Go Back   ninjette.org > Marketplace > Motorcycle-related
Old July 9th, 2012, 10:36 AM   #1
ninja_thresh_hold
ninjette.org *********
ninja_thresh_hold's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r
Talking ecotrons ninja ex250 efi kit group buy!
Hey guys, ive gotten in touch with matt of ecotrons.com, and he said that "another group buy is welcome" the new one will include the new throttlebody, and all of the new additions to the kit. i am still talking to him about the numbers,
pricing:
Same deal: 15% for 3 kits, 20% for 5 kits.
3 kits: 510 usd
5 kits: 480 usd
what all the kit comes with:
new TB
but in the mean time, who all is interested?
LIST:
1.airjeir
2.fizzer914
3.NinjaVanish
4.
5.
Last futzed with by ninja_thresh_hold; August 10th, 2012 at 01:00 PM.
ninja_thresh_hold is offline   Reply With Quote
Old July 10th, 2012, 10:44 AM   #2
Marketplace Forum Rules
Old July 10th, 2012, 11:11 AM   #3
dubojr1
dubojr1's Avatar
Anyone had any issues running this kit and the KOSO gauges? Since this kit takes over the ignition timing will any KOSO wiring need to be changed for everything to function. Tach pick up for example.
Old July 10th, 2012, 11:22 AM   #4
flynjay
flynjay's Avatar
No wiring on the bike is modified during installation of the Ecotrons kit. So, I don't see any reason why it would have any difficulties. I do not have KOSO gauges and don't believe any of the previous group buy does either.
Old July 10th, 2012, 11:25 AM   #5
dubojr1
dubojr1's Avatar
Originally Posted by flynjay View Post
No wiring on the bike is modified. The kit uses the stock pickup. I don't see any reason why it would have any difficulties.
Doesn't the KOSO get the tach signal from the stock ECU? If the EFI kit has it's own ECU and controls the timing, wouldn't the KOSO have to get it from there after the EFI kit has been installed?
Is my thinking wrong here?
Old July 10th, 2012, 11:26 AM   #6
ninja_thresh_hold
they will both work at the same time, i'm getting the rx2 gauge and this kit, and then im going to turbo my bike.
Last futzed with by ninja_thresh_hold; July 10th, 2012 at 07:23 PM.
Old July 10th, 2012, 11:30 AM   #7
dubojr1
dubojr1's Avatar
That doesn't really answer my question either. I already have a KOSO and I'm trying to understand what issues I may run into with an EFI kit. I also have a remote start alarm and I'm also curious if there would be any concerns there.
BTW... forget the turbo. Our engines, transmissions, clutches, etc. are not engineered to handle that kind of HP. Not stock any way...
Old July 10th, 2012, 11:32 AM   #8
dubojr1
dubojr1's Avatar
Apparently you don't understand what Alex did. He was correct in all he did and I don't see any reason for him to delete any technical discussions in here.
Old July 10th, 2012, 11:38 AM   #9
ninja_thresh_hold
alright, well so far as the turbo, i have it all figured out i have forged pistons and everything i need so im goot there, and so far as your question, i don't see any reason why the gauges would interfere with anything, because it doesnt change the bikes wiring, the harness plugs into a plug under the driver seat, and the alarm may or may not interfere, depending on how it wires up. i will ask matt and get back to you as soon as i can
Old July 10th, 2012, 11:39 AM   #10
ninja_thresh_hold
yeah im glad he deleted the other posts, but i dunno
Old July 10th, 2012, 11:42 AM   #11
flynjay
flynjay's Avatar
When you install the KOSO gauges, what do you have to do wiring wise?
Old July 10th, 2012, 11:45 AM   #12
Guys, the rules aren't arbitrary, and aren't random. Marketplace area is for people & companies selling things. The only type of posts that are generally permitted in sales threads are questions from people who are interested in purchasing what is being sold. There is no restriction on tech or non-tech questions, as long as they are related to a potential purchase.
If the discussion runs off a tangent to having nothing to do with the purchase/sale in the original post, it shouldn't be here, and should in fact be done in a separate thread in the tech section or elsewhere on this site.
Old July 10th, 2012, 11:51 AM   #13
dubojr1
dubojr1's Avatar
You have 1 wire to run straight to the battery (for gauge settings memory I believe), 1 wire to run to the coolant temp sensor (KOSO provided but replaces the stock sensor), 1 wire to run to your choice of an oil temp reading location (secondary drain plug in my case), and 1 wire to run for the speed sensor (located on the front wheel) and then the gauge plugs straight into the stock harness behind the dash. It gets everything else it needs from there.
Old July 10th, 2012, 11:51 AM   #14
the kit plugs into the connectors that the stock ecu used. If the koso needs spliced into the same wire that the oem tach gets its signal from, then the koso should, in theory, still work when using the efi kit, because it will just be plugged into the kit ecu rather than the oem cdi. Are we thinking the same thing here or am i just theorizing wildly?
Posted via Mobile Device
Old July 10th, 2012, 11:55 AM   #15
dubojr1
dubojr1's Avatar
So is the EFI ECU a replacement for stock or an addition to stock?
I'm actually running the BRT and it was my understanding that the BRT would be illuminated by the EFI ECU. Is this correct?
Old July 10th, 2012, 12:13 PM   #16
flynjay
flynjay's Avatar
The Ecotrons ECU replaces the stock CDI.
Old July 10th, 2012, 12:14 PM   #17
flynjay
flynjay's Avatar
That's my take on it.
Old July 10th, 2012, 12:17 PM   #18
dubojr1
dubojr1's Avatar
Ok, now that clears it up. My BRT replaced the stock CDI so the EFI ECU would replace my BRT.
BTW...I'm thinking there would be no change needed for alarm function.
