March 15th, 2012, 05:27 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
My rear brake doesn't work?!
Hey guys! troubles troubles troubles...
Al right, my rear brake doesn't work. When i press down the brake it says "pffftt" and the brake caliper dosen't move onto the disc at all. The pedal is very easy to press on. Like there is no resistance at all, only the spring makes it jump back to place. Brake fluid is full and clean. hope you guys can help me. hate driving without the rear brake |
March 15th, 2012, 10:56 AM | #2 |
Blown seal/seals inside the master cylinder. Time for a rebuild.
March 15th, 2012, 03:18 PM | #3 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
Try bleeding any air from the lines first.
March 15th, 2012, 03:27 PM | #4 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
Have you done recent maintence, or is this something that has developed over time?
March 15th, 2012, 05:20 PM | #5 |
Can you see any leak of brake fluid along the hose or at the caliper?
March 15th, 2012, 08:56 PM | #6 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
The hydraulic system has no pressure. Seeing how you state the fluid is clean I am guessing new fluid recently and there is either air in the line or a blown seal in the master cylinder.
Either problem is not allowing the fluid system to compress/displace which activates the caliper. |
March 15th, 2012, 09:16 PM | #7 |
I was thinking one of your pads was stuck on the guide or you have the pads in wrong. Double check that the pads are making good contact with the rotor and are free to move.
Happened to me when I changed the rear tire. |
March 16th, 2012, 12:13 PM | #8 | |
Indeed im also 95% sure that this is my problem! How can i fix this? |
March 16th, 2012, 12:32 PM | #9 | |
If you have air in the line this method will remove it from the system. This process should be performed multiple times as needed to purge air from the system and keep an eye on the rear reservoir filling it as needed. If the above process does not improve the rear brake the problem could be a blown seal in the master cylinder itself which would require removal and rebuilding. What has recently been done to the rear brake system? |
March 16th, 2012, 02:40 PM | #10 | |
March 16th, 2012, 02:50 PM | #11 | |
March 16th, 2012, 03:30 PM | #12 | |
Tach doesn't work on my race bike | nick5446 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 15th, 2013 09:35 AM |
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL | coelgrim | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 11th, 2013 05:10 PM |
fuel gauge light doesn't work. | jon.b.calderon | 2008 - 2012 Ninja 250R Tech Talk | 1 | January 20th, 2013 11:03 PM |
Fuelly badge doesn't work right | ricomtzjr | Help | 7 | December 17th, 2012 01:59 AM |
Brake light works, but doesn't work =/ | CalvinAmI | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 14th, 2012 07:24 AM |
