November 13th, 2013, 01:20 PM | #1 |
Join Date: Sep 2013 Motorcycle(s): 05 Ninja 250 Posts: 23
Idle speed
First thing is that when I start the bike after a day of not riding the bike starts up and then dies. I notice that the RPM's are less than 1k when this happens. All I need to do is apply a little choke and let it run for a minute and when I release the choke all is fine and the bike runs.
Next issue is that when just beginning to ride the idle speed is around 1.2 rpm's but then after riding for a while it will jump to 3 or 4. I have checked for vacuum leaks using the carb spray on all 4 boots but don't see any change in the idle speed. I really thought this was the issue but now I have no idea or maybe there are other places to check for a leak. I have also messed with the idle adjuster screw countless times after riding the bike for 15 minutes to make sure the engine is warm to get it to the 1.2 rpm's but the problem still persists. I have also lubed the throttle cables recently because I thought they might be sticking. Any questions, comments, or ideas would be helpful. Thanks. |
November 13th, 2013, 01:28 PM | #2 |
Time for a carb cleaning . Something is sticking somewhere when it gets warm/hot enough. You could try some seafoam or the sorts but doubt it will help. My gut is telling me to let you know to check for carb sync too. Not sure why.
November 13th, 2013, 01:51 PM | #3 |
Join Date: Nov 2013 Motorcycle(s): 2007 Ninja 250 Phantom Silver, 2006 Harley Davidson XL1200L Glacier White Posts: 28
Sticky slide?
November 13th, 2013, 01:53 PM | #4 |
Thanks for the response. I recently cleaned the carbs as well. I did not sync them though since I don't have the tool. I will try to get my hands on a sync tool and see if that fixes the problem.
November 13th, 2013, 02:12 PM | #5 |
November 13th, 2013, 02:24 PM | #6 |
Could also be something like the vacuum line to the petcock. A small split in the line might be able to do this but be hard to see. May do good to replace all vacuum lines depending on their age anyway.
November 13th, 2013, 02:47 PM | #7 |
This is what I'm thinking also.
November 20th, 2013, 09:52 AM | #8 |
I was able to clean the carbs again and even sync them. The problem still persists though. My next idea was maybe the air filter. Is that possible?
November 20th, 2013, 12:05 PM | #9 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Has this bike run well in the past or is it a new problem / new to you bike?
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
November 20th, 2013, 12:19 PM | #10 | |
I took it for a ride earlier and can get the idle speed back down when I pull the clutch in but other than that it tends to idle high. |
November 20th, 2013, 12:36 PM | #11 |
Does it still run good with the choke on? That's usually a sign of clogged jets.
Did you remove all of the jets and clean them carefully? How about the float height? Did you set the idle mixture screws at 2 1/2 turn out and confirm the washers and o-rings are good? If the air filter looks good I don't think it's an issue. Check for a vacuum leak around the carb boots. |
November 20th, 2013, 12:45 PM | #12 | |
When I cleaned the carbs I removed all the jets and cleaned the very tiny holes and made sure they were all clear. I did not check the float height or idle mixture screws but that is what someone said in another forum I just looked at. They said idle mixture screw not set right was one of the main problems for high idle speeds. I will check the idle mixture screw. What is a proper float height? **Just took it for another quick ride and when it started to idle high I stopped and pulled in the clutch almost to the point of letting the bike stall out. I tried it a couple of times and it went back down to regular idle. Last futzed with by tdecotis; November 20th, 2013 at 01:12 PM. Reason: typo |
November 20th, 2013, 02:06 PM | #13 | |
Take the air filter out and reach inside the airbox. Lift the slides with your finger and let them drop - do they rise and fall smoothly? Does the throttle snap back quickly and firmly when you release it? Set the idle mixture screws 2 1/2 turns out, slightly more in cold weather. |
November 20th, 2013, 02:30 PM | #14 |
sail away
Valve adjustment? These bikes have valves on rockers that like to tighten up over time. If they get too tight the valves never close.
The correct float height is 17mm +-2mm. http://faq.ninja250.org/wiki/How_do_..._the_floats%3F Personally, I think the method using the clear tubing is only good for a gut check. You attach clear tubing to the drain hole and bend it upward so that the end of the tube is higher than the height of the fuel in the carb. Then you unscrew the drain plug and allow the fuel in the bowl to go into the tube. Theoretically the height measured in the tube should be similar to the height inside the bowl.
November 22nd, 2013, 10:47 AM | #15 |
Thanks again everyone. I realized that when I cleaned the carbs I screwed in the idle mixture screws all the way. I was able to reset them and the bike seems to be running the best it has since I got it.
Irregular idle and stalling at speed | scubaru | 1986 - 2007 Ninja 250R Tech Talk | 8 | May 26th, 2013 06:26 PM |
How to Adjust Idle Speed | 2013 kawi girl | 2013 - 2017 Ninja 300 Tech Talk | 6 | October 23rd, 2012 07:02 AM |
Ideal idle speed? | vital2009 | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 2nd, 2011 04:33 PM |
Idle Speed? | jstrain | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 6th, 2011 11:51 AM |
idle speed? | ninjablk08 | General Motorcycling Discussion | 5 | June 11th, 2009 05:22 AM |
