Old February 3rd, 2012, 01:43 PM   #1
cuong-nutz
cuong-nutz's Avatar
Cool CBR250 Hugger on your Ninjette
I currently have run a modded Yamaha Byson Hugger from Indonesia on my Ninjette. This hugger is not very accessible option for those in the states and other countries so another option was needed. That's where the Honda CBR250r comes in. These new bikes came from the factory with a hugger installed and guess what, it fits with some minor mods! The CBR250r Hugger can be had for $10 plus S+H. A very cheap alternative!! It clears a 150 size tire fine too.
Byson Hugger vs CBR250r Hugger
The modifications needed:
Th mods needed for this hugger is similar to that of the Byson's but less cutting needed as the exhaust of the hugger is shorter compared to the opposite side.
1. You will need to notch a space to clear the rear tire alignment guide so the hugger will sit flush with the swingarm. After doing so, secure the hugger using the factory bolt from your OE chain guard:
2. A notch is needed to clear the factory chain guard guide.
3. You will need to trim this section to clear the frame and undertail. I have not tested the undertail/battery box clearance during suspension travel yet.
4. This is the exhaust side of the hugger. Here you can choose to hack half it off to clear the brake line and use the holes to zip tie the hugger down to the swing arm with the hugger's mounting holes.
HalfFast Racing Team
Old February 3rd, 2012, 01:55 PM   #2
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Good job!
I really like people who go out of their way to test fit things. Kinda like that DIY zip-tie throttle mod.
Very cool.
Old February 3rd, 2012, 11:45 PM   #3
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
definitely in for this.
I've been looking all over for that yamaha hugger, this is even better.
looks like the p/n is 40510-KYJ-900 according to cheap cycle parts
kamikaze is offline   Reply With Quote
Old February 4th, 2012, 08:55 AM   #4
And the best part is the whole thing is only $24 shipped. I got one sitting at home that I'm going to cut notches in and fit to a pre-gen swingarm. Hopefully I have enough space in front of the rear wheel so I don't have to cut off any of my wheel well
Only thing I don't like about the CBR250 hugger is that there's no definitive line to use for painting it like there is with the Byson hugger. I'll have to be creative if with the paint if I can get it to fit.
Old February 5th, 2012, 02:37 AM   #5
dragonboy
dragonboy's Avatar
Motorcycle(s): 2010 250R SE Green Machine, 2011 250R SE White Lightning
Great info. Any pics installed and is it hitting the undertail under load. Thanks!
dragonboy is offline   Reply With Quote
Old February 6th, 2012, 09:41 AM   #6
kamikaze
kamikaze's Avatar
ok, called the local Honda dealer with that part number, and they wanted $130
Old February 6th, 2012, 09:44 AM   #7
cheapcycleparts.com has them for about $24 shipped. That's what I payed for mine.
http://www.ninjette.org/forums/showthread.php?t=95715
Old February 6th, 2012, 09:49 AM   #8
kamikaze
kamikaze's Avatar
they're on backorder, and when I try to ship to canada their website comes up with a warning that has no text and I can't continue :/
I might just wait until I go to the Gap in may and have it shipped to the house there.
Old February 6th, 2012, 10:09 AM   #9
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
Dang, awesome find! Been looking for a good hugger but haven't been willing to pay like $100 for one... Just called the local Honda dealer here and I'll be off to pick on up for $12 this afternoon
ATGATT
Scattcatt is offline   Reply With Quote
Old February 6th, 2012, 11:02 AM   #10
HKr1
IC2(SW)
HKr1's Avatar
Honda part will just slow the Kawi down.
Old February 6th, 2012, 12:59 PM   #11
dragonboy
dragonboy's Avatar
Talking
Installed mine over the weekend on the wife's Green Machine, which is lowered 1.5". Absolutely no cutting required. Chain side back bolts right up. Ran the brake side right behind the brakeline and it clears the reservoir easy. Zip tied rear hole to the brake line loop to keep the hugger from sliding front to back. Then used two zip ties to hold it down to the swingarm. I did not have her try it out yet, but clearance to the battery box is close. Again, it's lowered so it may have more clearance on stock ride height with some added compression. Wife is a shorty so it is currently set at 1.
I would have experimented on my bike, but I already have the Scott's hugger and didn't feel like dealing with reattaching it. Overall, the CBR250 hugger is super easy to install and looks like a factory part. Only con is possible clearance issues. I will increase the rear shock to 2 and notch out the hugger to clear the battery tray if it becomes an issue.
