August 28th, 2014, 06:42 AM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
clamp around airbox to carbs
hey there im missing one of the spring clamps that go around the air box boot to the carbs
will that make a difference in performance and what will I notice... |
August 28th, 2014, 06:47 AM | #2 |
It could possibly leak a bit, you can throw a zip tie around it till you get something more permanent.
August 28th, 2014, 06:49 AM | #3 |
Join Date: Feb 2013 Motorcycle(s): Ninja 250 (2001) Posts: 135
It could end up giving you some inconsistent fueling issues, or it could have no effect. You can check to see if it's a problem by spraying carb cleaner around the boot while the motorcycle is warmed up and idling. If the idle changes, you have a leak. (Wipe the carb cleaner residue off after you're done -- over time it can degrade some kinds of rubber).
Either way, the easiest thing to do is to go to the hardware store and get a screw-type clamp (like the ones that go on the engine/airbox boots) and use that in the place of the missing spring. |
August 28th, 2014, 06:52 AM | #4 |
I would definitely do something. Order the OEM clamp and find something to snug it down with temporarily - even a zip tie is better than nothing.
You won't get a vacuum leak because it's on the back side of the carb, but you could draw-in unfiltered air. |
August 28th, 2014, 07:31 AM | #5 |
gonna use hose clamp will that help
Airbox ducts to carbs | tiggen | 1986 - 2007 Ninja 250R Tech Talk | 9 | April 2nd, 2014 06:42 AM |
remove and reinstall carbs - stock airbox | red | 2008 - 2012 Ninja 250R Tech Talk | 22 | July 16th, 2013 07:09 PM |
How do I get the carbs off of the stock airbox? | Ben M | 2008 - 2012 Ninja 250R Tech Talk | 11 | September 28th, 2012 11:21 PM |
Full exhaust + airbox mod = how hi maintenance are the carbs/jetting? | 675Raisinator | 2008 - 2012 Ninja 250R Tech Talk | 14 | December 27th, 2011 12:05 PM |
SV clamp-ons | Ninja Nut | Motorcycle-related | 1 | January 4th, 2010 05:15 PM |
