Old March 27th, 2012, 12:50 PM   #1
swsh23815
Motorcycle(s): 2012 kawasaki ninja 250r
Gas Leaking into oil
Need help assessing the problem.
On my ride to school last week I was running a little late so I was riding a little faster than I normally do. About 5 minutes from school traffic come to a complete stop. After a couple of mile's negotiating the traffic i notice that the rpm's are not right. Normally riding at 70mph the rpm's are right around 8500, now they were at 9500-10000 to go the same speed. Since im running late for my final i just park the bike and head to class. On the way home the rpm's where still a little off but not as bad and as i got closer to home they seemed to be back to normal. When i get home i take a look at the oil gauge and the oil level seemed to jump up from when i checked it in the morning. Also the oil has a pretty good smell of gasoline. The coolant level has'nt changed, thats why i suspect gas. Does anyone know what the issue could be? The bike is a 2012, has 3,500 miles on it. I just changed the oil on it at 3000 miles.
here is a pic of the oil:
swsh23815 is offline   Reply With Quote
Old March 27th, 2012, 01:21 PM   #2
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
While parked, something prevented your float valve(s) from closing all the way and your carb overfilled with gas. When this happens, the gas runs into the intake and down through the cylinders, into the oil. Don't run it again until you get the oil changed and have your carbs looked at.
cbdallas is offline   Reply With Quote
Old March 27th, 2012, 02:52 PM   #3
DaBlue1
DaBlue1's Avatar
You may or may not have 2 different problems
Being that your bike is 2012 with 3500 miles on it, it would be rare for the carbs to have a stuck float valve and a stuck petcock. Because the petcock is vacuum operated it to would have to be stuck open for any significant amount of gas to change the oil level. The fuel bowls don't hold that much gas. From the looks of your oil level it appears to be at the max level which is fine.
As far as the smell of gas in the oil, that too can be normal. On occasion you can have a gassy smell in the oil especially right after riding it long distances or riding at high rpms or riding it WOT or using the choke on a cold engine. Since the fuel in a cold engine is sticking to the cylinder walls due to condensation, the mixture is too lean for the engine to start. The choke system will add fuel to the engine to compensate for the fuel that is stuck to the cylinder walls. Once the engine is warmed up, condensation is not a problem, and the choke is not needed. Due to the incomplete vaporization of fuel at slow speeds or the additional fuel required at high speeds, the actual air/fuel ratio is usually a little richer.
After the bike has set a while and cooled down, recheck the smell of the oil, as the tiny amount of gas will have a evaporated. If not drain and change your oil and compare it to that which you removed. If the problem is not resolved, return you bike to the dealer for further maintenance since your bike should still be under warranty.
Your second issue with the rpms may have to due with the IC ignitor and overall heat. This has been a noted problem and pops up on rare occasions.
http://www.ninjette.org/wiki/Ignitor_problem
Old March 27th, 2012, 03:34 PM   #4
Be careful about reading the gauge always with the bike on its wheels and in a perfectly vertical position, and with a cool engine.
Otherwise, you may see great variations in the level.
An improperly adjusted clutch cable may be the cause of the change in rpm's.
Changes in oil viscosity due to temperature or contamination are mostly noted during clutching out and seldom at full engagement.
The fuel petcock is vacuum activated in order to prevent carbs' overflow with engine off.
Not saying that your bike has no problem; just not to be too apprehensive.
Last futzed with by Motofool; March 28th, 2012 at 05:16 PM.
Old March 28th, 2012, 08:03 AM   #5
swsh23815
After reading the post's on the IC ignitor, i think that is definitely what happened on that day. As far as the oil, maybe I was just paranoid about it after having that issue. Regardless, I am going to change the oil and see if the problem persists.
Old March 29th, 2012, 03:13 AM   #6
I always smell gas when I change my oil.
Anyway, the tach variance is likely the infamous and well-known overheating CDI. It seems that MOST of our bikes do it. *shrug* They read higher when the CDI is warm than when it is cool.
