February 18th, 2012, 11:53 AM | #761 |
Alright it started up fine this morning. Took a couple starts but it seems fairly stable.
@n4mwd Quicksteel says it's gasoline resistant. One of the uses they described is to plug up leaks in a gas tank. I made the tube about a foot long and sloped straight up and then bends around. Lets see if this helps/solves the issue. I also have the MAP sensor coming from the top of the TB so there really shouldnt be much flowing up that tube. I think if the MAP tube diameter was larger, that might solve it as well.
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
February 18th, 2012, 06:05 PM | #762 |
Join Date: Oct 2011 Motorcycle(s): 1983 Suzuki GR650 Tempter, 2010 Ninja 250r Special Edition Posts: 17
Doe anyone know the performance gains? Any dyno results available?
February 18th, 2012, 06:18 PM | #763 | |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
February 19th, 2012, 02:08 AM | #764 | |
There has to be a way. I thought about adding an inline filter but I think that would change the pressure responses.
February 19th, 2012, 02:09 AM | #765 |
I'm not sure about a dyno but overall I would estimate that it's very similar to a well tuned carb.
February 19th, 2012, 06:16 AM | #766 |
MAP sensor work around
I didn't realize this until you guys started complaining about it, but the ecotrons TB has the injector recessed too far behind the MAP sensor vacuum port. This is why you are having problems. If you look at the OEM TB you can see that the vacuum port is even with the injector nozzle and on the opposite side. The ecotrons port is right next to the hole for the injector.
Here is a possible workaround for the MAP sensor filling with gas problem. If you take a small jar and JB-weld two ports to it (short piece of copper tubing or fish tank air couplers), the MAP sensor will be protected from gas entering the vacuum port. The only problem is that you will need to empty the container into the tank when it gets full. Also, the orientation is critical. I'm not sure how this would affect the sensor's operation, but it will stop the gas from getting in for sure. Filling the voids in the injector tube with quicksteel so that there is just a simple straight tube to the bore might help, but because of the proximity to the vacuum port, I don't think this problem will ever go away completely.
February 21st, 2012, 11:02 AM | #767 |
Replacement Rubber intake bushings
Does anybody know the status of our replacement rubber intake bushings? That is, the gas resistant version of the bicycle inner tube that fits on the TB. Did Matt actually say he was working on them? All I got was an email saying he was replacing the fuel tap because the copper stems were breaking off and squirting gas everywhere. I haven't gotten anything from him regarding the rubber bushings.
February 21st, 2012, 11:05 AM | #768 | |
February 21st, 2012, 11:12 AM | #769 |
ScattCatt discovered this problem when he removed his TB. Pictured below are his originals and the replacements he made himself out of radiator hose.
As far as the Fuel Tap problem, I only heard about that from Matt.
February 21st, 2012, 11:14 AM | #770 |
I asked Matt about the rubber intake boots a week ago and he said they are working on a customized boot that'll fit perfectly on both the engine and throttlebody side. No word on when it will be complete but I wouldnt be surprised if it'll take a few weeks.
As for the copper fuel taps, no idea. I'm not using them since I've got a Cali tank but I've also only heard of one guy that had the issue.
February 21st, 2012, 11:51 AM | #771 | |
And got to remember scattcat is running his bike really rich compaired to most of us so wouldnt be a surprise that he has more gas getting to those boots. Thats why he was getting the popping off throttle boot as well. Cant compair all bc of one. Same for my incident. probably was my fault but i ended up using my CA tank to fix my problems anyways. Anyways. How is everyones kit doing so far? Anyone try the performance switch? I tried yesterday since i been having the ecu learn for a long time now. I really didnt notice too big of a difference. Just up high in the rpms but at idle and such seemed like it was getting too much fuel. maybe 1whp
February 21st, 2012, 11:59 AM | #772 |
Oh haha there you go. Glad you got that fixed. Running the tubing up to the vent port isnt that big of a deal. I have yet to put an air filter on the middle port though. Is that important?
