#1 |
Join Date: Jun 2013 Motorcycle(s): 2011 Kawasaki Ninja 250r Posts: 3
New Member/New Rider with few question
Hi Everyone, I recently got my motorcycle license and a 2011 Ninja 250r 2 weeks ago. I love my experience so far. I have
Few questions. - I wish there was an gear indicator light, do you guys think this would work for the 250? Kawasaki Ninja 250R FI Only 2008-2012 Healtech Gipro DS - Is putting on the Yoshimura Fender Eliminator kit hard to install ? Doesnt seem to bad. I did a few searches on how to do it, no luck. Are there any other cheaper good fender eliminator kits (i dont want to cut the stock one)? - Is adding Yoshimura TRS Stainless/Stainless Slip-On something I should look into getting? Is it worth paying $380? Thanks everyone? |
#2 |
Jigglin' your Jiglets
MOTM - Apr '13
Perhaps you should try riding the bike before you hack away at it.
If the Ninja 250 doesn't have enough power for you, then you don't know how to ride it. AFM #676 ![]() Supersports are for n00bs |
#3 |
Blunt is Jiggles sometimes but he is right. Ride the bike for a bit to make sure it's the right bike for you.
Your questions; The gear indicator in your link says FI only. Since your location says MI I don't think it's gunna work on a carbed bike. There are some indicator mods if you search this site. None of the fender kits are hard to install. Just take your time and read the instructions. Most will say skip the slip on and go for a full system. But not this day.... once your sure the ninja is right for you, then swap exhaust as you see fit. Enjoy and ride safe!
#4 |
Ive driven about 250 miles so far! I love it. But you guys are right. I think I should ride more and get comfortable with it before doing mods.
One more question. Might be a dumb one though. When I press the rear brake, the brake light doesnt light up. Is that normal ? Thanks ! |
#5 |
Not normal sir, the use of either brake lever should activate the rear tail light.
#6 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 257
If you use the search for that rear brake light, I remember a thread with someone havif the same problem. Another member posted a picture of the nut you have to tighten to increase the "sensitivity" of the pedal. But it's basically right above the rear brake pedal. It's a plastic piece of all thread and a plastic nut.
#7 |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
Personally as you first bike I would just do the fender eliminator"They are butt ugly" then ride it for the summer untouched. During the winter I would do a full exhaust system, I just put a slip-on on mine and wished I would have done the entire system. Another good add on is some new braided brakelines. Don't forget to rejet for the exhaust too.
Right now just enjoy the ride. |
New Member/Rider :D | drunyon | New Members | 12 | November 19th, 2012 07:18 AM |
New Member with a question | tokempole | General Motorcycling Discussion | 1 | May 7th, 2012 02:48 PM |
New member and rider | dunkin | New Members | 6 | May 5th, 2012 01:45 AM |
member map suggestion/question | zeroth | Forum Information | 5 | April 12th, 2009 08:35 PM |
Is there (member map question) | sometimesido | Forum Information | 1 | April 7th, 2009 01:12 PM |