Old March 29th, 2012, 04:08 AM   #7
zzrguy
zzrguy's Avatar
Motorcycle(s): 2002 ZZR 250
Exclamation
your oil looks due for a change anyways :P Its all milky looking like paint
zzrguy is offline   Reply With Quote
Old March 29th, 2012, 06:13 AM   #8
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Your oil is gross looking.
Old March 29th, 2012, 07:14 AM   #9
swsh23815
The oil is only 600 miles old. That's why I suspected something leaked into it.
Posted via Mobile Device
Old March 29th, 2012, 08:26 AM   #10
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
There probably is something...someone else has a problem where they did a valve job, and now there oil is a milky yellow color. Might want to look into there thread as well. Could anti-freeze have gotten into your oil?
Old March 29th, 2012, 11:57 AM   #11
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Worn down float valves will do that. Ask me how I know.
Old March 29th, 2012, 03:24 PM   #12
how do you know?
Old March 29th, 2012, 05:17 PM   #13
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
how do you know?
I don't.
Old March 29th, 2012, 09:01 PM   #14
KELPHYN
KELPHYN's Avatar
How does the oil look now? Hard to really tell from the photo but it could just be your oil is frothed with air. Sometimes happens to some oils if run hard. If oil looked fine after sitting for awhile, but the problem presists; change brand of oil.
Old March 29th, 2012, 09:27 PM   #15
swsh23815
I have been using the kawasaki brand oil since I got the bike. Most of my riding is 60 mile trips on the freeway too and from school. Would the constant 8500 rpms have any effect on the oil looking like that?
Old March 29th, 2012, 09:54 PM   #16
KELPHYN
KELPHYN's Avatar
I tried Kawi synetic ONCE,(dealer was out of Amsoil) Didn't like it. Engine was noisey, clutch felt like it was slipping, don't remember if the oil frothed. Have run Amsoil 10-40 motorcylce oil ever since. Motor just seems to run smoother. Might just be me, but I like it. Got good deal on a case, so I'm set for the next 6 oil changes.
Old March 29th, 2012, 10:03 PM   #17
KELPHYN
KELPHYN's Avatar
Oops, forgot to answer your question. Oil could froth one time and not the next. Can depend on temperature, how hard you run it if the bike wasn't quite warm, lots of little things. That's why I asked what the oil looked like later. Did it look normal in the morning.
Old February 4th, 2013, 08:31 AM   #18
LNasty
Daily Jap rider
LNasty's Avatar
Question
my oil looks and smells the same what ended up being wrong with yours, I also have 2012 with rpm issues. Have no idea what's wrong
Old February 4th, 2013, 08:53 AM   #19
DaBlue1
DaBlue1's Avatar
Depending on the temp some oil can look cloudy through the sight glass, then be normal looking when warm. If you suspect a lot of gas in your oil you should drain it and inspect it. If there is a significant amount of gas getting in your oil, the oil viscosity will be noticeably thinner than normal, maybe milky in color and smell heavily of gasoline. If this is your issue, you should change your oil ASAP and replace the petcock with a new one, so you won't have to deal with a recurring problem. If your bike is under warranty, make Kawasaki fix right away.
As far as your rpm issue goes, see this thread.
Leaking gas Alisha_Ardella 2008 - 2012 Ninja 250R Tech Talk 23 May 11th, 2015 10:41 AM
leaking oil D: TwoSixSided 2008 - 2012 Ninja 250R Tech Talk 4 December 3rd, 2013 06:06 PM
Coolant leaking into oil and oil leaking out of somewhere. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 31 May 25th, 2013 04:09 PM
Why is My Gas Cap Still Leaking?! az3200 1986 - 2007 Ninja 250R Tech Talk 9 May 8th, 2013 06:17 AM
leaking a little gas h0yitsdom 1986 - 2007 Ninja 250R Tech Talk 15 July 11th, 2011 04:57 PM