My kit has been running great so far. Only took it out a few times since installing the O2 sensors. I did feel that the O2 sensors smoothed out the engine immediately after installation. I took it out for a ride, installed it, took it out again and the difference at low RPMs was huge. Not so much "more power" but just smoother power. As for the boots issue, I'm not having too much trouble with it but I feel like the throttlebody does shift out over time. I have pod filters so the vibration, I would imagine, can wiggle the TB out of the boots. Maybe I should find a way to support the pod filters themselves. Not sure. Give it a few more rides and I'll report back once again.
February 21st, 2012, 12:03 PM | #773 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
My system is working well. I have had two issues, the MAP sensor died due to fuel ingestion and the supplied petcock broke as somebody else described. Mine was off the bike when I noticed the failure.
The MAP sensor was replaced by Matt. I decided to modify the original pregen petcock so the return line goes to the old vacuum line. This has been working quite well. It did take some time and itterations to get the fuel line routing all squared away, but it is in a good config now. I have 700+ miles since installing the kit. I had a look at the plugs last weekend and they are textbook perfect mixture. I have actually never seen that in person. I also am running pod filters without a problem. I do have the stock pregen carb boots, so that may be the difference. As far as the "rich" setting. I have not tried it. But you can setup the map to whatever you like (rich or lean). If you feel it is too rich on the low side update the desired lambda map to reflect that. |
February 21st, 2012, 12:07 PM | #774 | |
And for the middle port i just vented it and have a hose going to the bottom of the bike. that one is just for water and junk from the cap. the other one is the actual vent i just left that one open.
February 21st, 2012, 12:11 PM | #775 | |
And so did ur Map sensor break when it ingested too much fuel? Mine seems to be working fine after i let it air out. Hope it dont break and i got about 700 miles on mine too now. I need to check my spark plugs and i want to do my valve job too. And for those that are wondering those tusk fuel quick connects really work. makes working on the bike so much better since u can take the tank off without having to drain all the gas
February 21st, 2012, 12:15 PM | #776 |
@flynjay and @EMSRacer07 Great! Glad to see it all working out for you. Also great to hear the pod filters dont seem to shift. Mine havent actually popped out but seeing it wobble up and down in a rhythmic fashion to the engine, I could imagine it slipping out at some point. I wont worry since if after 700+miles nothing happened, I'm sure within that i'd take the bike part again and give it an overall checkup anyway. Just at that to my bimonthly bike check.
Am I the only one with the injectors coming from the top so far?
February 21st, 2012, 12:29 PM | #777 | ||
It has been working well, initially the bubbles didn't flow out very well but I have it so the filter is facing in such a way that if there is any fuel in it it puddles at the outlet side of the filter. The bubbles worked themselves out over about a week. Quote:
February 21st, 2012, 12:38 PM | #778 | |
My MAP sensor took overnight... luckily there wasnt a lot of gas in it. We'll all need to keep an eye on it. I am considering putting a drain or filter inline but that might mess up the vacuum readings.
February 21st, 2012, 01:26 PM | #779 | |
February 21st, 2012, 02:57 PM | #780 |
With all the latest problems with the TB that have surfaced (rotting rubber bushings, TB popping out, fuel in the MAP sensor, etc.) I have decided to abandon the thought of trying to save the ecotrons TB. What I said from the start is that it had to be at least as reliable as the carburetors for me to use it, and while this was promised, the kit has not even come close to the reliability of the carbs based on the facts you guys have reported here.
If I fix the fuel rail, then I would have to drill and tap a new vacuum port. After that, there will be something else. I know you guys have just used the plastic injector housings, but you have fatigued the plastic and/or used low pressure tubing to do it. I have also noticed that one of the electrical connectors for the fuel injectors on my wiring harness is not the right one to fit the injector. Basically, I haven't decided on whether I will be selling the kit to someone who isn't as picky about reliability, or trying to buy an OEM TB and use that. So far, with the exception of the fuel tap, 99% of the kit's problems could be solved with a properly designed TB.
