Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old May 16th, 2014, 10:28 AM   #201
diwhiteii
diwhiteii's Avatar
Motorcycle(s): 2009 Ninja 250R, 2013 Ninja 300
Originally Posted by Xtina View Post
Any updates? selling any more carbon....?
I am actually selling more carbon
diwhiteii is offline   Reply With Quote
Old May 16th, 2014, 10:32 AM   #202
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
pm sent
Xtina is offline   Reply With Quote
Old May 16th, 2014, 01:39 PM   #203
Enjoy the pics!
Nice speaker! Does it foam up the fuel when you crank up the bass?
Old May 27th, 2014, 06:07 PM   #204
Did someone steal your photos for this ebay posting? or am I just going crazy? They look like your early-on build pics.
http://www.ebay.com/itm/KAWASAKI-NIN...-/271184834780
Old May 27th, 2014, 06:33 PM   #205
The seller is SSR. He worked with SSR on developing these and obviously promotion was part of the incentive.
Last futzed with by CZroe; June 10th, 2014 at 02:30 PM.
Old May 27th, 2014, 07:01 PM   #206
Oh. Missed that.
Old May 28th, 2014, 02:50 AM   #207
diwhiteii
diwhiteii's Avatar
Nailed it!
Old July 4th, 2014, 10:33 AM   #208
diwhiteii
diwhiteii's Avatar
New Pics
I am almost finished
More pics will follow
Old July 4th, 2014, 07:03 PM   #209
mania
mania's Avatar
Motorcycle(s): 2013 250
Very nice diwhiteii
Really like the Galespeed wheels too
Did you happen to check stock weight vs the weight of this set?
Thanks & good job
mania is offline   Reply With Quote
Old July 4th, 2014, 07:24 PM   #210
diwhiteii
diwhiteii's Avatar
Originally Posted by mania View Post
Very nice diwhiteii
Thanks & good job
The Galespeed wheels are 5lbs less on each wheel.
Old July 4th, 2014, 10:31 PM   #211
mania
mania's Avatar
Wow that is very impressive! Each wheel
Thanks for that info
Old July 5th, 2014, 11:02 AM   #212
diwhiteii
diwhiteii's Avatar
Updated Mod List!
Body enhancements:
Fiberglass Front 636 Center Cowl with Windscreen
SSR Carbon Fiber Center Headlight Cowl (removed, now need to list on the forum)
SSR Carbon Fiber Belly Pan (removing, now need to list on the forum)
SSR Rear Hugger SSR (removing, now need to list on the forum)
SSR Carbon Fiber Front Fender
A-tech Carbon Fiber Gauge Surround
A-tech Carbon Fiber Gauge paneling (coming soon)
A-tech Carbon Fiber Frame Covers
A-tech Carbon Fiber Tank Cover
A-tech Carbon Fiber Front Tank Cover
Magical Racing Belly Pan
Magical Racing Clutch Cover
SSR Carbon Fiber Under-seat Side Panels
SSR Carbon Fiber Under-tank Side Panels
SSR Carbon Fiber Side Fairings
SSR Carbon Fiber Under-Headlight Fairing Shroud
SSR Carbon Fiber Rear Tail center piece
SSR Carbon Fiber Alternator Cover
SSR Carbon Fiber Rear Seat Cowl
Dimotiv Center & Side Tank Pad
Exterior
Pro-bolt Gold & Blue Titanium bolts
Oxford Premium Heated Touring Grips
Driven D-Axis Clip-ons Gold/Titanium
Driven D-Axis Black & Gold Fuel Tank Cap
Driven Axis Mirror Silver/Black
Bikers Blue oil cap (removed, now need to list on the forum)
Bikers Blue Clutch Lever
Bikers Silver Swing arm end cap hooks (removing, now need to list on the forum)
Bikers Blue Swing arm adjustment plates (removing, now need to list on the forum)
Bikers Blue Fork Sliders
Bikers Blue Rear Swing arm Sliders
Bikers Blue Cable Adjuster
Bikers Blue Steering Stem Bolt
X-Race Tripe Tree (removing, now need to list on the forum)
KKK Product Upper Tripe Tree (coming soon)
Sato Silver/Black Rear Sets with Blue Bolts (removing, now need to list on the forum)
Sato Folding Pedal Tips (removing, now need to list on the forum)
Valter Type 2.5 adjustable Rearsets Black and Gold (coming soon)
Dimotiv Titanium Frame Hole Caps
Dimotiv Gold Swing arm Spools
Dimotiv Gold Sprocket Cover
Dimotiv Gold Exhaust Slider
Dimotiv Black Frame Sliders
Dimotiv Gold Alternator Slider
