Old May 18th, 2013, 02:07 PM   #1
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
The Ninja 300 is a Terrible Beginner Bike
Man this thing sucks for beginners. Its so much less noob friendly than the 250. Where to start... Well I have this video from my gf's first ride and she was having a hell of a time with it.
Ok so, this bike is very finicky with staying on. Half the time when coming to a stop it will just die as evidenced by this video. You might think its operator error but it happens when I ride it too. My gf does nooby shifts which doesn't help the problem but I don't want to tell her to do other things because it will probably be too much for a noob to concentrate on. For example if you pull the clutch but stay on the throttle and let it down easy while stopping then it won't die but thats just asking her to do too many things at once right now.
So to try and correct it I jacked the idle way the **** up and that helped a little though it still happens.
Then there is that ****** ass on/off engine. This is the exact problem that I HATED on the ninja 650 though it is less prevalent on the 300. At lower speeds its very hard to find that coasting amount of throttle. You're either accelerating or decelerating and when you make that switch the bike will jerk you. Carbs are so much more noob friendly in that respect though some decent fuel mapping would solve the 300s issue. Its so annoying I'm half considering a power commander even though I bought this bike with the intention of leaving it as stock as possible.
Then theres the brakes, those are pretty nooby friendly, ****ing impossible to lock up
So I told my gf to ride my 250 instead since its so much easier to control. She was hesitant because she knows how much time effort and $$$$ I've put into it and she doesn't want to crash it or mess it up. But I told her to learn on this one and then she can go back to riding Persimmon (thats what she named my 300.....) when she is more comfortable controlling it.
So the Ninja 300 still sucks and is going to fail and here's a vid of my gf's first ride
Video should finish 2 hours from this post
AFM #676
Supersports are for n00bs
Old May 18th, 2013, 02:13 PM   #2
lgk
what gear and rpm are you at when you're trying to coast?
Old May 18th, 2013, 03:13 PM   #3
Brother Michigan
Motorcycle(s): 2013 Ninja 300
The 300 is pretty finicky in first gear (because it's so darn short), but every other gear is smooth as butter in my book.
Old May 18th, 2013, 04:00 PM   #4
old3
Motorcycle(s): Ninja 300, KTM EXC610SMR
Raise the gearing +1 CS, IDK what they were thinking on those final drive ratios. It relieves some of the snatchiness. You will learn to ride around it in long turns, it thankfully is pretty easy to get past but is there. The tight engagement point of the clutch counters the super easy pull IMO. Again, a mystery why they did that too.
Sounds like you got one of the stallers. No cure has been found as of yet, but a tuner wouldn't hurt it. Mine stalled a couple times early on, never again since Area P tune went in its gut.
old3 is offline   Reply With Quote
Old May 18th, 2013, 04:01 PM   #5
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Me thinks your GF's natural skills are simply to much for the stock 300 and she simply needs raw untamed power of the jiggles special edition 250. It sounds like the 636 would be a much better bike for her to learn on IMO.
Old May 18th, 2013, 04:30 PM   #6
Joshorilla
Bass Master General
Joshorilla's Avatar
With the on/off jerkyness, the FI 250 is very much like this also, it also dies on decelleration, or at least drops down to about 1k rpm.
I believe the FI systems are near identicle, at least the bazzaz system works for both the 250 / 300 with the same everything, bar maps and O2 sensor.
So it may be worth getting a bazzaz, they seem to be cheaper than PC's and they get better reviews from what I see.
Old May 18th, 2013, 04:45 PM   #7
Tigerpaw
You have a lemon. Take it to the shop.
My 300 never stalls(idle was set to spec). Is not jerky(outside of the super low first gear.
CHEERS!!!
Old May 18th, 2013, 05:04 PM   #8
allanoue
allanoue's Avatar
MOTM - Sep '14
my unmodified 300 never stalls maybe downshift sooner and push the slipper clutch some
Old May 18th, 2013, 06:19 PM   #9
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I can ride it and make or so it doesn't stall but she doesn't have that level of skill yet. Her shifting process is let the friction zone on the clutch handle it.
