March 26th, 2014, 02:52 AM | #1 |
Name: S n 0 r r £
Location: Stjoerdal, Norway (San Diego, CA, USA, 2015-2016 , Bielefeld, Nordrhein Westfalen,Germany 2021-'22)
Join Date: Sep 2012 Motorcycle(s): TMZ 5.952 "Tula" 200, Ninja 250 -Special ed. '11, ZZR 1400 (ZX14), Honda CB 1100 F Super Bol D'or Posts: 150
"scratching" noise when driving, depending on the clutch
Recently I have noticed a sound from the bike ('11 250R) when driving.
It's not easy to describe, but is some sort of "scratching" noise. I hear it clearly on my daily commute, mostly going at 60-65 mph. When I pull in the clutch it stops immediately. Some rotating parts seem to contribute to the sound/noise. It's not very loud. (It reminds me slightly about a dog scratching himself intensely) It's like a surface scratches another surface several times a second (when going at the typical speeds metioned). Immediately I thought it has something to do with the clutch itself. The chain seems to be worn. I doubth that it's from the chain, but using the clutch could maybe change the stress on the chain, which could turn the sound off and on? Anybody that have experienced what they believe is the same kind of sound? Any idea about the source? Thanks. Last futzed with by Norway; March 26th, 2014 at 02:54 AM. Reason: typos |
March 26th, 2014, 04:27 AM | #2 |
See if it still happens if you just touch the lever or just put slight pressure on it.
March 26th, 2014, 05:01 AM | #3 |
Fast-Guy wannabe
MOTM - Jan '13
Worn chain will make a grinding scratching sound under load, and it can get pretty loud.
March 26th, 2014, 01:06 PM | #4 |
Name: S n 0 r r £
March 26th, 2014, 01:09 PM | #5 | |
Name: S n 0 r r £
Interesting what you say here, since I suspected that the noise was less when going downhill, which normally means little load.. I'll also lubricate it thoroughly next time, and see if that helps. Thanks. |
March 31st, 2014, 05:39 AM | #6 |
Board Member
find anything?
March 31st, 2014, 01:28 PM | #7 |
Name: S n 0 r r £
I took the bike for a ride, for a couple of hours, on Saturday. I noticed that the noise is diminishing as soon as I release the throttle, meaning that it seems to be there only under load.
It was mentioned that this could be the case if the chain is worn (which it is). So, I guess it might be the chain. What I find a little bit strange is that I have the impression that the sound comes from somewhere in front of me, and towards the right. But, I guess my perception may be wrong, in this respect. I will tell if I find out.. |
March 31st, 2014, 01:51 PM | #8 |
It very well could be the chain. Do not fully trust directional sound when riding a bike except left vs. right. Measure you chain slack and you will know.
March 31st, 2014, 01:58 PM | #9 |
Join Date: Jun 2012 Motorcycle(s): 12' Ninja 250 Posts: 831
this. Could possibly be ur chain. I currently dont have the proper tools to adjust me chain, every time i ride it hits the bottom part of the chainguard. makes me sad inside ((
March 31st, 2014, 02:09 PM | #10 | |
If the lack of a paddock stand is the problem you could have a couple of buddies lift the rear. |
May 12th, 2014, 11:26 PM | #11 | |
Name: S n 0 r r £
The previous chain did not stretch out, at some places. This made the scratching sound, when driving. It also lead to a very rapid detoriation of the sprockets. So, the clutch was not the source, in my case. |
May 17th, 2014, 08:28 AM | #12 |
Join Date: Nov 2013 Motorcycle(s): 2012 Kawasaki Ninja 250 Posts: 50
Glad to read this post. I now know I need a new chain and sprockets, exactly what I thought. (:
May 17th, 2014, 05:38 PM | #13 |
Board Member
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2015 01:40 PM |
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2012 04:30 PM |
Rear Brake Scratching Noise | etiainen | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 23rd, 2011 07:17 PM |
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits | Ninjette Newsbot | Motorcycling News | 0 | April 12th, 2010 11:20 PM |
Question about loud "pop" noise from exhaust (?) | mbharat | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 4th, 2009 08:58 PM |