SSR Silver Kickstand
SSR Silver Frame hole caps (removed, now need to list on the forum)
Custom Saddlemen Black, Blue, & Pearl White Carbon Fiber Seat
R&G Mirror Block-off Plates (removed, now need to list on the forum)
Yoshimura Carbon Fiber Mirror Block-off Plates
R&G Radiator Guard
R&G Radiator Downpipe Guard
Blue Powder coated knuckle arm
Bare metal powder coated swing arm (removing, now need to list on the forum)
Blue aluminum valve stems
Custom metallic Paint Job
Engine
K&N Dual Pod filters
DynoJet Power Commander V
DynoJet Auto Tune
DynoJet Quick Shifter
DynoJet LCD-200
Motion Pro Revolver Throttle
Area P Full Ultra High Mount Exhaust system/ Yoshimura R-77 carbon fiber muffler
Zeta Racing Z-Carbon Exhaust Pipe Guard
Shorai LFX Lithium Battery
Green Silicon Radiator Hoses Tubing
Domino Racing Starter/Kill Switch
Suspension
Ohlin’s Racing Rear Shock
Andreani Fork Cartridge kit, preload, rebound, compression
Polished Front Forks
All Balls Racing Tapered bearings
Over Racing Type 7 Aluminum Swingarm (coming soon)
Scotts Polished Steering damper with Blue Titanium bolts
SSR Silver Link-Arms
Wheels & Tires
Galespeed Racing Gold Wheels
Driven Galespeed EVO 42T Sprocket
EK Gold/Black Chain
Bridgestone Battlax BT-003 Racing Street Front 110/70/17
Bridgestone Battlax BT-003 Racing Street Rear 140/70/17
Brakes
Brembo RCS 15 & Reservoir Kit
Aftermarket Silver Brembo RCS 15 Brake lever
Brembo Calipers Front & Rear
Galfer Racing Kevlar G1532 Front 068 & Rear 220 pads
SSR Front Brembo Caliper mount
RSV Rear upside-down Brembo caliper mount
Dimotiv Gold Front reservoir cap
Dimotiv Titanium Rear reservoir cap
Galfer Wave Floating Front Rotor
Galfer Wave Rear Rotor
Galfer White & Blue Brake Lines
Lighting
Bike Monkey Clear Taillight
HID Dual Halo Projectors
Smoked Led Front Turn Signals
Koso Dual temperature gauge
Old July 5th, 2014, 11:47 AM   #213
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
AMAZING BUILD!
David White , Evil Genius
What the heck are those little things on the back of the swing arm ? and what are they for /????
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old July 5th, 2014, 01:50 PM   #214
diwhiteii
diwhiteii's Avatar
Originally Posted by Klondike1020 View Post
AMAZING BUILD!
Thanks!
Those are stand hooks if you don't want to use swingarm spools to raise the bike
Old July 5th, 2014, 03:04 PM   #215
I think I've heard thst type called a "paddock stand" or something.
Old July 6th, 2014, 08:34 AM   #216
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
@diwhiteii how much did the weight savings on those rims help?
Old July 6th, 2014, 09:12 AM   #217
diwhiteii
diwhiteii's Avatar
It flicks right to left like a feather and the acceleration is improved. Next mod is really going to get me excited. Aluminum Swingarm. See Below
Old July 6th, 2014, 09:57 AM   #218
JohnnyBravo
That's good stuff... I'm def looking into the rims; nice swing arm too
Thanks
Old July 6th, 2014, 10:55 AM   #219
With the lighter rims and lighter swingarm, you're going to have to adjust your rebound damping a little bit. It's going to rebound a little faster and will need some more damping so you don't pogo.
Old July 6th, 2014, 12:59 PM   #220
diwhiteii
diwhiteii's Avatar
Yep. I haven't dialed it in just quite yet, but will when I get the swingarm.
Old July 6th, 2014, 08:07 PM   #221
diwhiteii
diwhiteii's Avatar
New frame caps, racing belly pan, and carbon fiber tank pads
The updates continue...
Old July 7th, 2014, 09:45 AM   #222
JohnnyBravo
Reminds me of Tom jones... What's new pussy cat whoa whoa whoa whooooooooa
Old July 7th, 2014, 11:26 AM   #223
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I'm pretty sure paddock stand refers to the front/rear stand itself, not the hooks.
