#1 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninja EX250 Posts: 19
Low end power??
So i just did the 6000 mile valve adjustment and the intake was at .002 and the exhaust was at .003. we changes the intake to .004 and the exhaust to .005 (the low end of spec) and it still is making a little excess slapping/ clicking noise. Also, the bike putts in 1st, 2nd gear up until about 7000 rmps (the bike will start to pull but let up then will almost shoot you a little then putt again? i forgot to mark where the throttle chord was tightened at, but we got it to where its running the best, but its not wehre it used to be (when we put it to about where it was, this bogging is 10X worse? PLEASE HELP BROTHERS, this is my daily driver (no car)>? Thanks, Luke
#2 |
Sounds like it needs some carb work or adjustments.
Is the air filter clean and the snorkel clear? How old is the gas? First thing I would do is to make sure the gas is good before doing much else. |
#3 |
Gas is brand new. Cleaned the carbs when we had them off. Has a brand new K&N air filter, even tried taking it out and putting the stock one back in, and it ran worse, so went back to K&N (the one in the airbox). Would shimming the needles in the carbs help (I dont know what this would do?) or do you think the carb needs jetted? Thanks, Luke
#4 | |
Did you oil the K&N? Shimming will help, but it should run reasonably well without. |
#5 |
I did not adjust the idle screws. The K&N came oiled. the bike seems to run decent about 6K RPM, but maybe a slight bog when holding steady RPM? Im frustrated as can be, we adjusted valves twice, cleaned carbs & jets inside and out w carb cleaner. It looks like there was an aftermarket needle in there bc it is stainless steal color? do you think shimming the needle would fix the low end bog? Thanks, Luke
#6 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
Spray carb cleaner doesn't do a good job of cleaning a dirty carb. It simply isn't aggressive enough to cut through heavy buildup.
Soak the metal parts only in Berryman's Chem Dip for 24-48 hours, rinse with water, and blow out the jets and every opening in the carb body with high pressure compressed air. If you have access to a sonic cleaner, it will get the carb clean the first time. I've seen carbs that needed as many as five extended soaks in Chem Dip to get completely clean. |
#7 |
The carb jets were fine looking, see through all holes and did use high pressure to blow through all jets and didnt seem dirty at all. the bike only has 6000 miles. I ran a whole tank of seafoam through before i cleaned them. not thinking its a dirty carb issue, i just think the mixture might not be right? Which a dirty carb could cause, but they seemed so clean, and when i ran carb cleaner and compressed air through everything, it passed through with ease? The bike didnt bog before i cleaned them and did the valve adjustment? and it was bogging to point where i couldn't get going without bike about to die, then we adjusted the throttle cord and it got better, but not quite there yet?
#8 | |
Shimming will help it run better in the mid-throttle range, but I think there's an issue elsewhere that needs to be corrected to get it running properly. Are you running 87 octane ethanol-free gas? You should be using the idle speed adjuster on the left side to adjust the idle speed to 1300. Adjusting the slack in the throttle cable isn't the correct way to adjust the idle speed. I might also drain the floatbowls just to take a look at what comes out. The valve adjustment could be off as well. Chances are you will need to remove the carbs again and go through them very carefully. Read through this section first - http://faq.ninja250.org/wiki/Intake Plan on syncing the carbs when you get them back on. |
#9 |
I bet it might be that idle mixture. We adjusted valves, then took off adjusted again a little tighter bc we thought it was a little to loose. so its at intake .004 and exhaust .005 which is lowest end of spec. I will do the idle mixture/clean carbs tonight and let you know what happens. What does adjusting the throttle cable do? and how should i adjust it? and what i meant was that before i adjusted that cable, i knew that the idle as adjusted on left little black knob, but when i put bike in first and went to hit the gas, it wanted to die, then all a sudden would catch and shoot me like a sling shot then back down then back up till hit 6K rpm then ran fine? we did sink the carbs after both valve adjustments and cleaning carbs. I will clean those idles then sink carbs. Anything else anyone can think of with this new info?
#10 |
im running 89 for past 12 months (since i have had it)
#11 |
#12 |
So i tested the Petcock, and it is not leaking. I adjusted the valves to the low end of spec. intake .004 and exhaust .005 last night. I changed the oil, smelled a little gas in the oil, and the oil was dark. When i filled back up wtih oil, it was honey color and had lots of little bubbles in it in the sight glass
#13 |
Inline 4!!!
That's what I was thinking.
#14 |
Join Date: Nov 2014 Motorcycle(s): EX250, Suzuki Savage, 76 Goldwing restoration project, 71 CB350, 73 Yamaha GT1, Posts: 73
Running it up at WOT or almost there...let off just a little and it momentarily seems to pull much harder...then normal again is usually slightly lean mixture.
Have you done any exhaust or intake mods that would increase flow through the engine? If so, you'll probably need to rejet. The way they jet so lean these days, you almost need to rejet a brand new bike. Good luck with it...and there's really not much low end power to get anyway but I understand what you're saying. Steve |
#15 |
Welcome Steve!
#16 |
Hi Everyone.
Thanks for the welcome, Chris. Just thought I'd drop in since I've read that one so many times in so many different places and it sounds just as he described it. That is, of course, assuming that the carbs are working completely properly with all jets clean, clear and the float levels correct. |
#17 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
Float height
I was also going to mention float height. Very important.
Those 2 pilot screws should be set 2.5 turns out from lightly seated. And a teeny weenie washer or 2 under the needles should help. With those 2 minor mods, correct float height and a carb sync your 250 should run sweet. j98sprint |
Low end adjustment help | Noobman | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 9th, 2014 08:51 PM |
Low power in all gears | caltony | 1986 - 2007 Ninja 250R Tech Talk | 13 | February 15th, 2014 10:30 AM |
improving low end power | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 16 | November 17th, 2013 05:37 PM |
Low rpm power not there? | zzrguy | 1986 - 2007 Ninja 250R Tech Talk | 22 | June 20th, 2012 06:37 PM |
Where to start- assessing complete lack of low end power | Jojah17 | 2008 - 2012 Ninja 250R Tech Talk | 17 | May 10th, 2011 11:24 AM |
