August 28th, 2015, 06:40 AM | #1 |
Join Date: Jul 2015 Motorcycle(s): 2004 EX250R Posts: 39
1000 RPM idle too low ?
I just got a low mileage 2004 250 Ninja running again after setting for years. Intro thread link (https://www.ninjette.org/forums/showthread.php?t=240484)
So Ducatiman refurbished the carbs and the bike starts easily no choke needed just let it warm a minute before it is ready to take the throttle. I have the idle set at 1000 RPM's and it purrs. Blip the throttle and it revs fine then returns to 1000. Will this hurt anything ? I know spec is 1200-1300 but I figure within reason the lower the better. Just worried bout oil pressure. I haven't really ridded it yet maybe after running a while it will be too low after engine is good and hot ?? Can't say enough about Ducatiman's Custom Carb service.... I woulda never dreamed it would ever run this smooth after all this time and all I have read about wandering idle issues people seems to have with these 250's Thanks, 22R88 |
August 28th, 2015, 06:52 AM | #2 |
I have mine set at about 1,400, seems to like it just fine, the bike is made to idle at a certain RPM, I suggest you try, and see.
http://faq.ninja250.org/wiki/What_is...I_adjust_it%3F
August 28th, 2015, 08:05 AM | #3 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
you will want the idle set to spec for shifting, charging, oil pressure, etc etc.
also, there is no big flywheel to keep this tiny engine running, so coming off throttle at cruise could allow it to stall possibly
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
August 28th, 2015, 08:21 AM | #4 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
If you like it at 1k and it doesn't die, then don't worry about it. You can change it any time you want.
August 28th, 2015, 11:45 AM | #5 |
^^^ werd. as long as it doesn't die and it returns to that rpm consistently, go with it.
Personally I'm at the opposite end of the spectrum and make mine idle around 1500. It's nice and easy to see the needle overlay on one of the hash marks and the throttle response seems acceptable and it returns to that speed consistently. Whatever works for you and your bike. Personally I'd turn it up. |
August 29th, 2015, 08:56 AM | #6 |
Appreciate all the responses. I am just gonna wing it and see how it acts when I start riding it. Thanks,
22R88 |
August 29th, 2015, 09:18 AM | #7 |
Here... Take it for a ride. If the bike and rider are happy then go with it. If there is ANY reason to question it, raise it up to spec. It's just not worth the worry, there are bigger fish to fry.
August 31st, 2015, 03:09 PM | #8 |
Lostcause enthusiast
Join Date: Jan 2015 Motorcycle(s): 2000 EX250F Posts: 178
the other comment i would have is to make sure that your adjustments are all correct, you should tune your air bleeds until the idle is as high as possible and ideally you'd want to put a vacuum gauge on there and sync the carbs.
If you just threw them on straight out of the box they cant possibly be adjusted in, unless ducatiman is really that awesome. |
August 31st, 2015, 03:15 PM | #9 | ||
Yes he is, the only tuning once you get them back is the idle mixture screws
Dialing in the idle mixture screws Quote:
August 31st, 2015, 03:34 PM | #10 |
Vacuum synch is to synch the jetting together not the throttles. Throttles should be synched before you put the carb on (or never touched from factory), the vac just makes sure you are pulling the same vac (running as strong) on both carbs. The closer you get to perfect tuning the stronger vac you'll pull. You can just turn the screws in and out and hear the idle pick up, but the vac gauge takes some of the guesswork out of it.
I don't really understand that quote but apparently the poster who has built 'blueprinted race engines' thinks that the vacuum gauge is use for adjusting the throttle balance screw? Its not, its used for the fine jetting adjustment. Even still when adjusting the pilots, I do it with the bike fully warmed up and i give them an extra touch of a turn to the rich side just so it tips in off idle a little better, and runs better on cold starts. IMO your perfectly tuned when your cold idle is a little bit higher than your hot idle. |
August 31st, 2015, 03:48 PM | #11 |
Yeah that's my write-up, I'm saying that using vacuum sync has its faults, and reasons why, it's the set the both butterflies exactly the same, which is the point of synchronization.
Adjustment to the jetting, Is a best guess, if your not using an exhaust gas analyzer. Adjusting the idle mixture screws you can get real close by ear, assuming your listening.
August 31st, 2015, 06:47 PM | #12 |
Join Date: Jun 2013 Motorcycle(s): N650 (and others) Posts: 408
After I did valve adjustment + sync, my bike would also idle around 1K, but it was a lot happier around 1.4K, as the idle could vary a bit on temp, phase of moon, etc.
September 11th, 2015, 03:17 PM | #13 |
You know, Mr Ghostt, this was bothering me, partially because i felt bad about the smartass response, and partially because I'm more or less self taught and have picked up some bad habits/preconceptions along the way. I'm not sure if i ever was actually taught how to synch carbs, or if i learned it from a book or something on the internet or what.
So, I asked two friends of mine, one who races later-model sportbikes (he has a '04 cbr600, an '01 R1 and an '01 RC51) how he does a carb synch- he said that on his R1 he has to do it frequently as you loose the setting when you remove the carbs, and he said that he only adjusts the throttle balance. He also said that by turning it 'one **** hair' the bike will go wildly out of tune, and since its a four, you absolutely need the synch tool to tune the throttles. Certainly less forgiving than our ninjas, and since you can't do it on a bench, the vacuum gauges are the only tool available. The mix screws many of the modern sportbikes can't be reached with the carbs on the bike, so best case you can set them, try them out, take the whole bike back apart, make a small change... ugh... there is a reason I don't mess with modern sportbikes (the ninja doesn't really count) The other guy I asked is the best motorcycle mechanic i know, a guy who has raced on a national level and owns a moto shop and does vintage restoration and customs that have been on 'bikeexif' He texted me back 'both' haha. Not a big texter, next time i see him in person i'll ask him for a better explaination of how he goes about tuning with a vac. gauge. I can get more out of him when he's got a beer instead of a phone in his hand. On the older bikes (cb's; gs's; kz's) that i've worked on, seems like the vac didn't respond a lot to the throttles being synched. Hell my CB450 had a goofy piece of bent metal strip connecting the carbs and you just kinda bent it back and forth to get the carbs running together. The mix jet however would take it from burbling like a kitten to choking and sputtering in less than a 1/4 turn. Long story... well... long, i apologize for my snotty response and I learned a lot doing some digging. I think if you try adjusting the pilots with the vac gauge on there, you will see how beneficial it can be, my two cylinders are running about a 1/4 turn off from each other on the pilot... the idle still hasn't broke the paint dot from the factory, i should probably see where it is at and i might find a bit more throttle response. |
September 11th, 2015, 03:30 PM | #14 |
No worries, I didn't, and almost never get offended by responses to my post/write-ups.
I understand that some will stand by what methods for for them. My write-up of carburetor synchronization is my method, and I present the reasons why, and the faults with vacuum synchronization. The final choice is yours, and yours alone. Thank you for explaining your actions, and as always I respect your rights to have an opinion, as well as everyone else. Sláinte!
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
High Idle RPM (during/after riding) | Maielstrom | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 23rd, 2013 07:05 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Raising Idle RPM | Archerzz | 1986 - 2007 Ninja 250R Tech Talk | 4 | June 14th, 2011 12:51 PM |
High Idle RPM... | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 20th, 2010 09:59 PM |
