August 9th, 2013, 08:56 PM | #1 |
Join Date: Mar 2012 Motorcycle(s): Black 2012 Ninja 250R Posts: 93
Embedded Computer Display System
MOD: I meant to post in 2012 ninja 250 farkles. Please move. Sorry about that.
Custom embedded system. Built and programmed by me. Uses two PIC micro controllers and some other accessories ICs. Shows time, date, gear, status of some accessories. (Fuse Box On/Off, Aux LEDs On/Off, Running Lights On, and External Horn On/Off). Also has an "animation/notification" window. Will show animated turn signal, high beams on/off, etc. Also shows information such as gyroscope (was going to be used for lean angle, not working out quite well), if the bike is centered, GPS info, Fuel info and MPG, some other info, etc. Shows outside temp and compass. You can log your trip on it and download it later to the computer and see it on a map (that part was actually a module so I didn't code that, but I did code the interface to it). MOD: I meant to post in 2012 ninja 250 farkles. Please move. Sorry about that. Last futzed with by linkinpark9812; August 9th, 2013 at 10:00 PM. |
August 9th, 2013, 08:58 PM | #2 |
A little messy, but everything beyond that is loomed. The blue wires in the top right hand corner actually have 4 wires in each, so that made the mess that much less. A lot of the wiring that runs back and forth on the bike is on the other side (hence all the wiring going to that side) and that is all loomed.
August 9th, 2013, 08:59 PM | #3 |
Very cool!
August 9th, 2013, 09:03 PM | #4 |
Step by step of board 1 of 2. In the last pic, you can also see the completed board 2 in the upper right hand corner.
board 1 is the main board, with the main micro-controller, some memory, inputs/outputs to bike, stuff like that. board 2 is mainly sensors (GPS, bluetooth, accelerometer, gyroscope, some I/O as well). |
August 9th, 2013, 09:38 PM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
See @CycleCam303 my bike isn't the bigger wiring cluster**** of all time.
August 9th, 2013, 09:39 PM | #6 |
nice! how are you doing the gear? ratio between speed and rpm? or do you have switches on the mechenism?
August 9th, 2013, 09:57 PM | #7 |
hall sensors which detects a magnetic field (aka a magnet) which is on the gear shifter.
August 9th, 2013, 09:59 PM | #8 | |
August 9th, 2013, 10:12 PM | #9 |
Freedom for Germany
Wow that's great, did u already think about sales?
August 10th, 2013, 04:22 AM | #10 |
That is an awesome display! Great work.
August 19th, 2013, 03:37 PM | #11 |
Shows time, date, gear, status of some accessories. (Fuse Box On/Off, Aux LEDs On/Off, Running Lights On, and External Horn On/Off). Also has an "animation/notification" window. Will show animated turn signal, high beams on/off, etc. Also shows information such as gyroscope (was going to be used for lean angle, not working out quite well), if the bike is centered, GPS info, Fuel info and MPG, some other info, etc. Shows outside temp and compass. You can log your trip on it and download it later to the computer and see it on a map (that part was actually a module so I didn't code that, but I did code the interface to it). |
August 19th, 2013, 03:39 PM | #12 |
That's pretty cool!
August 19th, 2013, 03:44 PM | #13 |
/merged
January 6th, 2014, 06:04 PM | #14 |
Could you share the source & model or P/N of those sensors? I've been meaning to replace the magnetic switches on my cheapo Chinese-made gear indicator.
January 6th, 2014, 06:13 PM | #15 | |
Pulls down to ground when activated. |
January 6th, 2014, 06:41 PM | #16 | |
Thanks! My existing one is really more like this one: http://www.digikey.com/product-detai...0-010-ND/43977 I assumed they were the same type of thing. Will your type not work as a replacement? Mine are way too touchy and extremely difficult to adjust.
January 7th, 2014, 06:28 PM | #17 |
March 22nd, 2014, 06:34 PM | #18 |
Join Date: Mar 2014 Motorcycle(s): ninja 250r 09 Posts: 17
very cool. I do still with ardiuno but haven't done anything like this.
March 30th, 2014, 12:57 AM | #19 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
very interested in this
March 30th, 2014, 09:50 AM | #20 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
That's cool, way to many bells an whistles for my taste, my bike came stock with all the stuff I care about ATM
March 31st, 2014, 01:03 AM | #21 |
A and B trip meter
Instant fuel Average fuel Coolant temperature Outside temperature Option Air Fuel Ratio via Wideband Sensor Exhaust Temperature Gear Select |
April 10th, 2014, 01:20 PM | #22 |
Join Date: Mar 2014 Motorcycle(s): 2008 250r Ninja Posts: 67
I'd buy this. Hint hint
April 10th, 2014, 11:30 PM | #23 |
Got the new one up and running for the most part, just need to test/calibrate the sensors!
April 11th, 2014, 06:55 PM | #24 |
Sweet
Please Critique My Riding (Video Embedded) | jeffb502 | Riding Skills | 47 | April 23rd, 2014 03:28 PM |
YouTube Embedded videos | NevadaWolf | Help | 2 | June 23rd, 2013 12:17 AM |
Best embedded code comment on record | Alex | Off-Topic | 14 | April 4th, 2013 01:34 PM |
Question for you computer geeks… I mean… computer experts | THE BIG SITT | Off-Topic | 10 | January 28th, 2012 12:18 AM |
[visordown.com] - First Look: Transparentius - road display system | Ninjette Newsbot | Motorcycling News | 0 | January 4th, 2010 02:50 PM |
