Old September 13th, 2023, 06:10 PM   #1
Nkf
Motorcycle(s): 2008 ninja 250
Unhappy No start/pet valve issue?
So I bought the bike a few years ago not running and I ended up now putting it back together recently and it will not run. It cranks and tries to start but to no avail doesn’t run. I sent the carb off to get ultrasonic cleaned and I believe tuned to run by ducatiman as many people spoke up for his work. I am familiar with working on efi motors but not familiar with carburetors. I think I’m at a vacuum issue so I’m not sure if the vacuum side of the petcock has gone bad and should buy a rebuild kit for the pet valve/a new one, or if the problem is the vacuum valve for the entire system. I have tested the petcock and tried to apply vacuum to the valve but I don’t think valve is working as there is no air flow coming through the valve or does that mean the valve is good? I have spark, the bike doesn’t not slow crank(new battery), the air filter is not clogged, I can see some smoke coming out of the tailpipe and it does puff like there is compression so I believe it’s down to the fuel system. I currently only have about a half gallon of gas in the tank in case I need to pull the tank off. Any suggestions? The bike has only 1400 miles and I don’t think there is anything mechanically wrong with it. The title says it’s a 2007 250 but I believe it maybe a newer generation of the 2008. Any help is appreciated
Nkf is offline   Reply With Quote
Old September 13th, 2023, 06:27 PM   #2
petcock flow test....pull both the fuel line and the vacuum line at the carb...apply vacuum to the vac line and fuel should flow. Rather than sucking on the vac line, I prefer to use a medical syringe.
If no flow...remove it, send it to me, i stock all rebuild parts needed. Cost will be about 1/2 of what a new one would.
Old September 13th, 2023, 08:19 PM   #3
Petcock diaphragm is dead-end passage, so there should be zero flow. That's how vacuum is generated and difference in pressure between vacuum and atmospheric is how it moves plunger to unblock flow. Yes, sucking on vacuum hose can be dangerous if there's crack in diaphragm.
Do petcock flow test. This is from Honda manual. Kawi in RES still needs vacuum to flow. How much petrol do you collect in 10-sec?
Can also bypass petcock completely to rule out or pinpoint it as problem. Use squirt bottle to spray 2-3cc petrol into airbox. Wait 15s for it to vapourise, then start engine. Does it run?
Valve adjustment issue??? VaFish 1986 - 2007 Ninja 250R Tech Talk 11 December 9th, 2016 03:30 PM
gas tank pet cock issue!! help! ac9im11 2008 - 2012 Ninja 250R Tech Talk 8 May 14th, 2014 08:41 AM
Possible Valve or Carb Issue? schmdty420 1986 - 2007 Ninja 250R Tech Talk 25 June 20th, 2012 09:12 AM
Valve adjustment Issue cgborders 1986 - 2007 Ninja 250R Tech Talk 7 February 14th, 2012 07:34 PM
Valve issue SpYd3r05 1986 - 2007 Ninja 250R Tech Talk 18 August 12th, 2010 04:27 PM
