July 7th, 2014, 10:21 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): ninja 650r. suzuki m50 Posts: 2
oil change disaster....help!!!!
My wife tryed to take me filter off and completely bent it half....resulting in my ripping it apart piece by piece and its still sealed on there like it was welded....help!!!
July 7th, 2014, 10:52 PM | #2 |
Join Date: Jan 2014 Motorcycle(s): 2007 Ninja 250 Posts: 23
Can you use a needlenose plier or a regular plier and work it carefully to unscrew the metal casing off?
Oh, and another point. Whatever tool you decide to use, make sure it has a lot of surface area to grip the metal casing. You don't want to tear the rest of it into smaller pieces. Last futzed with by curiousrat; July 7th, 2014 at 11:16 PM. Reason: Added more comments. |
July 7th, 2014, 10:53 PM | #3 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
Wow.
I'm guessing vice-grips or channel-locks on the remaining flange isn't getting it to turn? Do you think that the filter might have been cross-threaded? If the vice-grips / channel-locks don't work I would probably try and VERY CAREFULLY cut off the remaining flange and then try vice-grips / channel-locks on the circumference of just the remaining nut portion. If that doesn't work I would EVEN MORE CAREFULLY try and split the remaining nut part of the filter and pry that off. May your hands be swift and true. Last futzed with by iamjacob; July 7th, 2014 at 10:54 PM. Reason: speeeling |
July 7th, 2014, 10:56 PM | #4 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
I don't know what in the actual fck you guys did there. What I would do at this point , would try 2 things. Put a leather ultility glove on and try to turn it by hand. 2nd , try a large flat head screw driver and gently tap the holes on the remaining oil filter in the counter clockwise direction. That should help loosen it
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
July 7th, 2014, 11:03 PM | #5 |
July 7th, 2014, 11:23 PM | #6 |
July 8th, 2014, 02:56 AM | #7 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
+1 on a screw driver and mallet. Make an indent for the screwdriver to get a good bite and gently "hammer" it off. Stop if the metal begins to tear and make another indent. Heat from a small torch (be very careful not to over heat the parts) or hair dryer on the remaining filter part may help. Try not to feat the anything but the filter piece so it will (slightly) expand then try to tap it off with the screwdriver and hammer. Good luck.
July 8th, 2014, 03:49 AM | #8 |
Que Buenos Son!!!
MOTM - Nov '14
What did you use to try to get the filter off,.. a hammer?
July 8th, 2014, 03:58 AM | #9 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
...And what did you learn in school today, son?
lol Just kidding
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
July 8th, 2014, 04:07 AM | #10 |
Assuming it's aluminum on the motor end, heat will only make it more difficult to get off. [Aluminum expands faster than steel] If I were you I'd try to find a pin spanner and pull it off that way. Check a bicycle store.
http://www.bikepartsplace.com/discou...er-spa-1c-grn/ I wouldn't suggest using vise grips on the threaded portion of the filter as you will likely not be able to get it off that way without damaging the threads on the motor. |
July 8th, 2014, 04:40 AM | #11 |
Get an adjustable pin spanner wrench of some type.
http://www.harborfreight.com/adjusta...nch-36554.html |
July 10th, 2014, 05:54 PM | #12 |
tryed everything
We started with the filter socket which only stripped the filter, then we tryed the wrench that bent and stripped it, then hammered a stress driver through it and that finished it off.so now ive pulled it apart piece my peice as u can see.I guess the pin pliers are my last hope.the most its budged is a quarter inch.the thread started to bend as well....is that thread bolt replaceable? And where would I find one????
July 10th, 2014, 06:36 PM | #13 | |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
Hey Unregistered never go faster than your brakes can be applied... |
July 10th, 2014, 11:18 PM | #14 |
Post another picture so we can get a better idea of where you stand.
From the 1st picture, what is the yellow stuff around the threads? Have you tried lubing the threads with some engine oil and then turn it? I was thinking some extra lubrication could help. |
July 11th, 2014, 12:25 AM | #15 | |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
July 11th, 2014, 02:38 AM | #16 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Hopefully a spanner wrench will be beefy enough to get it loose for you, and if that fails you'll have to get two long pin punches to put in the holes and a screw driver to twist it off.
I prefer to use a wrench that i can slide as close to the base of the filter as i can so i can grip the base, which is extremely strong and less likely to tear apart from someone gorilla griping it while tightening it. In the event a wrench is unable to twist the filter you will want to back the wrench out on the filter about an inch with someone applying pressure and using a chisel very carefully next to the base and tapping the filter lightly to get a bite so you can get a better blow on it to release the friction the gasket is causing it to bind on the engine. |
July 11th, 2014, 05:43 AM | #17 |
Old and slow
Join Date: May 2014 Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250 Posts: 889
first off, stick something in that oil intake so nothing gets in there, crawls in there.
that way if you have any grinding or what have you, nothing gets into the engine... THIS IS LITERALLY the last thing between the oil sump and the journal bearings, wrist pins, cam bearings... All the filters and chunk removal is before this point, keep it clean. Secondly I have an oil filter removal tool at home, it is the BOMB. more you twist, the tighter it grabs... the OEM filter from Dodge (installed at the factory) would not come off. I put this thing on and it crushed the filter, but it came off. has gears and cams inside, works both ways, lose and tight... and so far it fits everything from a Dodge Dakota to a Honda CBR600 I got it at Farm & Fleet... sorry the pic doesn't show the manufacture, more info as I have it. |
July 11th, 2014, 10:36 AM | #18 | |
EX500 full of EX250 parts
July 11th, 2014, 11:04 AM | #19 |
Que Buenos Son!!!
MOTM - Nov '14
Anytime that I've had an oil filter that was on too tight to remove I've always used the same old trick... I just pound a big screwdriver through the filter, in one side and out the other, and use the extra leverage of the screwdriver to twist it out. Works every time.
July 11th, 2014, 11:22 AM | #20 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
Not sure if you all are doing this, but before installing the new filter always rub some fresh oil on the rubber seal before seating the filter. This will prevent it from seizing up when it is time to change it. I have been doing this on all of my vehicles for years and have never had the the filter stick.
July 11th, 2014, 11:25 AM | #21 |
July 11th, 2014, 11:33 AM | #22 | |
Put a few rubber bands wrapped around the flange on what's left of the filter & use a vice grips to try to work it off. You don't want to catch the threads with the grip, the rubber should improve traction and keep the grips far enough off the threads
July 11th, 2014, 11:47 AM | #23 |
Oil on the threads and gasket only work if your the one doing it.
July 15th, 2014, 05:29 PM | #24 |
Join Date: Apr 2012 Motorcycle(s): 2012 Yamaha FZ6R, 2014 Suzuki GSX-R600 Posts: 299
I would take a sheet metal cutter and cut as far inward as you can go, then try to rip it the rest of the way.
July 15th, 2014, 06:10 PM | #25 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
If you take a long narrow punch you can stick the tip if it firmly against the side of one of the holes and tap it with a mallet counter clock wise.
it should come out easy.
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
July 15th, 2014, 08:11 PM | #26 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Looks worse than it is...
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
oil change | wellcraft | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 14th, 2010 06:14 AM |
change oil filter, without draining oil? | peter330 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2010 01:08 PM |
