Old November 5th, 2011, 09:43 AM   #1
little fish
little fish's Avatar
Motorcycle(s): 2003 Nija, 1984 es200 ATC
30 minute modification
feel free to chime in on this one, just in case i did something wrong
yesterday i decided to do a little modification to the bike, to help it breath better.
i first took the mufflers off (and then ran it down the road to see how loud it was) (yes it's pretty loud)
then i modified the mufflers a little.....at first i wanted to take them apart so i drilled out the 4 rivits on the tip of the pipe .. but it wouldnt separate...so i drilled out the middle with a long drill. then where the 4 rivits were, i opened the holes up a bit. bolted the pipes back on and started her up....nice deep throaty sound!! sweet.
the second thing i did was hack the airbox ( i didnt like the 2 little holes for air to pass through) so out came the saws-all and hack-o -change-o...the air box is fixed.
all this took less than 30 min. would have been quicker if i didnt pull the pipes off. (but then i would have been able to get the shavings out either)
was going to post some pics, but i can't get on photbucket for some reason
little fish is offline   Reply With Quote
Old November 5th, 2011, 09:45 AM   #2
Have you made any jetting changes? Both of the mods you've done have made the bike run leaner.
Old November 5th, 2011, 10:08 AM   #3
little fish
not yet thats in the plans ..i'll have to keep an eye on the plugs for a bit to make sure i'm not running too rich
Old November 5th, 2011, 10:09 AM   #4
You definitely won't be running rich, you're running lean (i.e. - possible concern for parts at high revs high loads).
Old November 5th, 2011, 01:03 PM   #5
little fish
yeah i meant rich or lean ( i forgot the "or lean" part)
Old November 5th, 2011, 01:08 PM   #6
little fish
here's a pic of the exhaust mod
and the intake mod
Old November 5th, 2011, 05:59 PM   #7
setasai
setasai's Avatar
Changing the airflow so drastically, you should immediately notice some performance changes. Was there a real reason to wanting to make it "breathe" better? Did you not like the performance originally?
Old November 6th, 2011, 11:40 AM   #8
If you get the chance, buy some hose, slit it up one side, and run it up along the edges of the holes you cut in your airbox lid. Either that, or just file it down really smooth. No need to risk having plastic shavings sucked into your engine.
here's what I mean with the tubing stuff. check out this video at about 2:05 and he is lining the edge of the holes he cut in his airbox with slit hose:
*edit*
you're going to be lean in at least the idle circuits and the mid range. You might also have to go up a size in the jets to get the top end at the right mixture. Talk to @Timon about how his jetting needs changed when he did basically the same intake modifications you did in this thread:
http://www.ninjette.org/forums/showt...ht=air+box+lid
*/edit*
Old November 6th, 2011, 11:44 AM   #9
sounds like a great way to over heat your valves
Old February 19th, 2012, 11:07 AM   #10
shiftyninja
Motorcycle(s): 09' EX250J, 01' EX250R
I was thinking the same as above. Plus I like how he is still clueless on rich or lean conditions, yet he does something that you should have at least a little knowledge in.
shiftyninja is offline   Reply With Quote
Old February 19th, 2012, 11:26 AM   #11
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
DUDE, REJET!!!!! you will REQUIRE bigger main jets. also need to lift the needle or get a new needle. The bikes come lean stock anyways.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles
jasle is offline   Reply With Quote
Old February 19th, 2012, 12:25 PM   #12
@jasle, you're completely right.
I did this over thanksgiving, only my intake holes are A LOT cleaner (ocd about that), and I have slip-ons instead of hacking up my stock cans. The needles for sure had to be raised, and the oem 105 mains were lacking. I have 108's I'll be testing once I can ride.
Old February 19th, 2012, 01:06 PM   #13
raising needles only effects mid-throttle fuel ratio. for WOT, the only thing that matters is main jet size, float level and kinda the pilot system. needle height doesn't matter once you get to WOT
Old February 19th, 2012, 03:18 PM   #14
I know alex. Like I said, the mains were lacking because it wasn't pulling hard enough at WOT, but with the needles raised with another washer, the mid-range was perfect.
I've never touched the floats because I've never had issue with low rpm wot bogging.
Ninja 250R Modification patzcool Pictures 12 March 17th, 2013 09:20 PM
Fender modification Alex 2008 - 2012 Ninja 250R Tech Talk 226 March 4th, 2013 07:32 PM
Yakaru's Modification Fest Yakaru 2008 - 2012 Ninja 250R Tech Talk 43 December 2nd, 2012 08:43 PM
new airbox modification slow_2k10 2008 - 2012 Ninja 250R Tech Talk 6 February 19th, 2012 11:16 AM
Latest Modification kawigirl09 Pictures 8 October 10th, 2009 08:30 AM
