December 20th, 2012, 12:04 AM | #1 |
tires for track days
I am wanting to look at using some slicks at the track next summer, but i have not had much luck finding any, are the guys that race here using slick or are you just using supersport tires.
December 20th, 2012, 12:50 AM | #2 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
Bridgestone 125GP slicks. The front is a 90 and the rear is a 120
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
December 20th, 2012, 09:07 AM | #3 |
MOTM - Mar '13, Jun '14
For which bike?
December 21st, 2012, 02:27 PM | #5 |
Join Date: Sep 2012 Motorcycle(s): Daytona 675 Posts: 123
December 21st, 2012, 03:04 PM | #6 |
December 21st, 2012, 03:35 PM | #7 |
The only other race compound tires I know about are Dunlop Unbeatens and MIchelin Power Cups...they are DOT race tires
Pirelli trackside vendors offer a setup for the 250 where it's a Diablo Rosso II rear tire with a Diablo Supercorsa SP front tire.
December 24th, 2012, 07:55 AM | #8 |
Join Date: Oct 2012 Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F Posts: 96
I've been running the bridgestone bt003rs. They are a good sticky track day tire and are available in the correct sizes. Most of the ninja 250 racers in cmra use the same rear tire and a race version front tire.
December 26th, 2012, 08:53 AM | #9 |
Fighting Texas Aggie '08
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250r (Race), 2005 Kawasaki Ninja ZX-6R 636 (Track), 2005 Ducati Monster 620 (Street) Posts: 541
I will be using exactly what rc racer suggested, this year. Its a 120 BT003R 'soft' front and the 140 BT003RS rear. Its basically the best "race" set up you can get for Bridgestones. I have also considered the Pirelli set up above, but the guys around Texas all use the Bridgestones.
December 26th, 2012, 09:01 AM | #10 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
Love my 003's but they lack feel if anything, but confidence plus. Beware they take a bit to warm up (like any tyre) and the feel changes, soon as they are ready you can belt the fcuk out of em. One day I'll try Pirellis but hard to change from what I know. |
December 26th, 2012, 11:39 AM | #11 | |
December 26th, 2012, 12:27 PM | #12 |
My cynical hat is on, sorry....
Why are you wanting to run slicks? Because someone else said so? Does your pace warrant such tires? Why overbuy on tires if you don't need to. Don't let tires mask technique, you can go plenty fast on lesser priced tires. Buy tires based your pace, track conditions, weather and so on. Save the paper for more track time. See what I mean? If you wanna just try em out, buy a set of takeoffs with some life left and see if they are right for you. Otherwise send your extra $$ to my paypal lol. [takes cynical hat off/] Enjoy the slicks yo, go fast and take chances.
December 26th, 2012, 06:17 PM | #13 | ||||
If it were me I would be fine running the BT003RS tires but if money were no object I would easily go with the slicks. Quote:
It's actually easy to change. Just try something new and see if you like it...if you don't, sell them on here. If you like them, rock on. Ive done several detailed tire reviews for the D675 forum (Dunlop Q2s, Pirelli Diablo Superbike Slick Pros, and Michelin Power Cups) Quote:
There is something about confidence when it comes to riding so if buying the best tires gives you the confidence then do it. However it took a lot of track time and actually running tires past wear bars to find out characteristics of tires and how they behave. I have done trackdays with nothing but Dunlop Q2s running pretty decent paces. I would like to get an extra set of wheels to run for trackdays with tires like Pirelli Diablo Rosso IIs, Pirelli Sport Demons, Bridgestone BT003RS and then have the GP125 slicks as my race tires.
December 26th, 2012, 07:44 PM | #14 |
that is why i am asking questions, the guys that run the track day suggested that i get some stickier tires on the 250, I only run about 4 seconds slower then the fastest guys at about 1'44" lap pace. figured i would ask the 250 forum to see what tires they are running.
December 26th, 2012, 08:30 PM | #15 |
Fast-Guy wannabe
MOTM - Jan '13
Slicks are overrated I prefer skinless
December 28th, 2012, 03:07 PM | #17 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
bridgestone
http://www.eurotred.com.au/tyres_2011/index.html pirelli http://www.pirelli.com/tyre/ww/en/mo...?subtype=track michelin http://motorcycle.michelin.com.au/tw...roductList/1/2 dunlop http://www.dunloptyres.com.au/dotAss...faf04a599d.pdf i like dunlops. also google how many heat cycles tyres last. |
January 5th, 2013, 07:18 AM | #18 |
CVMA / AFM / M1GP #250
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650 Posts: A lot.
Downside to slicks... they'll MAYBE last you two days at the track. My Pirelli rear slick is nearly done after just one track day at Buttonwillow. But OH the poaching in B group was glorious!