Old July 8th, 2014, 05:03 AM   #224
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Do you happen to have the actual weights of the stock and new wheels? I'm wondering how the VRossi wheels compare. It could be just my imagination, but my bike did seem like it accelerated a bit more easily with the new wheels/tires on it.
Old July 8th, 2014, 06:53 AM   #225
Rotational inertia mang, every little bit helps. You're running DRII tires on those VRossi rims. Light tires + light rims = less rotational weight = quicker acceleration with the same torque applied. I'd hazard a bet that increase was not all in your head.
Think like a weight weenie bicyclist.
Old July 8th, 2014, 11:43 AM   #226
InvisiBill
InvisiBill's Avatar
Rotational inertia mang, every little bit helps. You're running DRII tires on those VRossi rims. Light tires + light rims = less rotational weight = quicker acceleration with the same torque applied. I'd hazard a bet that increase was not all in your head. :thumbup:
Actually Pilot Powers. The only thing I have the weight of is the new wheels, not the new tires or the old tires/wheels (hence my question to diwhiteii), so I wasn't even positive that the new stuff was lighter.
But yes, if the new setup really is lighter, it would definitely help. If you really want to get into it, even the weight distribution within the wheel setup could have a small effect on things (I think this came up in another thread).
Old July 8th, 2014, 11:45 AM   #227
All covered in the first three words.
Old July 8th, 2014, 07:18 PM   #228
JohnnyBravo
New fancy rims, or more money saved for sailboat???
Old July 9th, 2014, 10:23 AM   #229
Klondike1020
Intrepid Adventurer
Who makes the swing arm
I was looking at swapping a cr500 swing arm into my ninja when I had it
Alas laziness overcame ambition
-also --- why hasn't anyone made their own carbon fibre rim yet?
I've been watching a lot of documentaries on carbon fiber vacuum infusing
The curing in an autoclave is the difficult sounding part . But that could be don't with a really big pressure cooker
There are already CF wheels for r1 Busa grom
Somone has to make them for ninjettes
BST would make them for sure they make batch s
A batch of six grom wheels is on ebay
Old July 9th, 2014, 10:27 AM   #230
psych0hans
psych0hans's Avatar
Sailboat... You already have a bike to ride, new wheels won't make that much of a difference... Sail boat is a whole new ball park for you to play in
Old July 9th, 2014, 11:20 AM   #231
allanoue
allanoue's Avatar
MOTM - Sep '14
When you buy that sailboat, it will be the second happiest day of your life.
Old July 9th, 2014, 11:49 AM   #232
JohnnyBravo
I'm ready to retire... It's totally possible, yet crazy, soon as I get a boat capable of sailing around the high seas
Old July 9th, 2014, 01:22 PM   #233
Klondike1020
Intrepid Adventurer
Stay on CL- often people sell decent boats for stupid cheap
the sail boat market is very volatile and I even found 30' sail boats for free on occasion. Depends where you look , but for such a major investment you should be looking all over the country.
The problem with the free boats is they need thousands of $ in rigging and maintenance
Old July 10th, 2014, 04:02 AM   #234
JohnnyBravo
I've been seeing the same thing, an checking stuff out. It's amazing how much some stuff costs, an how much folks seem to give away
Old July 10th, 2014, 10:01 AM   #235
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Very nice...
Raven's Rejuvenation
Old July 10th, 2014, 12:36 PM   #236
Klondike1020
Intrepid Adventurer
People who have money to spend have money to throw away.
Boats are the worst investment possible.
I am very careful about how I spend money on a boat.
If you get a live aboard cheap then the money saved on a house or apartment can mediate the overall expenses.
Typically I buy small boat project. Jet ski, jet boat, older I/o.
Get them cheap and fix them. Sail boat rigging and slips- nothing cheap about them.
Old July 12th, 2014, 08:57 AM   #237
InvisiBill
InvisiBill's Avatar
(I'm sure glad I don't have any hobbies that are a waste of money.)
Old July 13th, 2014, 08:27 PM   #238
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
David, your bike is really very special but please allow me to criticize the way you'd mount your plate
Look how the Thais do it
But I don't know if this is allowed at your place...
Old July 13th, 2014, 08:27 PM   #239
diwhiteii
diwhiteii's Avatar
Yes I actually do. Numbers are with tires mounted
Stock wheels
Front 22lbs
Rear 31lbs
Galespeed
Front 17lbs
Rear 26lbs
Old July 13th, 2014, 08:35 PM   #240
diwhiteii
diwhiteii's Avatar
Over Racing makes the swing-arm and it is not a regular stock item, each one is made after payment is received and you can't cancel your order.