February 21st, 2012, 03:28 PM | #781 |
@n4mwd Correct the TB is the cause of many of the issues but this is to be expected since the TB was not intended for the ninja250 to begin with. It "can" be used to great results but as you said, there are things that could be better.
This whole installation is a learning process for both us and ecotrons and I think they are doing a fantastic job at accommodating our issues and changes. That said, I can see why you might give up on it. If you do decide to continue and have the money, find yourself a UK TB and just be done with it. The ECU works great. I havent spent that much money on the TB as you did so in the future, I may consider getting an OEM TB to complete the kit. @flynjay Not a bad idea and easy too. I'll give that a shot as well.
February 21st, 2012, 05:38 PM | #782 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
Actually @EMSRacer07 I'm really not running as rich as you might think (richer than the stoich AFR, yes, but significantly richer than the stock desired lambda chart, no.) If you highlight all of the cells in the desired lambda table (excluding RPM values and TPS values) the average on the stock table is 0.891115625 where as the table that I'm currently running has an average of 0.884353741. This difference of 0.006761884 is very small, to the point of not even being noticeable. I'm actually considering leaning my table out to have an average of 0.935714286 which would be a 13.1 AFR which may or may not give more power (will require testing) as I'm currently sitting at a 13.0 AFR. Now, the stock desired lamba table has an interesting taper to it, which I suspect is largely due to the fact that richer mixtures help cool an engine but on the negative side, the stock table goes all the way down to .8298 for WOT beyond 3,000 RPM, this gives an AFR of 11.6172 which is very low regarding optimum power (typically). Comparing my chart to the stock chart now, the vast majority of the RPM's used while actually driving in the stock chart are even richer than what I'm running. The main exception are all the "1"s at the top for idle in the stock chart. Just wanted to clear that up in reality, your point still holds about me running richer than you guys simply due to the fact that I'm not using the O2 sensors though, just perhaps not nearly as rich as you may or may not have thought.
ATGATT |
February 21st, 2012, 06:12 PM | #783 | |
February 21st, 2012, 06:55 PM | #784 |
It's a thought I still toy with, but still hesitate on doing what I'm ACTUALLY considering doing is putting wideband sensors in there with a gauge on my dash to just keep track of my AFR without taping into the EFI kit. So a separate system entirely. This will make my desired lambda tuning even more effective as I'll actually be able to SEE AFR's at certain TPS settings and RPM's
ATGATT |
February 21st, 2012, 07:33 PM | #785 | |
I would think that you are running pretty rich since it looks like the base map was pretty rich. When I installed the O2 sensors they were pretty much pegged on the rich side for the first few rides. You already have the narrow band sensors. You would have to tap the exhaust to put in the wide band o2 sensor anyway. |
February 21st, 2012, 08:41 PM | #786 |
Hey anybody have an idea for a fuel trap in the MAP sensor tubing. I got gas all the way up a foot of tubing. Matt has suggested trying some stiffer tubing but I'd also like to put a trap there as well just in case. This way I can test out a few other methods and not have to wait a day for it to dry.
Sigh, just my luck too. I rode it all the way to school and when I went to start it on my way out, it wouldnt start. Made me sad and late for an exam. Luckily the professor is super cool with me and I was easily able to finish it in under 20minutes. No biggy but it definitely made me nervous for a while. And about the decel fuel cutoff. Can someone post a screenshot of yours and highlight the boxes that I should change if I wanted to use 3000rpms as the cutoff point? I look at the decel window but it's just gibberish to me.
