May 10th, 2014, 04:40 PM | #1 |
Join Date: May 2014 Motorcycle(s): 2010 Ninja 250R Posts: 6
Another bike will crank but won't start thread...
So...I know there's plenty of threads on this and yes, I've read them all. So, as the title states, my bike will crank, but won't start, now, let me explain my situation. My just bought a 2010 250R and the previous owner said he had let it sit for about a year, now when I got the bike, it still ran fine but would only run with the choke on. So, I got it home yesterday and this morning everything worked fine. I took out the carbs to clean them but found that they were already very clean, still, I sprayed some carb cleaner through all the areas anyway since I had the carbs out already. Afterwards, I re-assembled everything and I had to hold the starter for a little while but the bike started right up with the choke on. It would still cut off with the choke off so I turned up the idle knob and it worked fine with the choke off. So, satisfied that everything was working well, I turned off the bike and went to work putting the fairings back on and then took the bike off the stands. After I had cleaned up I went to start the bike to ride it only to have it start for a second and then die, and then after that it now only will crank but won't start. I have already checked all the common issues: fuses, spark plugs, spark in the boot, fuel in the carbs and I hooked up my battery to my car (while it was off) and still no luck. Anyone have any idea what could be wrong?
May 10th, 2014, 04:57 PM | #2 |
Join Date: Feb 2013 Motorcycle(s): Ninja 250 (2001) Posts: 135
How long did it sit between it starting with choke and it not starting? I'm assuming not long, from your post. First thought: how is the battery doing? If the battery is weak you could still get spark, but it could have some trouble actually starting.
Also, it's good practice to clean out the jets and the little transition circuit passages with some copper wire or nylon (not steel!) guitar string, since carb cleaner alone can't really get all the deposits off. If you haven't done that already, and if you do end up taking the carbs off again (and hopefully you won't have to), definitely give that a shot. |
May 10th, 2014, 04:59 PM | #3 | |
May 11th, 2014, 06:34 AM | #4 |
Wannabe Reborn
Could always try a little ether/starting fluid. If it starts and runs, but then dies, it's a fuel supply issue. If it doesn't start, that could be an igniting issue. Won't solve it, but gets you closer to finding solution.
May 11th, 2014, 07:01 AM | #5 | |
If you have a multimeter laying around you can test the battery pretty easily, and if not, they're way cheaper than a new battery. |
May 12th, 2014, 09:07 AM | #6 |
I've tried using WD40 directly into the airbox, no luck starting
May 12th, 2014, 09:07 AM | #7 | |
May 12th, 2014, 10:23 AM | #8 |
Hmm. Now I'm just grasping at straws, but you could also double-check that the airbox/crankcase vent hose is still attached -- I accidentally knocked mine off once while reinstalling the carburetors, which made it very hard to get the bike started and to keep it running. The vent hose is the S-shaped hose that attaches to the bottom of your airbox (pictured here without the airbox, and with an aftermarket white plastic breather attached to it). And you've already probably done this, but it would be a good idea to double check that the carburetor/airbox boots are securely fastened, with the boot springs in the right place.
May 12th, 2014, 12:08 PM | #9 |
Track Clown
MOTM - Sep '15
bad gas. run a clean tank through, also play with the idle adjuster on the left side of the bike below the tank.
Step 1: Start bike with choke. Step 2: let bike warm up with choke fully open. Step 3: Step once RPM is in the 6000 range, reduce choke to off, if it shuts down, repeat step 1. Step 4: reduce choke down till the RPM is resting around 2000. Step 5: Adjust Idle screw till the RPM is 4000. Step 6: Turn off choke. |
May 12th, 2014, 12:44 PM | #10 | |
May 12th, 2014, 01:05 PM | #11 |
My current problem is almost identical to this:
http://www.kawiforums.com/ninja-250r...-problems.html The only difference is even when I set the fuel to PRI, it still doesn't work, but other than that, it's the same issue, if I let the bike sit for a few hours, I can get it to start after holding the starter for 5-10 sec, but it'll run at high RPM's and then eventually shutdown after a couple min and won't start back up. That guy ended up having hoses in the wrong place, but I'm pretty sure all my hoses are correct, I've checked them several times. I also took some pics to make sure. |
Bike won't start !HELP! | carterdenny | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 5th, 2014 08:40 AM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
bike won't crank!! | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 5th, 2011 04:19 PM |
Another "Bike won't start this morning" thread. | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 40 | January 1st, 2011 02:03 AM |
Bike won't start, help! | demp | 2008 - 2012 Ninja 250R Tech Talk | 10 | November 10th, 2009 01:45 PM |
