Old January 4th, 2012, 09:56 AM   #1
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
Gas cap
Hey Im not with my motorcycle so I cant look at it right now but has anyone taken the gas cap and that whole assembly off? Is there rubber in there? or anything that would melt? im thinking about powdercoating that as well
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old January 4th, 2012, 10:01 AM   #2
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Yeah there is a big rubber gasket that goes between the cap flange and the tank.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old January 4th, 2012, 10:03 AM   #3
massacremasses
Avid Kitteh Poster
that would most likely be easy to take off and replace though.
I was more thinking in the lock where you stick the key in and open it. Im wondering whats in there... I dont want to melt anything... If I can only powder coat the outer edge part of it I can do that to and just paint the center where the actual cap opens... I just want to put as many accents as I can. lol
Old January 4th, 2012, 10:09 AM   #4
greg737
Motorcycle(s): -
It's got a lot of parts, but they can all be taken apart.
Yes there's rubber in the seal portion. The seal has rubber gaskets and springs that press the gaskets against the tank's filler neck. This poition of the gas cap is designed to allow air into the tank (as fuel is burned) so that negative pressure doesn't build up and stop fuel flow to the engine and the spring-loaded part of the gas cap is there to prevent (to some extent) gasoline vapors from escaping into the atmosphere (a minor effort at pollution control) during positive pressure situations in the tank (like when the tank heats up on a sunny day). That's why the bike's gas cap tends to make those whining noises during and after rides.
I think you could disassemble it and powdercoat the parts that show then reassemble it. You'll just have to be carefull not to powdercoat the screw holes so it will all go back together.
Old January 4th, 2012, 10:09 AM   #5
CynicalC
CynicalC's Avatar
The whole lock mechanism is easily removed from the cap itself.
Old January 4th, 2012, 10:11 AM   #6
flynjay
flynjay's Avatar
There definately is some sealing surfaces in there. I would take the cap off to powder coat.
I would also take the petcock off.
Old January 4th, 2012, 10:17 AM   #7
greg737
Motorcycle(s): -
I think there's even a tiny rubber piece in the keyhole cover flip-up part.
Old January 4th, 2012, 10:27 AM   #8
Skippii
Milkshake Drinker
Skippii's Avatar
If you haven't done so already, I HIGHLY recomment completely taking the lock assembly apart anyway and greasing everything. Being stuck miles away from home ata gas station with an empty tank that has corroded shut and will not open really sucks.
Posted via Mobile Device
Old January 4th, 2012, 10:31 AM   #9
flynjay
flynjay's Avatar
A little WD40 in the lock goes a long way.
Old January 4th, 2012, 10:39 AM   #10
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I don't think he's talking about powdercoating the tank, just the gas cap outer area.
It's just a simple o-ring. Easy to replace.
k-os is offline   Reply With Quote
Old January 4th, 2012, 10:41 AM   #11
This sounds like a man speaking from experience.
Old January 4th, 2012, 03:41 PM   #12
massacremasses
Avid Kitteh Poster
yeah @k-os is right. just the gas cap area or part. The gas tank will be painted.
Even if I can just get that ring part around the cap separately I could live with that. I just want to break up the black with the green as much as I can
Old January 4th, 2012, 03:45 PM   #13
massacremasses
Avid Kitteh Poster
this sounds like to much work... haha
Im dying not being able to ride it lately. The weather has been BEAUTIFUL!!! and I cant ride it! GRRR trying to do it right but hurry it up. lol
I can always do that part later if I want since the whole bike doesnt need to be down.
Old January 4th, 2012, 04:39 PM   #14
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
This is the 49-state pregen cap disassembled, your newgen is likely similar. It's not hard to do, and yes, you will need to do it to powdercoat the visible bits because the curing temps will destroy parts inside the latch mechanism.
Old January 4th, 2012, 04:56 PM   #15
massacremasses
Avid Kitteh Poster
Yeah thats what I was afraid of. 420 degrees tends to destroy stuff thats not made to handle heat (anything but metal) lol
So the get to the outer cap i have to take it ALL apart eh? thats a bummer.
Old January 4th, 2012, 05:08 PM   #16
FrugalNinja250
I took mine apart to paint it over two years ago, did a two-stage silver and clear urethane:
Only took a few minutes to get it apart and put it back together again.
Old January 4th, 2012, 05:08 PM   #17
CynicalC
CynicalC's Avatar
No you don't... You take out the 7 outer screws that hold the cap on, plus the one hidden inside and it all comes out as one piece. Then you can just take off the latch from underneath. It'll take you 5 minutes.
Old January 4th, 2012, 05:32 PM   #18
massacremasses
Avid Kitteh Poster
ill take it off this Friday then after work. I get off at 2:00 so I should have some daylight left. Then stay late sometime next week to powder coat it all. Im thinking I may only do the outer ring to give it more of just an accent
Old January 6th, 2012, 11:07 AM   #19
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
There's that pic again! Hate green. But love that green.
JLinde1339 is offline   Reply With Quote
Old January 6th, 2012, 01:08 PM   #20
Skippii
Milkshake Drinker
Skippii's Avatar
To be clear, I'm not tanking about the keyhole, I'm talking about the latch mechanism underneath it. You can spay as much wd40 as you like in the keyhole ans it won't get into the latch part. You can open the cap and spray the latch with the key turned and you might get some in, but nothing will even come close to the level of corrosion protection as opening it up and covering it with waterproof grease. I also used to believe that WD40 would be enough....until I got stranded the second time.
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
Another stuck gas cap! HELP! :) mmiles19 1986 - 2007 Ninja 250R Tech Talk 2 August 8th, 2014 09:39 PM
Best Keyless gas cap? Indetrucks 2008 - 2012 Ninja 250R Tech Talk 8 May 22nd, 2014 09:06 PM
Why is My Gas Cap Still Leaking?! az3200 1986 - 2007 Ninja 250R Tech Talk 9 May 8th, 2013 06:17 AM