I'll be going back to the Diablo Rosso 2 rear tire and probably stay with the Moto3 slick front tire. I think that may be the killer combo |
January 5th, 2013, 07:47 AM | #19 |
Join Date: Feb 2011 Motorcycle(s): Green 2013 ZX-6R Posts: 723
I've been racing on Pirelli SuperCorsa's in a 120 front and 150 rear combo. I have a couple sets of take-off's for $150 if you want to give a set a try before you buy new tires.
http://www.simplysurrealphotography....es/peanut2.png |
January 7th, 2013, 06:12 PM | #20 | |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
January 14th, 2013, 05:58 PM | #21 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
I really like my 003s. They are sticky as hell on the edges!
I don't run warmers though, so it takes a couple of good laps to heat them up.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
January 24th, 2013, 02:27 AM | #22 | |
Join Date: Sep 2012 Motorcycle(s): ex500 ex250 Posts: 56
(I have a nice tall pile of slicks sitting in my bed room they're 125/600 17" Bridgestones Race Slicks (used in everything from motogp to ama, to supermoto) The Big thing about slicks is, are you going to be able to keep them warm enough to consistantly grip? I don't even hear of the gents in the ccs 250 cup using slicks Then what happens on days when it rains at the track? Your definitely not gonna get any grip, atleast with the bt003's you'll still get good wet traction (i did a wet run through deal gap on 003's kept my ass planted and i flew on there) The place where slicks would really benefit you over dual compound tires like the bt-45 or 003 is if you were on a 600+cc machine where it's got enough power to break free n spin the tire while in motion. You'd atleast havea tire that instead of spinning it'll take that forces turn it into heat and inturn grip for when the tire tries to spins out on you. But i'm still curious as to how they give no feedback? You can feel what they tire does as you ride, the pic that was posted looks like it was done at a track day. Owner left the air pressure what it was factory, didn't let any air out to compensate for the raised pressure caused by the heat generated by the tires. It also looks like the forks need some damping help but that's another story and thats just from reading the tire from a pic. |
January 24th, 2013, 07:48 AM | #23 | |
So far, all the top runners at CVMA are running either bridgestone or pirelli slicks, since it is a desert track rain isnt an issue, and even on cold weekends like this past one, getting heat into them isnt a problem even without warmers. In the past I've run the 100 front slick 125 rear, 110 supercorsa with 140 rosso 2 rear, 120 supercorsa front with 150 supercorsa rear, 110 michelin front with 150 rear, 110 bridgestone BT003 with 140 rear. The tire size is probably the most negligible part of what makes these bikes handle. The tire compound and getting heat into them is much more important. |
January 24th, 2013, 08:23 AM | #24 | |
Fast-Guy wannabe
MOTM - Jan '13
You can fudge the rear tire a bit because traction back there isn't a problem on the 250. But every rider is going to have a front tire with compound, carcass, and profile that they prefer. |
January 24th, 2013, 09:29 AM | #25 | |
When you comin back?? |
January 24th, 2013, 09:42 AM | #26 |
Spoken like a true yami rider.
January 24th, 2013, 10:16 AM | #27 | |
CVMA #74 WSMC #750
Also, as you noticed Rexy....I kept swinging out wide in the bowl...I couldn't hold my line - bike kept wanting to swing out wide.
January 24th, 2013, 02:26 PM | #28 | |
Also you guys need to learn corner entry trail braking. **** is crazy. |
January 24th, 2013, 02:45 PM | #29 | |
CVMA #74 WSMC #750
I know. I raised the forks (flushed) and raised the rear quit a bit. Never dragged exhaust and that's what I wanted but at the same time it kept running me wide. 2:02s...not a problem. Felt like I could have done 2:00s no problem too but not when it kept drifting me wide. I may just go back to where it was before and bend the exhaust pipe so I don't drag anymore. Looking forward to next round.
[roadracingworld.com] - SoCal Track Days Issues Revised 2015 Track Day Schedule | Ninjette Newsbot | Motorcycling News | 0 | December 30th, 2014 12:00 PM |
[roadracingworld.com] - N2 Track Days Takes Over NESBA Track Event Operations | Ninjette Newsbot | Motorcycling News | 0 | March 26th, 2014 12:50 PM |
[roadracingworld.com] - Sportbike Track Girl Schedules Track Days For Women Only, At | Ninjette Newsbot | Motorcycling News | 0 | April 23rd, 2012 04:20 PM |
[roadracingworld.com] - Racers Edge Performance Track Days/Practice Days Now Open To | Ninjette Newsbot | Motorcycling News | 0 | March 25th, 2011 10:50 AM |
[roadracingworld.com] - Sportbike Track Time Hosting Track Days At Barber Motorsports | Ninjette Newsbot | Motorcycling News | 0 | August 1st, 2010 11:20 PM |