February 21st, 2012, 08:45 PM | #787 | |
February 21st, 2012, 09:00 PM | #788 | |
ATGATT |
February 21st, 2012, 09:07 PM | #789 |
Scattcatt, it sounds like you need some dyno time mate. I think you would really benefit from that. You seem to know what you're doing, but it would do some good to be able to play with a few different maps and see what changes the power where.
February 21st, 2012, 09:11 PM | #790 |
Here's some pics of my new gauge cluster with the 2 air fuel ratio gauges. I like it. Now I just need to reinstall my fuel injection.
I think I'm going to move the main gauge cluster closer to the top. I think it will look better. What does everyone think? |
February 21st, 2012, 09:14 PM | #791 |
What's the point of having 2 AFR gauges? Wouldn't both sides be doing the same thing as long as you programmed the same map into each side? Wouldn't a temp gauge be more useful compared to a second AFR gauge?
February 21st, 2012, 09:15 PM | #792 |
*sigh* call me crazy... But I think I'm going to save up and get my own dyno... Like $5000 for the one I'm looking at, in reality it's an issue of not wanting to take my bike down and get it dyno'ed by someone else I REALLY do want to get some dyno tests done though, I'm itching for it man.
ATGATT |
February 21st, 2012, 09:18 PM | #793 |
are you totally serious with me right now? that's so cool!
February 21st, 2012, 09:21 PM | #794 | |
I have it mounted from the top and it comes across towards the back of the bike and is zip tied to the frame. I'm going to swing out to the autostore and take a look around real quick. Ideally I want something that can hold some fuel and then let it drain out so that it doesnt need to be emptied but I'm not sure that would be ideal either. I'll work with Matt to figure out a better fix for this. He suggested that there might be some kind of tuning that has allowed too much residual fuel to stay in the throttlebody thus giving it the opportunity to travel up the tubing.
February 21st, 2012, 09:22 PM | #795 |
The gauge has water temp on it also :-)
Two a/f gauges are to show that the 2 cylinders are running the same. Plus all n all it cost me 150 dollars |
February 21st, 2012, 09:27 PM | #796 |
@justinswidebody that's actually pretty freaking sick! I'm totally digging that dash, I may consider something similar if I choose to go the wideband sensor route eventually. and @choneofakind well it's just another thought, I mean, $5000 is a LOT of money for this college kid
ATGATT |
February 21st, 2012, 09:30 PM | #797 |
Oh right. Forgot you were in college also. psssh just get it set up pretty well, get the O2 sensors installed so it can be more exact, and then get it dyno tested to see what she can put out
February 21st, 2012, 09:31 PM | #798 |
If you want me to make you one let me know. :-) I can build more.
February 22nd, 2012, 12:19 AM | #799 | |
Crazy I tell you. So much engineering goes into this and here we are trying to make a DIY makeshift version of something that was so intelligently designed.
February 22nd, 2012, 08:06 AM | #800 | |
That in addition to the fact that the injector is surrounded by open space as you noted. And probably also because Kawi uses better injectors. Another thing I thought of is that its possible that ecotrons is purging the fuel pressure from the fuel rail at shutdown. This would cause the injector to squirt into the TB with no place to go - except into the vacuum port. If the bike runs fine and then wont start after its sits a few minutes, then this could be the culprit.
OEM Fuel Injection Kit and other 250 race mods | Shadowwolf1117 | Motorcycle-related | 0 | April 3rd, 2015 10:51 PM |
Ecotrons EFI (Fuel Injection) kit Group Buy: June 2013 | n4mwd | Motorcycle-related | 94 | October 12th, 2014 08:36 PM |
Ecotrons EFI Group Buy: March 2013 | n4mwd | Motorcycle-related | 124 | May 20th, 2013 10:15 PM |
Ecotrons EFI for ninja 250 (GROUP BUY) | ninja_thresh_hold | Motorcycle-related | 101 | March 4th, 2013 05:45 PM |
DWG Waterproof audio kit group buy. | Buffalony | Motorcycle-related | 0 | March 1st, 2009 11:57 AM |