AFM #676
Old May 18th, 2013, 06:27 PM   #10
Gratz on her first ride!
Old May 18th, 2013, 06:31 PM   #11
JohnnyBravo
JohnnyBravo's Avatar
You got to have a lemon... Mines great
Old May 18th, 2013, 08:13 PM   #12
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I think you're just doing it wrong
AFM #676
Old May 18th, 2013, 08:32 PM   #13
xSean13
xSean13's Avatar
Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR
Get an R6
xSean13 is offline   Reply With Quote
Old May 18th, 2013, 08:35 PM   #14
HKr1
IC2(SW)
HKr1's Avatar
Whats all the clunking noise coming to a stop??
Old May 18th, 2013, 09:41 PM   #15
Jono
Jono's Avatar
Hurry up and total that bike on the track!!
Old May 18th, 2013, 10:50 PM   #16
Byakkotai
Byakkotai's Avatar
Motorcycle(s): 2013 White Ninja 300
She handled the stalls really well (especially in traffic) imo. Did the dealer check out the bike yet?
Byakkotai is offline   Reply With Quote
Old May 18th, 2013, 11:09 PM   #17
Coolbpf
Limp Noodle
Coolbpf's Avatar
Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy
I think jiggles is just a troll.
Coolbpf is offline   Reply With Quote
Old May 19th, 2013, 05:07 AM   #18
allanoue
allanoue's Avatar
MOTM - Sep '14
I think jiggles gf is learning how to stop properly and the 300 will not let her develop a bad habit.
Old May 19th, 2013, 06:57 AM   #19
Joshorilla
Bass Master General
Joshorilla's Avatar
I agree, Jiggles should get a working GF.
Also, you do something that really bugs me with where you walk the bike while slowing down, some people do it because they like it, some people aren't confident riding slowly (past stop signs! ) you would fail your test for doing that here! (Both walking the bike and doing a rolling stop)
But seriosuly, just get her to pull in the clutch on the 300 sooner, that stops the bike from dying, I noticed on the 250 that if I decelled to a speed I would be comfortable riding at low rpm's the bike would drop revs and die, the fix is to just pull the clutch sooner and give a little throttle.
Old May 19th, 2013, 09:53 AM   #20
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Haven't taken it down yet, probably will after my next trackday
I will mouth rape you
What do you mean?
I do or she does? When in the video? When I was turning around in gravel?
Also the problem seems to be that when the throttle is closed and in gear there is no fuel going to the engine then the clutch is pulled and the engine dies rapidly and isn't able to catch up when it hits idle. If you rev it with the clutch in or in neutral it won't die.
AFM #676
Old May 19th, 2013, 10:15 AM   #21
Joshorilla
Bass Master General
Joshorilla's Avatar
Should have made it more clear, she does it about 40 seconds in, you mention gravel, I always "walk" the bike through gravel, that's the only exception and a wise move, kick out the outriggers and if she (the bike) slips you have a chance of saving it or stepping off.
Old May 19th, 2013, 11:07 AM   #22
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yea I've noticed she leaves her legs down for too long too. It's a confidence thing with her. It's best not to have a noob think about too many things at once so I'll let it slide until she gets some more experience
AFM #676
Old May 19th, 2013, 03:27 PM   #23
JohnnyBravo
What am I doing wrong, besides having no problem with my 300? Seems to me I'm doing something right... Perfect bike for this beginner!
Old May 19th, 2013, 06:12 PM   #24
allanoue
allanoue's Avatar
MOTM - Sep '14
What do you mean?
idk it just sounded to me like she was in too low of a gear, like it was lugging way before she was going to stop then you would caption it shut. It sounds like there is a flaw in the programming in the FI but I am sure I have the same flaw but I do not notice it because I stay in gear all the way to first gear than clutch in.
