature, humidity/moisture, and UV conditioning before doing the impact tests.
October 23rd, 2011, 10:55 PM | #7 |
Thanks for all the comments. I like the smell of petrol so fumes in the phace isn't too bad, though my lungs will probably hate me later in life :P
I guess putting the visor down is the best option, but regardless, I feel better about leaving my helmet on while filling the gas tank now. |
October 23rd, 2011, 11:44 PM | #8 |
I dont take my helmet off at all when filling, only gloves just so I can access the stupid buttons. How else are you supposed to do it? Behind your back under one leg standing on the seat and the pump?
October 24th, 2011, 04:58 AM | #9 |
I would pay to see that...
October 24th, 2011, 06:05 AM | #10 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
October 25th, 2011, 07:04 AM | #11 |
Join Date: Aug 2011 Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS Posts: 238
October 25th, 2011, 10:33 AM | #12 |
My biggest concern is gas splashing up into my eye. My next concern is keeping it off my pretty paint.
October 25th, 2011, 11:12 AM | #13 |
October 25th, 2011, 01:52 PM | #14 |
never enough
Join Date: Sep 2011 Motorcycle(s): Blue 2010 ninja 250R Posts: 277
i just keep my helmet on and look down at the tank.
custom graphics, zero gravity DB |
Gas Tank Lock stuck? Maintenance for gas cap with pics! | Skippii | 1986 - 2007 Ninja 250R Tech Talk | 35 | May 6th, 2021 09:03 PM |
DIY: Super-Secure Gas Tank Holder (for when your tank is removed) | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 21 | June 16th, 2014 01:20 AM |
Newbie Mistake. Filling up the gas tank | Samer | General Motorcycling Discussion | 10 | October 12th, 2009 08:09 AM |
