December 1st, 2018, 03:53 PM | #1 |
2010 Ninja 250 not starting
I've looked around and googled, most people with this issue are able to hear some noise when trying to start the bike. The lights turn on (gas etc) when I turn the key to the on position but absolutely nothing happens when I push the start button, bike is in neutral kick stand is up. The bike has been sitting in the garage for a couple months & want to see if I can resolve the issue before taking it to a shop. Advice is appreciated thank you.
December 1st, 2018, 04:16 PM | #2 |
Do the lights stay on while you're trying to start it?
Could an interlock switch be doing this? Be sure that if the side stand it down, you're in neutral. Be sure the kill switch is turned to the run position. I can't remember when the clutch lever has to be pulled, but try pulling that too. Welcome to the board! |
December 2nd, 2018, 07:41 AM | #3 |
Test the battery voltage before starting and during cranking.
It should be over 12.7 before and no lower than 10V when you hit the button. Most likely the battery, battery connections, or fuse. More ideas - https://faq.ninja250.org/wiki/Troubleshooting |
December 2nd, 2018, 11:11 AM | #4 |
Thank you. I don't have a tool to measure the voltage but I do have a portable jumper so I will try and jump the battery and see if that fixes the issue.
December 2nd, 2018, 11:13 AM | #5 |
Thank you! Tried with the stand down and up, always while in neutral, going to start with trying to jump the battery hopefully it's something simple.
December 2nd, 2018, 04:29 PM | #6 |
Really need a multimeter to test interlock switches: clutch, kickstand, neutral.
A lot of times, switches "look" fine, but are electronically defective. Only way to confirm is by measuring them. I'm in East Bay and work in San Rafael if you're nearby, I can come over on lunch break or something and take a look. |
December 3rd, 2018, 06:43 AM | #7 | |
You didn't say if the lights that come on when you turn on the ignition switch remain on when you hit the start button. |
December 3rd, 2018, 05:14 PM | #8 |
Unless battery is completely, terminally dead with super-low voltage, you should still have solenoid >click< and some cranking action, albeit slowly, if all interloc switches are working. If battery's too low to spin starter & engine, you'll get clackity noises from solenoid. Need to measure battery voltage before and during starting.
I bet this is issue with interlock switches. Take a look at these threads, it can become very lengthy process without testing properly: https://www.ninjette.org/forums/showthread.php?t=312718 https://www.ninjette.org/forums/showthread.php?t=318707 |
December 3rd, 2018, 05:26 PM | #9 |
Let's find out at least an approximate battery voltage when he tries to crank, before we get him going with more complicated troubleshooting.
I'm still waiting to hear if the lights that come on when he turns the key go back off when he hits the start button. |
December 3rd, 2018, 05:36 PM | #10 |
yeah, get one of these to measure battery voltage:
https://www.harborfreight.com/7-func...ter-63759.html coupons to get it for free! http://www.hfqpdb.com/browse Also some alligator clips to free up your hands: https://www.harborfreight.com/18-inc...ads-66717.html Video on how to measure voltage:
December 4th, 2018, 11:34 AM | #11 | |
December 4th, 2018, 11:35 AM | #12 | |
December 4th, 2018, 11:37 AM | #13 | |
December 4th, 2018, 11:39 AM | #14 | |
December 4th, 2018, 11:46 AM | #15 | |
Check the oil level and always keep a close eye on it as the little Ninjas will use some. Run Shell Rotella T6 5W-40 or a 40-grade cycle specific oil, preferably synthetic. Here's some maintenance info - https://faq.ninja250.org/wiki/Ninja250_Howto Use 87 octane Regular, no benefit from increased octane with the Ninja. |
December 5th, 2018, 04:19 PM | #16 | |
Appreciate it! That really helped me when I was changing the oil! |
2010 Ninja Not Starting | Xata27 | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 18th, 2015 06:05 AM |
Starting issues, Ninja 2010 won't crank | BlueDragon | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 12th, 2015 02:49 PM |
ninja 250 starting issue | ninjawing | 2008 - 2012 Ninja 250R Tech Talk | 21 | October 1st, 2013 10:33 AM |
06 Ninja 250- Starting Issues. Need help | hazelberg | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 1st, 2012 08:57 AM |
2007 250 Ninja Not Starting | FrankChen07 | 1986 - 2007 Ninja 250R Tech Talk | 2 | October 24th, 2011 09:46 PM |
