April 20th, 2015, 09:45 AM | #1 |
Join Date: Feb 2015 Motorcycle(s): 2008 ninja 250 Posts: 22
Can i see a picture of your installed Shogun frame sliders
I installed mines over the past weekend. I don't have any pictures of mines right now but I will get some tonight. The reason for this post is after I installed it, I noticed the left side of the frame slider is.... extremely short. I think if my bike were to lowside, my fairings would not be protected on the left side.
I wanted to see if this is true for everyone else. Googling images doesn't give me both sides of the bike for reference. Does anyone else notice this or is it just me? |
April 20th, 2015, 09:58 AM | #2 |
Certified Troublemaker
The set i have on my 300 are side specific and one is longer than the other... May be worth double check you have the correct slider on the correct side as the newgen and 300 should be the same.
April 20th, 2015, 10:01 AM | #3 |
Yeah I have it installed on the correct side. Long one being on the right side due to the exhaust and the shorter one on the left. The issue is the left side's slider is just way too short to protect anything
April 20th, 2015, 10:05 AM | #4 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
You obviously mounted the cross bar correctly, did you also put the correct pucks on the right side? The slider pucks are also different lengths...
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
April 20th, 2015, 10:08 AM | #5 |
Didnt think of the mounting bars themselves.
April 20th, 2015, 10:22 AM | #6 |
April 20th, 2015, 10:31 AM | #7 |
The pucks are the bits sticking out of the fairings, the crossbar is what they bolt to.
April 20th, 2015, 10:35 AM | #8 |
Please excuse the drawing...
I mounted as such as shown in figure 1 on each end. Are you saying that I however have installed those bars on the wrong side (left belongs on right, right belongs on left?) and need to switch them out? |
April 20th, 2015, 10:58 AM | #9 |
I don't know if its possible to mount the crossbars on the wrong sides. Check the part numbers against the installation instructions.
What side did you put the longer puck on? It should be on the left side according to the instructions. Edit: just reread your post, you mixed the pucks up. Swop them out and you should be fine.
April 20th, 2015, 11:44 AM | #10 |
You're right... just saw the instruction manual and it clearly says longer puck on the left side....
I swear I looked at this youtube video yesterday while installing and he did longer on the right side... Oh wells https://www.youtube.com/watch?v=D8zFHoJ2Eyo |
April 20th, 2015, 11:54 AM | #11 |
It happens, easy fix.
April 20th, 2015, 12:12 PM | #12 |
Time to open the fairings again
April 20th, 2015, 12:21 PM | #13 |
you may be able to get away with just unbolting them and sliding them out.
April 21st, 2015, 09:16 AM | #14 |
MOTM - Oct '15
It will be easier on you if you remove the fairings.
Thanks to @LittleRedNinjette for turning my jibberish into english.
April 21st, 2015, 09:18 AM | #15 |
always happy to help.
April 29th, 2015, 08:56 PM | #16 |
A friend of mines finally had some time to help me. Would never trust myself doing this but it finally looks even! Thanks for the help!
April 30th, 2015, 05:59 AM | #17 | |
Looks good!
08-12 Shogun Frame sliders | cuong-nutz | Motorcycle-related | 0 | May 1st, 2013 06:39 AM |
Shogun no-cut sliders for 08-12 NEVER INSTALLED | adouglas | Motorcycle-related | 2 | April 2nd, 2013 04:22 AM |
Shogun Frame Sliders | geeker | 2013 - 2017 Ninja 300 Farkles | 6 | January 17th, 2013 07:01 PM |
Which Shogun Frame Sliders? | solo440 | 2008 - 2012 Ninja 250R Farkles | 7 | July 15th, 2011 05:13 AM |
*LIKE NEW* Shogun Frame Sliders | 00v_Lucky | Motorcycle-related | 11 | July 2nd, 2010 04:35 AM |
