May 7th, 2014, 10:26 AM | #1 |
Join Date: Apr 2014 Motorcycle(s): 1995 ninja 250r Posts: 130
adding a glove box to fairing
to start let me say i have a pre-gen.
i'm starting to load up my bike with all the little extras that make life easier. was just sizing out the front fairing for a clock/usb charger and realized that there is more than enough room there to add a compartment on each side big enough for my gloves, phone, or what not. started to look around the shop for sheets of plastic to wield up some boxes but decided that there is no way that i am the first to try this and someone else probably did it and knows a prefab way to get a couple water tight lockable boxes mounted in the fairing. i am sure that there is a bike out there that has boxes built in, ie: goldwing, but dont know of any with slim storage boxes that would fit my space requirements. so what do you guys think? any ideas? |
May 7th, 2014, 10:29 AM | #2 |
Certified Slacker
Join Date: Apr 2014 Motorcycle(s): 2010 Kawasaki Ninja 250R SE Posts: 232
This sounds like a great idea.
Ninja Bob |
May 7th, 2014, 11:27 AM | #3 |
I remember someone mounting a slim lock box on their pregen. I bet the thread can be found. /searching
May 7th, 2014, 11:59 AM | #4 |
Join Date: Feb 2012 Motorcycle(s): 2012 Ninja 250R Posts: 362
@jschorr One option would be small Pelican Cases mounted within the fairings. The have rubber seals and are waterproof. They come in many sizes, colors, and configurations. Other places to check for waterproof containers are boating or camping/backpacking supply companies.
May 7th, 2014, 12:00 PM | #5 |
I have been trying to search but haven't come up with the right combo of words yet
The boat/pelican case idea is pretty good. |
May 7th, 2014, 12:33 PM | #6 |
Certified Slacker
One thing you may want to consider is heat resistance depending on how close it is to engine components. But I haven't really peaked under there, so I don't know myself.
Ninja Bob |
May 7th, 2014, 01:07 PM | #7 |
So far....
Goldwing, triumph, Honda 1100 all have inside fairing pockets. The triumph has a 9 inch deep one making it the best so far. Need to find dimensions, and that is turning out to be harder Than it should be. Heat should not be a problem. This will be mounted in front of the fork radius. It will cut air flow a bit. |
May 8th, 2014, 01:48 AM | #8 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
Hmmm. An interesting idea. If proven doable, I could see this being really useful. I have a newgen but I imagine the concept is the same, no? I remember a post somewhere around here where a rider put a USB port or something of the sort on the top side of the main fairing. I could see cutting a notch in the topside, adding hinges and a lock for the door... This is possible lol.
Hope it works, would love to see it done.
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
May 10th, 2014, 08:38 PM | #9 |
Depends on how easy you want to be able to access your "storage". Pelican boxes can be mounted inside the fairing. To me, I'd rather just use a backpack to be sure.
You never can tell when you might need something! |
May 10th, 2014, 08:47 PM | #10 |
Intrepid Adventurer
You could make metal mounts or baskets that water tight cases could slide into and then purchase some affordable cases from walmart or ebay since they have a variety of shapes and sizes. that way u can put them on the bike or pull them out and take them with you if you are camping or staying in a hotel room.
Also many ATVs Scooters snowmobiles and jet skis have weather tight glove boxes Go on ebay motors and select motorcycle parts, snowmobile parts or whichever search for "compartment" "glovebox" Here is one that looks suitable it is lockable. Change out the keying or get a key made http://www.ebay.com/itm/B252-36413-0...1d2d72&vxp=mtr this is decent enough too http://www.ebay.com/itm/1980-Honda-C...8b1055&vxp=mtr Another good one. a bit large http://www.ebay.com/itm/VF700-VF-700...fde4d5&vxp=mtr
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
battery box/ tool box | tc.young | 1986 - 2007 Ninja 250R Tech Talk | 8 | July 2nd, 2013 07:17 PM |
Adding an Super Coolant | 7oxSin | 1986 - 2007 Ninja 250R Tech Talk | 22 | August 5th, 2012 10:52 AM |
Hey, thanks for adding me. | NickNYC | New Members | 25 | January 27th, 2012 12:17 AM |
Adding another one to the stable... | Apex | Off-Topic | 16 | March 18th, 2010 05:56 PM |
