June 14th, 2011, 03:00 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
bike won't crank!!
I have an 09, it was down for about a month now because I was waiting for parts and doing a whole bunch of maintenance.
I put all back together and now it won't crank...horn and turn signals work. I thought it was a dead battery and went out and bought a charger. I put it on and it supposedly charged pretty quick (charged light went from yellow to green). I put it back in still no crank. Now I've attached it to battery while in the bike and if the ignition is off is says fully charged after a few minutes but still no crank. But if I leave the ignition on then the charger seems to be charging..I have no neutral light or headlights...HELP. |
June 14th, 2011, 03:27 PM | #2 |
ModMy250.com
So, just to be sure, if you pull the clutch in with the kickstand up, it doesn't crank? Also, when you say "whole bunch of maintenance" what does that mean? Is there any way you disable or disconnected the neutral safety switch?
The www.ModMy250.com guy |
June 14th, 2011, 03:38 PM | #3 |
Check the voltage of the battery. Leave the charger on over night. http://www.ninjette.org/wiki/Battery
June 14th, 2011, 04:08 PM | #4 | ||
June 14th, 2011, 04:20 PM | #5 |
The bike should be turned off. If the battery fails to hold a charge, and voltage drops below 12.2 volts, get a new battery.
June 14th, 2011, 04:52 PM | #6 |
I just went to a shop and had him check out my battery, it seems fine he says. Any other ideas why it won't turn over?
June 14th, 2011, 05:06 PM | #7 |
First thing I'd do is figure out why there's no neutral light. Are you sure the bike is in neutral? Also, the headlamps won't be on until the bike is running.
June 14th, 2011, 05:13 PM | #8 |
I'm just as stumped as to why there is no neutral light... its definitely in neutral, I checked my fuses as well they seem to be fine.
June 14th, 2011, 06:33 PM | #9 |
Have you tried to shift between neutral and first and checked all the switches?
June 14th, 2011, 06:59 PM | #10 |
June 14th, 2011, 07:29 PM | #11 | |
June 14th, 2011, 09:40 PM | #12 | |
June 15th, 2011, 06:20 AM | #13 |
Found the problem!! It is the clutch safety switch #1 on 17-12 of the service manual. However I can't find where it plugs in...is it supposed to be behind the sprocket cover? The picture in the manual doesn't make sense.
June 15th, 2011, 08:37 AM | #14 |
It (Neutral Switch Connector) does sit behind the sprocket cover.
September 5th, 2011, 04:19 PM | #15 |
I don't think "Neutral Switch" and "Clutch Switch" are the same thing. One lets the bike start in gear when you pull the clutch lever while the other lets the bike start regardless of the clutch lever (when in neutral).
Starting issues, Ninja 2010 won't crank | BlueDragon | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 12th, 2015 02:49 PM |
Help! Bike won't go anywhere!! | Danger13Fox | 2008 - 2012 Ninja 250R Tech Talk | 29 | September 11th, 2014 06:07 PM |
Can you crank a bike without carbs in it? | Finesse | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 22nd, 2014 04:47 PM |
Another bike will crank but won't start thread... | remix919 | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 12th, 2014 01:05 PM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