Old July 10th, 2012, 02:12 PM   #19
ninja_thresh_hold
"Where does the koso wire (pick up ) tap to stock harness ?
Ignition coil driver wire?
Or stock pick up?
Basically should not have any issue. Because the efi kit do the same ignition control as the stock cdi. Except programmable ignition angles." - matt of ecotrons
Old July 10th, 2012, 02:16 PM   #20
ninja_thresh_hold
so are you interested in the group buy?
Old July 11th, 2012, 12:02 PM   #21
dubojr1
dubojr1's Avatar
I'll be paying attention here and making my mind up. My bike actually runs really good and get's descent mileage. I'm weighing the cost/gains still.
Old July 11th, 2012, 02:51 PM   #22
ninja_thresh_hold
yeah, i gotcha, im not sure if its true but people say you get better gas mileage if you put fuelinjection
Old July 11th, 2012, 04:31 PM   #23
airjeir
Motorcycle(s): 08 250r
new here, joined to get in on this group buy... I'm in for sure, what are the details on paying?
airjeir is offline   Reply With Quote
Old July 11th, 2012, 05:08 PM   #24
pomartin
pomartin's Avatar
Motorcycle(s): 08 Ninja 250R (FI)
sory for off.. i asked this question many times on different forums, but still didnt got the answer.
What is diference between this EFI kit and stock kawasaki EFI kit... if there is any?
@airjeir welcome to the forum
pomartin is offline   Reply With Quote
Old July 11th, 2012, 05:21 PM   #25
lgk
Depends on the tune, and how fast the bike warms up.
The closed loop nature of fuel injection makes sure there is less fuel wasted.
My original reason for installing the kit was the ability to ride off right after starting.
Works like a charm.
Old July 11th, 2012, 05:28 PM   #26
lgk
Standard
The stock kawasaki efi system has an in tank pump and filter.
I think the fuel pressure regulator is at the pump.
There is no return plumbing.
The computer is not programmable.
The ecotrons system has an external pump and filter
Inline pressure regulator and return loop
The computer is programmable for ignition and fuel delivery.
Parts wise it seems the ecotrons kit is easier to repair with off the shelf parts from a cager parts store
Old July 11th, 2012, 05:31 PM   #27
ninja_thresh_hold
Works like a charm.
thanks for the input! so is it true that with fi the ride feels a whole lot better? some ppl compare to a ninja 600
Old July 11th, 2012, 05:38 PM   #28
lgk
The throttle response feels quicker than the carbs.
The power seems smoother too.
Im not sure it compares to a 600 though
Old July 13th, 2012, 12:57 AM   #29
ninja_thresh_hold
alright, so is anyone interested in the group buy? i havnt had anyone sign up yet...
Old July 13th, 2012, 02:19 PM   #30
airjeir
Thumbs up group buy
I'm in if we get it under $500, so put me down
Old July 14th, 2012, 05:41 PM   #31
ninja_thresh_hold
sound good!
1.airjeir
2.
3.
4.
5.
Old July 14th, 2012, 07:55 PM   #32
fizzer914
fizzer914's Avatar
Motorcycle(s): 2010 250 se
im in how much though?
sound good!
1.airjeir
2.fizzer914
3.
4.
5.
fizzer914 is offline   Reply With Quote
Old July 14th, 2012, 07:57 PM   #33
ninja_thresh_hold
as i said in the original post, if we get 3 ppl to purchase a kit, $510 usd.
if we get 5 kits sold, $480 usd
Old July 15th, 2012, 03:26 PM   #34
t-rav_12
Motorcycle(s): '06 Ninja 2-Fitty (DD Commuter); '05 Ninja 2-Fitty (Track CCS#112); '94 YZF 7-FittyR (Missile/Backroad Bomber)
Sorry if I missed this in an earlier post, but I din't see what model yrs this deal is good for... I have an '06 EX2-Fitty and am trying to rally for another Area P exhaust buy as well. ( http://www.ninjette.org/forums/showthread.php?t=71794 )
t-rav_12 is offline   Reply With Quote
Old July 15th, 2012, 04:00 PM   #35
ninja_thresh_hold
the kit is applicable to any pre gens AND new gen ninja ex250r the only difference is the wiring harness's
Old July 15th, 2012, 04:39 PM   #36
t-rav_12
...so that's something I would specify at the point of order?
Old July 15th, 2012, 05:24 PM   #37
lgk
definitely, make sure you get the right kit, otherwise the electrical wont be plug and play.
Old July 22nd, 2012, 08:10 PM   #38
ninja_thresh_hold
cmon we need more ppl in order to get the lower price!
Old July 26th, 2012, 11:04 AM   #39
NinjaVanish
NinjaVanish's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250R
Are the prices shipped prices?
NinjaVanish is offline   Reply With Quote
Old July 26th, 2012, 11:43 PM   #40
EMSRacer07
EMSRacer07's Avatar
yep i think its shipped prices. And i have been using my kit since the first group buy and still loving it and i have the oldest or one of the oldest using the kit so thats saying something too. Guys jump on while its cheaper in the group buy
Ecotrons EFI (Fuel Injection) kit Group Buy: June 2013 n4mwd Motorcycle-related 94 October 12th, 2014 08:36 PM
FS: Ecotrons EFI v2 used on 2009 250 setasai Motorcycle-related 1 September 5th, 2014 01:17 AM
2002 Kawasaki Ninja 250 EFI (EcoTrons) lolibater Motorcycle-related 7 November 5th, 2013 06:27 PM
Ecotrons EFI Group Buy: March 2013 n4mwd Motorcycle-related 124 May 20th, 2013 10:15 PM
Group Buy: EFI (Fuel Injection) Conversion Kit Jiggles Motorcycle-related 874 November 30th, 2012 04:54 AM
