March 14th, 2013, 11:19 AM | #1 |
swell dude extraordinaire
Join Date: May 2011 Motorcycle(s): '13 Ninja 300 (white, streetbike), '08 Ninja 250R (yellow, racebike), '97 Yamaha TZ125 4JT Posts: 14
New Ninja 300 and max cs sprocket enquiry
hello everyone,
I'm the new owner of a new white Ninja 300! It will keep my 250R racebike company in the carport ;-) and I actually traded my 2010 R1 for it. Have got a list of obligatory upgrades to work on while (patiently) breaking the motor in but updating the final drive ratio is a priority... apparently it is very popular to do so! And having searched the threads, I've not found an answer to a simple enquiry: What is the largest countershaft sprocket that will fit in the Ninja 300? I know that a 15T works but will a 16T or even 17T fit? While I realize that's a major increase in final drive ratio, I'd like to point out that I weigh less than 42 kg (about 95 lbs.) and bumping the ratio on my 250R over 15% worked fine when it was a streetbike. many thanks in advance! Robert |
March 14th, 2013, 11:38 AM | #2 |
No clue about your sprock question but 95lbs!!!! Wow! You're like jokey sized.
March 14th, 2013, 12:09 PM | #3 |
March 14th, 2013, 12:41 PM | #4 |
Another member here (I forget who... ) went 15/39 on his 300 and said it still felt fine.
Correct me if I'm wrong here, but I believe the speedo on the 300 is not based on the front wheel speed like on the 250R. Members have reported that doing 15/42 on the 300 makes their speedometer nearly perfect. Going with taller gearing would make your speedo read low. I'd rather have it read high than low. |
March 14th, 2013, 01:11 PM | #5 | |
I realize that the speedo reading will be affected but I'll be fine once I've compared it to a known-accurate source. Still would like to know whether a 16T will fit though... many thanks! |
March 14th, 2013, 01:17 PM | #6 |
/moved to 300 tech area
March 14th, 2013, 02:15 PM | #7 | |
Join Date: Jan 2013 Motorcycle(s): Ninja 300R Posts: 181
March 14th, 2013, 05:21 PM | #8 |
Join Date: Oct 2012 Motorcycle(s): White 2013 Ninja 300(Storm), Silver 2003 Fjr1300 Posts: 173
I'm 5' 7'' and weigh between 95-100 and 15/42 work perfectly for me. P.S. unlike most with the 15 tooth mine is +2 instead of dead on.
ATGATT For all I know, women who ride motorcycles are all man-hating dominatrix's. It was like a mild panic attack! |
March 14th, 2013, 05:30 PM | #9 |
what is the stock rear one? 42?
March 16th, 2013, 03:32 AM | #10 |
MOTM - Sep '14
You need to update your profile
March 16th, 2013, 04:26 AM | #11 |
March 29th, 2013, 02:00 PM | #12 |
hello again,
Just an update on the Ninja 300 countershaft sprocket size issue: A 16T will not fit. I'm running the 15T without the sprocket cover as I still have to cut it so the reversed clevis will clear (I'm doing GP shift). I'm still breaking in the bike and have got 75 miles to go 15/38 is +18% and still pulls fine from first gear, at least with a 100 lbs. rider. The chain is short enough that this works though the adjusters are less than 3 notches from the back of the swingarm. Will offer another report once I can wind it out past 6 krpm... Robert |
April 10th, 2013, 04:59 AM | #13 |
I'm planning on buying a 15t sprocket, can anyone confirm what pitch I would need for my stock chain?
April 18th, 2013, 02:58 PM | #14 |
hello everyone,
Final update and report: 15/38 works great, at least for a 100 lbs. rider ;-) Top speed is still achieved in fifth gear (which is the same as sixth with a normal final drive ratio) because of the power deficit but highway cruising is far more comfortable at +18%. I used a product (`Speedo Healer') to correct the speed sensor signal from the countershaft sprocket to compensate for the revised final drive ratio. It isn't inexpensive (~130 USD w/ cable) but is certainly convenient. @psych0hans - our bikes use a standard 520 chain which has a 5/8" pitch. -Robert |
September 28th, 2013, 07:17 AM | #15 | |
Join Date: Sep 2013 Motorcycle(s): ninja 300 ABS 2013 v-strom 650 Se ABS 2010 Posts: 5