Now I know I could likely be wrong but that is my
Old May 19th, 2013, 06:26 PM   #25
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Well she doesn't blip and downshift, she's too much of a noob
AFM #676
Old May 19th, 2013, 06:32 PM   #26
allanoue
allanoue's Avatar
MOTM - Sep '14
skip the blip the slipper clutch will cover her
Old May 19th, 2013, 06:32 PM   #27
Jiggles
Jiggles's Avatar
MOTM - Apr '13
That's what she does
AFM #676
Old May 19th, 2013, 06:33 PM   #28
allanoue
allanoue's Avatar
MOTM - Sep '14
ya but don't skip the down shift
Old May 19th, 2013, 08:55 PM   #29
Daks
Jersey Devil
Daks's Avatar
Motorcycle(s): '06 Ninja 250
Good. People will buy them, sell them and then we can buy them used. B)
Daks is offline   Reply With Quote
Old May 20th, 2013, 07:44 AM   #30
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
That's gotta be disappointing. Trade it in for a 500!
Mods: 636 front suspension conversion, wc clip ons, bohemian rear sets, FP jets, k&n filter, and AP full race exhaust
gt_turbo is offline   Reply With Quote
Old May 20th, 2013, 08:29 AM   #31
iceknyght
Recalculating. . .
iceknyght's Avatar
Motorcycle(s): '09 250 (sold) '12 Ninja 650
This is what I have been waiting for, but haven't seen many used ones up for sale yet...
jasontracewell.com
iceknyght is offline   Reply With Quote
Old May 20th, 2013, 11:02 AM   #32
Byakkotai
Byakkotai's Avatar
There are a couple on C-list...mostly owners trying to recoup however much they lost at the dealer though
Old May 20th, 2013, 11:27 AM   #33
iceknyght
Recalculating. . .
iceknyght's Avatar
Yeah, I have seen a few of those (I have IFTTT recipes for 650's and 300's), as well as dealer (advertising), but I am assuming it'll be at least another 6 months or so before people start posting them at a reasonable price... Perhaps around the fall...
jasontracewell.com
Old May 20th, 2013, 03:13 PM   #34
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I saw a 300 w/ABS on craigslist for more than what I paid OTD at the dealer and I already thought I paid too much. These sellers are out of their mind.
Old May 20th, 2013, 03:25 PM   #35
CycleCam303
King Hamfist
CycleCam303's Avatar
Yes but people must be paying those ridiculous prices. I'm no better I paid 4 grand for an 09... 8 months ago...
Old May 20th, 2013, 03:38 PM   #36
iceknyght
Recalculating. . .
iceknyght's Avatar
Damn, I could have sold you my '09 for $4k 8 or 9 months ago?!
jasontracewell.com
Old May 20th, 2013, 04:01 PM   #37
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
where were you when I sold mine 2 years ago.... lol
Old May 20th, 2013, 04:18 PM   #38
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I bought my 2011 for 4k 9 months ago.
But mine was completely stock and therefore worth it
AFM #676
Old May 20th, 2013, 04:44 PM   #39
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
tons of 300's for sale here in D/M/V area all the same story. "bought this bike x months ago, upgrading to bigger bike..." All mostly listed at $4200-$5000 1500-3k miles on them.
I hate selling stuff, i will never sell my 250 regardless of getting another bike...or several bikes. 1st i would take to big of a hit money wise for what i did to it, and 2nd i'm a hoarder and all my toys mean far much to me to ever get rid of
Old May 20th, 2013, 05:00 PM   #40
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
I think every one who is so in love with the 300. And won't admit to its down falls is the fact they along with the rest of the 300 owners got riped off like the rest of us.
H2R - beginner bike Kokosun General Motorcycling Discussion 40 October 2nd, 2014 10:18 PM
TERRIBLE THROTTLE FROM 1,500-6,300 RPM help!!! caliking 2008 - 2012 Ninja 250R Tech Talk 10 May 8th, 2014 01:57 PM
Best 1000cc Beginner Bike? :P krolinked General Motorcycling Discussion 158 October 24th, 2012 06:42 PM
Is 300 still a great beginner bike? kcaja1 General Motorcycling Discussion 23 October 9th, 2012 05:58 PM
Is the ninja 250r the ultimate beginner bike, or should I settle for something else? Mulholland General Motorcycling Discussion 188 April 15th, 2012 09:28 PM
