June 9th, 2014, 01:08 PM | #1 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Bike dies w/o choke
I was trying out my uncles Vulcan 500 yesterday. After riding around a bit with the choke on, I figured the bike was warm enough, so I shut the choke off. Whenever I came to a stop, the engine would shut off and wouldn't run again w/o choke.
What's the reason for that? I know he hasn't ridden the bike for a while, exactly how long I'm not sure right now. Is this an effect of old gas?
"even a proper fitting helmet can 'get loose'" -csmith |
June 9th, 2014, 01:09 PM | #2 |
Old gas or time to clean the carbs. Just because it's an older cruiser, don't mean much different between that and the ninja. Idle circuit mang.
June 10th, 2014, 09:01 AM | #4 |
Join Date: Oct 2011 Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT Posts: 434
definitely clogged pilot jet
wardie |
June 10th, 2014, 01:54 PM | #5 |
Track Clown
MOTM - Sep '15
bad gas and/or dirty filter. I cleaned my filter on the 250 this weekend and it fires up like a champ now.
June 11th, 2014, 10:28 PM | #6 |
Your face
Hmm seems as if i must clean the carbs eh? Would running some seafoam through it do the trick? Or am I about to have my head chopped off for even suggesting the idea...
June 11th, 2014, 10:30 PM | #7 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
Depends on how bad the carbs are. Ran a tank of seafoam through my ninja and it did the trick for me
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
June 11th, 2014, 11:10 PM | #8 |
Seafoam is the armchair psychologist diagnosis of depression... "just get out more"
I recommend the carbs get a good cleaning. Seafoam is the bandaid on the broken leg. Don't waste the bandaid until after you set the bone, put a screw through the fracture, and stitch up the wound. cliffnotes -seafoam after you clean the carbs -i agree, idle circuit, pilot jet, mixture screws, water in the fuel, run ethanol free if the bike plans to sit for any period of time (unridden)
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
June 12th, 2014, 03:57 PM | #9 |
King Hamfist
Join Date: Oct 2012 Motorcycle(s): 2007 Crf 150R, 2011 Hypermotard 796 Posts: 940
My dirt bike runs like garbage since I use it so infrequently. Really after 10 minutes of slapping the rev limiter it'll run fine. And I'm talking after not starting for 3 or 4 months.
June 12th, 2014, 04:11 PM | #10 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
It's always the idle circuit and if cleaning that doesn't stop it you will have to clean it again until it does.
Seafoam does not dissolve rust particles, grit or any of the microscopic stuff you find on careful dismantling. The future is fuel injection thank God. In 20 years we will wonder why we put up with carbs, just like we did with contact breakers. |
June 12th, 2014, 07:14 PM | #11 | |
June 13th, 2014, 03:43 AM | #12 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
Could be your idle cable. I had this issue. When the idle cable came loose I could only run with choke on.
Riding as I stole it. |
Bike starts without choke | rasta | General Motorcycling Discussion | 9 | July 22nd, 2013 08:00 PM |
Bike dies with choke after not storing properly... | seamuswh | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 15th, 2012 10:47 PM |
Help!! Bike not running without choke | gaby | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 12th, 2011 07:15 PM |
bike wont run without choke on? | ReDnEcK | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 15th, 2010 08:50 PM |
Bike keeps stalling when I closed the choke | calpoly07 | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 19th, 2009 05:17 PM |
