June 27th, 2016, 08:39 PM | #1 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Tire Pressure Gauges
What do you use?
June 27th, 2016, 09:15 PM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
i prefer the kind that read in psi
Last futzed with by rojoracing53; June 28th, 2016 at 04:38 AM. |
June 27th, 2016, 11:00 PM | #3 |
I think he is asking about brand, make or model.
I can 100% guarantee you will not like my answer and that is a fact. So here it is... Dollar General $2 gauge, when Kevin is with me, I will use his expensive one. For full disclosure though, I have had my dollar store gauge tested for accuracy by a vendor that has the tooling to test gauges. It is 1lb off and has been for years. At this point it has served me well... AFTER earning my trust and double checking it against other known accurate gauges.
June 27th, 2016, 11:14 PM | #4 |
cadd cadd cadd
MOTM - May '15
I have 3 gauges. All give me a different reading. FML.
Riding it like I financed it. |
June 28th, 2016, 01:31 AM | #5 |
I too have an inexpensive pencil type, it suits me fine.
Here some reviews on other types by the friendly fokes at WebBikeWorld http://www.webbikeworld.com/Motorcyc...compressor.htm
June 28th, 2016, 03:04 AM | #6 |
Join Date: Dec 2015 Motorcycle(s): Thruxton R, R6 450 triple, EX300 (sold) Posts: 263
Another for random cheapo pencil type. I don't think I've ever owned a nice, branded gauge.
Using it back to back with other people's gauges, it is close enough that I can't tell the difference. But also, as I have told others, I am not at the level of being able to tell the effects of small tire pressure changes. I can sense 3 modes: way too low, range that works, and over pressure. If it's in the range that works, I can't tell you the difference in a psi up or down. |
June 28th, 2016, 04:33 AM | #7 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
I have several cheap gages and the tire chuck on my compressor has a gage as well. They all read about the same. For street riding withing a pound or two is accurate enough for me.
Although I just realized that this was in the Ninjettes at Speed section and there probably are many track racers that 1 PSI does make a difference for. |
June 28th, 2016, 05:13 AM | #8 |
Join Date: Oct 2015 Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike Posts: 556
MOTM - Nov '15
Since this question was posted in the "speed" forum, I'll answer it this way:
What really matters isn't so much the number on the gauge, but the results that you get in tire performance. As long as your gauge is consistent in the readings that you get with a given pressure, you can use it to accurately make relative adjustments for your tires. For example: if my gauge consistently reads 2psi below any actual given pressure that's ok because I can still make use of it for consistent adjustments to get the desired end result. What is important when you want to be consistent is to use the same tire gauge every time. I have a little digital gauge that was given to me by a salesman in the mid-Nineties. Amazingly, it is still working on the original battery even though it is 20 years old! That is the only gauge that I use. Remember, that the faster you go, the more accurate tire pressure adjustments will matter. |
June 28th, 2016, 05:44 AM | #9 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
dis one: https://amzn.com/B004APM12G
June 28th, 2016, 12:53 PM | #10 | |
EX500 full of EX250 parts
I used to have an Accutire similar to the one Yakaru linked, but without the depth gauge. It worked well enough for my basic needs. I now have this one from Slime. The illumination is handy, and the angled tip can make it easier to deal with small clearances between the valve stem and wheel hub (the drum brake on the Vulcan rear was a pain).
June 28th, 2016, 04:52 PM | #11 | |
MOTM - Jan '16
Best thing would be to have a gauge that has been perfectly calibrated, and if you don't have your gauge, to have another perfectly calibrated gauge instead. |
July 1st, 2016, 06:15 AM | #12 |
MOTM - Nov '15
There is no such thing as a perfectly calibrated gauge. Only ones that are accurate enough to do the job.
July 1st, 2016, 06:22 AM | #13 |
Vanilla Gorilla
Join Date: Feb 2012 Motorcycle(s): '11 Triumph Sprint GT & '06 625SMC Posts: 79
I had a crap stick gauge lie to me, and ultimately cost me a prematurely worn out front tire, so this is all I use. It's pricey, but about as close to spot on as an air gauge can get...
July 1st, 2016, 06:49 AM | #14 |
July 1st, 2016, 06:57 AM | #15 |
At mid-O I discovered that my dial gauge, which I thought was decent, was wildly off.
Dropped by Summit Racing on the way home and bought a liquid-filled dial gauge. As soon as I arrived back in CT Cycle Gear ran a Father's Day special on a digital gauge, for a lot less than the liquid-filled one had cost... and I've heard/read nothing but good stuff about the accuracy of digital gauges. So back the Summit gauge goes. This is what's now in my box: Liking it so far, and the right-angle chuck works well on bike tires (for those who don't ride a larger bike, the dual front discs can be a huge PITA). If I ever get the opportunity to check it I will. I believe that the guts of many of these digital gauges are the same. The $90 Motion Pro pictured below has the exact same display and buttons as my $25 Cycle Gear special.
July 1st, 2016, 12:05 PM | #16 |
#squid
MOTM - Jul '16
I've been debating the investment of the very accurate motion pro gauge.
July 1st, 2016, 12:28 PM | #17 |
Vintage Screwball
MOTM - Mar '16
I've got an Accugage and have been using it for 3 years now. When I set the Ninja's tires to the Dunlop specs, every time off the track they read a perfect 10% increase in pressure. I'd say it's pretty accurate and reflects pressure changes accurately too. IMO, the range of the gauge will also help determine it's accuracy. For example, a dial gauge that only reads to 50 PSI would show a much smaller variation in pressure than a gauge that goes to 100 PSI. Probably similar with digital also but I'm not 100% certain on that. Ideally, with most things, you want the pressure or reading you will be using to fall in the middle of the range of the device.
Also use it on the Vintage race bikes, of course keeping a log of tire temperatures and other things and it's been determined to be accurate, or at least consistent, there as well. https://www.amazon.com/Accu-gage-Tir.../dp/B0006O2S0U
Goin' fast on slow bikes! |
July 1st, 2016, 12:49 PM | #18 |
That's the same one that started reading about 10 psi high on me.
The way we determined this was by checking against an inflator with a digital gauge, and also a second gauge that agreed with the inflator. When I got home and had both the Summit liquid-filled gauge and the just-purchased digital gauge at the same time, I did a three-way compare and yep.... the AccuGauge was off. Mine had a rubber housing and a different chuck, but it was the same face. Lesson is that these are mechanical devices and therefore may fail.
July 1st, 2016, 12:51 PM | #19 | |
Vintage Screwball
MOTM - Mar '16
July 1st, 2016, 07:12 PM | #20 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
I use a cheapo tire pressure gauge. Its accurate to itself within a half pound. The actual pressure doesn't matter at all, as long as its the best for Mr, my bike, and the place I'm riding. I experiment whats best, remember it, and only test with my gauge. On my MX bike I've gotten to the point I don't even use a gauge. I feel the tire with my hand and get it close enough for the first practice, and then at the track I use a compressed air tank and dial it in by feel.
Because Unregistered sucks at riding. |
Tire pressure gauges | Soujyu | General Motorcycling Discussion | 44 | April 4th, 2015 07:20 PM |
Best tire pressure ... | Davis937 | 1986 - 2007 Ninja 250R Tech Talk | 17 | February 17th, 2014 02:25 PM |
Bt-45 tire pressure | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 5th, 2011 09:05 AM |
Autogage Gauges, oil pressure? | J Walk | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 21st, 2011 08:49 AM |
Tire pressure.... | Davidb1986 | 2008 - 2012 Ninja 250R Tech Talk | 31 | May 24th, 2010 12:59 AM |