BTW, it's so solid, I didn't need to use the front hole on the chain side. It kinda tucks behind the rearset so you don't even notice it.
Old February 6th, 2012, 01:05 PM   #12
looks cool. nice and cheap.
Old February 6th, 2012, 01:12 PM   #13
This is good to know for me. I was planning on making some brackets out of brass strips, but I might not need to now.
I still need to figure out if this will clear the front-most section of my wheel-well, or if I have to hack a section of that off to get it installed.
Old February 6th, 2012, 01:16 PM   #14
The link I put in that posted was Cuongs sale thread. You might be able to work something out with him. I mean even if you pay shipping to Canada, that would still be a heck of a sight cheaper than $130, plus that would get the part off his hands. Win-win
Old February 13th, 2012, 11:41 AM   #15
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
ordered one today
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old February 16th, 2012, 05:47 AM   #16
g21-30
g21-30's Avatar
Here you go and for ONLY $8.88:
http://www.cyclepartsnation.com/page...0510-KYJ-900/1
This place always beats Cheap Cycle Parts!!
Old February 16th, 2012, 07:32 AM   #17
That's good to know. I'll keep them in my bookmarks thanks g21-30
Hows their shipping rates?
Old February 16th, 2012, 08:12 AM   #18
g21-30
g21-30's Avatar
^^For the hugger, the shipping is ridiculous! $21.00 from MI to VA!
Old February 16th, 2012, 08:50 AM   #19
ator
ator's Avatar
$19.77 from Kalamazoo Mi. to Riverview MI. !!
ator is offline   Reply With Quote
Old February 16th, 2012, 09:25 AM   #20
Scattcatt
Scattcatt's Avatar
Geez! Those prices are insane! There's no Honda dealerships around to order from?
ATGATT
Old February 16th, 2012, 09:39 AM   #21
dragonboy
dragonboy's Avatar
Local Honda dealer for $11 n no shipping.
Old February 16th, 2012, 09:59 AM   #22
ouch that shipping is harsh! I could have gone to my local dealership. I didn't even think to check State 8!! oh well. I still think $24 for a hugger is a pretty good deal. Plus it gives me a project to work on retrofitting it to my pregen...
Old February 20th, 2012, 03:56 AM   #23
I prefer the Byson hugger because it has better lines for painting and it reaches the full length of the swingarm, enhancing the look as if it were not so thin and rectangular (looks like two dinky 1x2" boards otherwise). I GREATLY prefer the Sportisi style that covers the whole swingarm with one that looks like it came from a completely different bike!
Old March 21st, 2012, 11:15 AM   #24
Scattcatt
Scattcatt's Avatar
Just installed my CBR hugger, total cost was $13 (including tax) and about 30 minutes of modifying to fit since I took a different approach to retrofitting. Looks great! Even without modding it fits okay, it's just off center to the left a little bit. I have it fastened down by one of the original screws for the chain guard (the back one) and one zip tie on the right side. It's surprisingly sturdy with only the one screw in, but I zip tied the other side for the sake of more security. I can post pictures later of the parts that I grinded off to make things fit.
ATGATT
Old March 21st, 2012, 11:20 AM   #25
TheJimmyEnglish
TheJimmyEnglish's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250R Red
Will it fit a 150/60 tire?
My YouTube Channel
TheJimmyEnglish is offline   Reply With Quote
Old March 21st, 2012, 11:53 AM   #26
Scattcatt
Scattcatt's Avatar
I'm running a 140/70 BT-003RS on it right now with lots of room all around, my first thought? Yes. With the modding of course. Without the modding you'll likely rub on the right side since it sits offset to the left
ATGATT
Old March 21st, 2012, 11:58 AM   #27
dragonboy
dragonboy's Avatar
Yes, lots of room for 150/60..
Another install tip: I cut about 1 inch off the brake side hugger tip and tucked the end behind the brake hose loop. You may need to bend the loop wider a bit but it now fits better and helped center the hugger. Still used zip ties.
Lastly, since my wife's 250 is lowered 1.5", there was very little clearance between the hugger and bottom of the battery tray so I notched out about an inch of the hugger that sits under the battery tray. So far no rubbing and looks totally stock.
Good luck!
Old March 22nd, 2012, 11:06 AM   #28
NathanUc
B-Town Ninja
NathanUc's Avatar
Motorcycle(s): Black 2013 Ninja ZX6R ABS
I ordered one from my local dealership yesterday for $12. If people are interested, I'll make a video of the install when I get it.
