Old April 18th, 2015, 06:29 AM   #1
motor32
motor32's Avatar
Motorcycle(s): 1987 Kawasaki Concours --- 2008 Kawasaki Ninja 250R
### Painting Leathers ??? ###
I want to change the color of my leathers. Any suggestions on how to do this ??? I want to go from black to lighter colors for more visibility. Dyes over the black didn't do much, maybe some-kind of spray paint ??? Thanks
motor32 is offline   Reply With Quote
Old April 18th, 2015, 06:46 AM   #2
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Old April 18th, 2015, 08:08 AM   #3
no
Old April 18th, 2015, 08:21 AM   #4
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I saw a guy once that had his airbrushed... Looked decent, doubt it lasts very well. I've seen folks spray paint shoes, looked less ok but changed the color, still doubt it lasted well
Old April 18th, 2015, 08:45 AM   #5
liberpolly
Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold.
You can glue sheets of thin colored vinyl to it. Lots of work though, you must cut them to shape...
Screw the inscrutable, eff the ineffable.
liberpolly is offline   Reply With Quote
Old April 18th, 2015, 08:47 AM   #6
Just put on a mesh hi vis vest Steve. Painting, dyeing, bleaching riding leathers has fail written all over it.
Old April 18th, 2015, 08:55 AM   #7
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Buy lighter leather and stop buying black leather, would be one suggestion. Another suggestion, get custom leathers made in the colors you want.
antiant is offline   Reply With Quote
Old April 18th, 2015, 09:05 AM   #8
like csmith said- hiviz mesh. get a yard of it at the fabric store and cut it to shape and sew it onto the leather.
Old April 18th, 2015, 09:57 AM   #9
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Dyes darken, not lighten; and paint probably wouldn't hold up very well (elements, movement while wearing it, etc). If you want to have a unique color, start with a white jacket and use leather dyes. Also make sure to put a strong waterproofer over it.
For reference, I've done this. Dyed one of my jackets to a blue/purple last year.
Old April 18th, 2015, 10:01 AM   #10
you can even use food coloring to dye leather and its fine (i've done this for sheaths) but paint is a nono on leather. enamels and acrylics or anything with a solvent will eat away at the leather making it brittle and much more likely to tear. maybe water color paint would be okay.
Old April 18th, 2015, 10:26 AM   #11
Not to mention what it could do to the stitching. ijs
My wife's mom is the queen of dyes and bleaches... carpets, furniture and drapes. To go from black to a lighter color, your gunna have to used some sort of bleaching agent before going to another color. Even if it was possible with good looking results, it most likely would compromise the safety of the gear.
Painting? Nathanptak 1986 - 2007 Ninja 250R Tech Talk 2 May 26th, 2013 07:56 PM
Considering Painting my Ninjette/Help! ManOfGod General Motorcycling Discussion 4 April 14th, 2013 09:14 AM
decided to do a little painting darrell85 Pictures 2 June 20th, 2012 06:39 AM
Painting rims...?! blink General Motorcycling Discussion 6 June 9th, 2011 04:12 PM
Painting Yoshi kevinlo423 2008 - 2012 Ninja 250R Farkles 11 March 10th, 2011 02:59 PM
