Old November 23rd, 2008, 11:53 PM   #1
Daytona Water Temp Gauge
sorry, no DIY, but after you take off the right bottom fairing, it's as simple as connecting a ground wire and replacing the present coolant temp sensor with the unit they provide. dress the wiring and you are done. if you want the gauge to light up, you do need to tap into a switched +12v source, but they give you a splice to do that, too.
Doubles as a clock, too.
Old November 24th, 2008, 01:32 AM   #2
Neat mod! Is it relatively water-proof?
Old November 24th, 2008, 10:13 AM   #3
It's supposed to be... we'll see.
Old November 24th, 2008, 11:32 AM   #4
HKr1
IC2(SW)
HKr1's Avatar
Very cool add-on Did you get it it from MotoSport ? Think will pick one up after a Baby Eagle
Old November 24th, 2008, 11:39 AM   #5
I got mine through a friend when I couldn't find a company that would ship these to Hawaii for a reasonable price. They usually run about $75 at discount on the web.
Baby Eagle???
Old November 24th, 2008, 01:37 PM   #6
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
It still cheeses me off the temperature range these bikes go through .
VeX is offline   Reply With Quote
Old November 24th, 2008, 01:41 PM   #7
operating temps that I've seen while the bike is moving down the road is between 150-190F.
Old November 24th, 2008, 04:26 PM   #8
HKr1
IC2(SW)
HKr1's Avatar
Baby Eagle???
Baby Desert Eagle 9mm
Old November 24th, 2008, 04:31 PM   #9
I knew that, but couldn't figure out what that had to do with the bike... more the wallet, eh?
Old November 24th, 2008, 04:39 PM   #10
HKr1
IC2(SW)
HKr1's Avatar
Get her CCW & will be perfect for the bike
Santa will bring a dayton temp gauge
Old May 16th, 2009, 07:47 AM   #11
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Is this gauge made by Shindy?
pantera is offline   Reply With Quote
Old May 16th, 2009, 07:52 AM   #12
Snake
Snake's Avatar
Looks like it also has a clock. Was I seeing that correctly?
Old May 16th, 2009, 07:55 AM   #13
pantera
pantera's Avatar
Yes, it does come with a clock also.
Old May 16th, 2009, 08:27 AM   #14
pantera
pantera's Avatar
How much coolant do you lose when you unscrew the OEM sensor ?
Old May 16th, 2009, 10:32 AM   #15
very little... maybe a tablespoon??? just be ready with the new unit when you take out the old.
Old May 25th, 2009, 10:49 AM   #16
ScorpionNinja
ScorpionNinja's Avatar
Aye aye, nice lil gizmo too add... ill look into getting one later on also! " So easy a caveman can do it " ??? lol
Old May 26th, 2009, 06:04 PM   #17
pantera
pantera's Avatar
Received and installed my gauge today.All went well except one well nut breaking on the back of one of the fairing bolts.I was able to still hold it in place and get the screw started so I was able to tighten the bolt.While reading the instructions I realized the internal battery on the gauge is not replaceable.I wonder if and when the battery fails if the gauge will still work as long as it is hooked to a power source on the motorcycle.Let the bike run to test the gauge and all seems well.Fan kicks on at 211 degrees F.
Old May 27th, 2009, 05:38 PM   #18
pantera
pantera's Avatar
Called the company today that makes these gauges(shindy)and they claim the gauge will indeed still work if and when the internal battery fails.
Old May 27th, 2009, 05:44 PM   #19
then, what's the battery for... clock?
Old May 27th, 2009, 10:22 PM   #20
headshrink
headshrink's Avatar
Perhaps this is a dumb question, but how do you use this gauge? Is the overheating warning light on the bike not sufficient?
It gets hot here in the summer, so I remembered this thread and was wondering if it would be more useful or more of a toy.
Old May 27th, 2009, 10:30 PM   #21
I suppose if you caught the overheating light when it came on, you might be okay, but most times it is not caught early and by the time you notice, the engine is toast. If I read over 200 when I ride, I start to monitor the temp more closely.
I bought mine mainly to monitor the warmup and to know when the coolant was "up to temp" so I would know when it was okay to start pushing the bike. If I'm reading 160 on the gauge, I'm pretty confident at that point the engine is completely warmed up. The clock is a nice feature, too.
Old May 28th, 2009, 01:38 AM   #22
pantera
pantera's Avatar
The battery is for the memory on the clock.
Old May 28th, 2009, 10:41 AM   #23
Banzai
Psychic war veteran
Banzai's Avatar
Cool, but I'd still trade the damn auto petcock, fuel level gauge, and temp idiot light for a decent half ass temp gauge in the proper location. Add that to the list with a decent tach, too.........