Downgraded to a 2013 636. Previous owner of a 2010 250r
My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja
NathanUc is offline   Reply With Quote
Old March 22nd, 2012, 12:37 PM   #29
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Sweet I am so glad you guys found a mod in my price range
Old March 25th, 2012, 08:07 AM   #30
leed
leed's Avatar
Motorcycle(s): Time will tell
Here is another cheaper hugger that doesn't charge outrageously for shipping and is in stock:
http://www.2wheelpros.com/oem-parts/...-900-part.html
I'll have to contact my local dealer to see if they can get me a hookup
Old March 25th, 2012, 10:26 AM   #31
Scattcatt
Scattcatt's Avatar
I believe this is the one everyone is talking about to begin with at least this is the one that I ordered and ended up waiting 2 months to get.
ATGATT
Old April 12th, 2012, 06:15 PM   #32
kwykoff
Motorcycle(s): 2011 Ninja 250
Nathan, I haven't looked you up on youtube yet, but did you end up posting an install vid?
my hugger just came in today, $15.50 after tax.
Also, side note, I'm from Bloomington. Graduated from South in '03
kwykoff is offline   Reply With Quote
Old April 12th, 2012, 07:04 PM   #33
NathanUc
B-Town Ninja
NathanUc's Avatar
Mine didn't even come in.. not sure what the hold up is but the dealership is taking forever. I was estimated to have it early last week...
Bloomington is a pretty sweet town with awesome roads. I grew up in Hammond/Gary though lol
Old April 12th, 2012, 10:05 PM   #34
leed
leed's Avatar
Apparently this part is in super high demand. My dealership does not have it either, and 2WheelPro's backordered it via Honda until the 18th.
Old April 14th, 2012, 11:48 PM   #35
kwykoff
so mine sits a bit higher than the OPs pic, but I tried for a no-cut approach. I don't think I'm going to leave it this way, it's not really where I want it to be. I'm thinking about pulling it off and wrapping it in carbon fiber vinyl and then cutting it down some to make it hug the tire more.
Old April 15th, 2012, 07:04 AM   #36
mkulchar
mkulchar's Avatar
Motorcycle(s): 2010 250r ninja
Wow that looks great, im goin to order one for that price.
If you could make a video of the install that would be awsome!!
Does anyone have a pic of the exhast side?
Excited to see the outcome.
Last futzed with by mkulchar; April 15th, 2012 at 09:24 AM.
mkulchar is offline   Reply With Quote
Old April 17th, 2012, 10:21 PM   #37
Steven250R
Steven250R's Avatar
Motorcycle(s): 2009 NINJA 250R
I LIKE!
Def. add that to the list of future mods.
Thanks!
Steven250R is offline   Reply With Quote
Old April 18th, 2012, 08:35 PM   #38
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
I just ordered one with the local dealership today. I changed out my tires and the 140 was the smallest option for the rear. Well, the hugger i had was designed only for a 130 rear. i contacted the seller and he said i should be able to trim it to fit. so i trimmed it and it still rubs not the edges of the tire, but in the middle..there goes $160 ...now its a week wait until i can mount a new hugger on my bike
Gorilla25 is offline   Reply With Quote
Old April 20th, 2012, 08:25 AM   #39
mkulchar
mkulchar's Avatar
I called the honda dealer near me and backordered till may. And they charging 73$
OUCH!!!!!
went to my kawi dealer and they had it for 16$. Now waiting for it to come in
Last futzed with by mkulchar; April 20th, 2012 at 11:41 AM.
Old April 20th, 2012, 08:57 AM   #40
diablos991
diablos991's Avatar
Motorcycle(s): 2009 Ninja 250 (blue)
I'm confused... You rode your bike while the hugger was rubbing on the middle of the tire and didn't notice in time to not ruin the tire?!
I would think that the very first thing to do when installing a larger tire would be to inspect fitment before ever getting on the bike and placing your life in it's hands.
diablos991 is offline   Reply With Quote
In regards: 2011 CBR250 kills the Ninjette on the track? ROADandTRACK Ninjettes At Speed 15 January 26th, 2012 08:39 PM
2011 CBR250 kills the Ninjette on the track? Warapura Ninjettes At Speed 65 October 27th, 2011 07:47 PM
Ninjette price up $400: Honda CBR250 up $3000 DiscoBriscoe General Motorcycling Discussion 9 October 3rd, 2011 09:26 PM
For all of those with a cbr250 also... choneofakind Motorcycle-related 2 September 5th, 2011 08:10 AM
Might get a CBR250 also. ninja250 The Ex-Ninjetters Lair 48 September 1st, 2011 10:34 AM