The more I think about it, the more I have to resist the urge to retrofit the Koso gauge set.......
Must fight the urge!!!!!!!!
Old May 29th, 2009, 07:34 PM   #24
Duvivr6
Motorcycle(s): 09 Ninja 250R Special Ed
Wow I really llike that looks nice!! were you get it?
Is there a way to have both the stock sensor ad the gauge installed at the same time?
Duvivr6 is offline   Reply With Quote
Old May 29th, 2009, 07:36 PM   #25
I guess you could tee off at the sensor mount point, but why? not sure if there is enough room to do that, though.
Old May 29th, 2009, 07:52 PM   #26
Duvivr6
Just to keep he functionality of the stock gauges
Old May 29th, 2009, 07:57 PM   #27
that would mean for the idiot light on the dash? the gauge is there so that you will know long before that light goes off that the bike is overheating.
like I said, it is possible if you tee off the sensor tap, but I wouldn't know if there's enough room to do so.
Old May 29th, 2009, 08:04 PM   #28
Duvivr6
yeah i'm sure the light is useless anyways cause by the time you get the light bike should be on fire! if you even are paying attention
Old May 29th, 2009, 09:45 PM   #29
headshrink
headshrink's Avatar
I think I saw mine once. The bike wasn't on fire, but my legs were.
Old May 30th, 2009, 03:09 PM   #30
pantera
pantera's Avatar
Finally stopped raining so I could take the Ninja out to try the gauge.Gauge works really well and seems to be extremely accurate.Can see the temp rise a few degrees when at stops and cool down at speed.Was only 66 degrees here today so the bike ran at 144 degrees at 75 mph on the highway and at about 150 to 157 degrees on the back roads.Even the gauge on the older Ninja 250 could not show you that.It just stayed in a general area while at operating temperature.
Old May 30th, 2009, 03:22 PM   #31
headshrink
headshrink's Avatar
Where is this available? I'm having difficulty finding it.
Old May 30th, 2009, 03:26 PM   #32
It used to be in Richard's store before, but I don't see it now. May want to PM him and ask.
http://store.racebikerentals.com/mer...tore_Code=0001
Old May 30th, 2009, 03:28 PM   #33
pantera
pantera's Avatar
Dennis Kirk,Parts Unlimited.Also check the web for Shindy gauge or Daytona temp gauge.I found a few places on line that carry it.
Old May 30th, 2009, 03:29 PM   #34
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
http://www.motosport.com/street/prod...mperture+gauge
Old May 30th, 2009, 04:26 PM   #35
headshrink
headshrink's Avatar
Thanks!
One thing I thought of while looking at the specs.... is the Daytona sensor threaded the same as the OEM sensor?
I assume so since it hasn't been mentioned, but just want to make sure.
Old May 30th, 2009, 04:58 PM   #36
yes.
Old May 31st, 2009, 09:08 PM   #37
NaughtyusMaximus
Motorcycle(s): 2009 ex250
What temp would the idiot light come on at normally?
NaughtyusMaximus is offline   Reply With Quote
Old May 31st, 2009, 09:13 PM   #38
230-248* f.
Old June 14th, 2009, 02:24 PM   #39
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
I installed this yesterday. I gotta say that I feel more secure knowing that I will not be overheating my bike now, especially since I'm in Texas. Thanks for your pics and advice, Kelly. It was definitely helpful.
Matt
2008 Ebony Ninja 250R (a.k.a. "Venom")
Mo1981 is offline   Reply With Quote
Old June 14th, 2009, 02:51 PM   #40
Anytime, Matt. Great to see you got it figured out.
Glad you like the temp gauge. I also like the clock function, but it's sometimes difficult to switch over with gloved hands. The clock gets a bit off over time, so keep an accurate eye on it.
Daytona Water Temp Gauge Problem?? kenji_808 2008 - 2012 Ninja 250R Tech Talk 2 December 28th, 2011 04:23 AM
Water Temp Gauge etiainen 2008 - 2012 Ninja 250R Farkles 5 November 4th, 2011 04:30 PM
Daytona Water Temp Gauge Keyoa 2008 - 2012 Ninja 250R Farkles 2 April 3rd, 2011 06:13 PM
Daytona Temp Gauge wellcraft General Motorcycling Discussion 0 January 26th, 2010 07:24 PM
Daytona Temp gauge whylee 2008 - 2012 Ninja 250R Tech Talk 9 January 20th, 2010 08:50 PM
