March 31st, 2019, 05:44 AM | #1 |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge,2020 aprilia dorsoduro, 2014 yamaha fjr, 85 yamaha fj 1100 Posts: A lot.
MOTM - Feb '18
freaky carb/fuel issues
if you read my devil's whip thread, i had major problems with fuel/carbs on my ride. getting ready to tear into and find the problem. i did check petcock, mini fuel filter so far which looked ok. almost felt like water in gas or one of my circuits was partially restricted.
"trying not to get old" |
March 31st, 2019, 10:00 AM | #2 |
Did the condition present itself and degrade during the ride?
Before pulling carbs, drain the bowls and analyze. Water and fuel should separate, easily visible by eye. If water present, may save you a carb pull and solving is obvious. If no water, nothing less than a carb pull is then called for.
Custom Carb Service |
March 31st, 2019, 11:20 AM | #3 |
You mentioned it occurred after hitting some big potholes/bumps. Wonder if something got shaken out of place?
March 31st, 2019, 11:39 AM | #4 |
MOTM - Feb '18
it started after pothole hits. subtle at first, just low end, partial throttle. got progressively worse as the ride progressed affecting all circuits. got to the point with any chop of the throttle would cause massive hestitation.
March 31st, 2019, 01:56 PM | #5 |
curious...are you running adjustable clip type needles?
March 31st, 2019, 02:07 PM | #6 |
MOTM - Feb '18
nope, stock needles shimmed with 2 washers. actually these are green bikes/godzilla carbs. dannoxyz rebuilt// cleaned red bikes carbs which now are on green bikes(which i sold)
March 31st, 2019, 02:29 PM | #7 |
loosin' me with the green, red, godzilla stuff
March 31st, 2019, 03:07 PM | #8 |
So carbs on this bike hasn't been professionally cleaned/refurbished.
Usual suspects: - clogged tank vent? Work better with gas cap open? - petcock's vacuum hose. What vacuum level does it give to petcock? Measure how much petcock flows in 60-seconds at that vacuum level. - needles, try with 1 washer Seems hitting bumps did something, i'm just not clear what could happen to carbs by bumps. - |
March 31st, 2019, 03:11 PM | #9 |
MOTM - Feb '18
i changed out vacuum hose at truck stop when i had issues. i will tear into it tomorrow.
March 31st, 2019, 03:22 PM | #10 |
there are a couple oddball scenarios possible from extreme shock, but in any event, at this point...this is what is needed
March 31st, 2019, 04:04 PM | #11 |
March 31st, 2019, 07:00 PM | #12 |
I had the same problem on my 2012 this week after the bike was sitting for 6 months, i try to start it but no luck so i took the carbs off the bike took the bowls off the carbs and found some nasty gel in it,so i clean the carbs put them back try to start it again bike would start and die start and die,so i decided to drain the gas out of the tank to put fresh fuel in it, instead water was coming out for about 10 seconds and than gas started to come out so i put half gallon of fresh gas in it after 3 tries bike started fine and runs good now...Ethanol in today fuel it's the problem with water in the tank and gel crap in the carbs
March 31st, 2019, 07:09 PM | #13 |
Rinsing all fuel-related parts with acetone should clear out water. It dissolves both polar and non-polar compounds.
April 1st, 2019, 02:02 PM | #14 |
MOTM - Feb '18
carbs pulled no evidence/clues so far
April 1st, 2019, 06:14 PM | #15 |
Remove rubber tubes holding carbs to head. Remove all hose clamps completely.
Carefully inspect every inch of these tubes inside & out. Pry on edges. See if there are any cracks or tears. Did you have upper and lower mounts of airbox firmly screwed to frame? |
April 2nd, 2019, 12:52 AM | #16 |
MOTM - Feb '18
ok , i will check it today
HELP!! Carb Issues!! | xXecuterXx2 | 1986 - 2007 Ninja 250R Tech Talk | 39 | May 11th, 2015 08:27 AM |
Carb issues? | Citykid | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 28th, 2014 08:43 PM |
Carb Issues: you're not alone. | Ninjinsky | 1986 - 2007 Ninja 250R Tech Talk | 16 | August 11th, 2014 12:27 PM |
Fuel tank/Fuel gauge issues | coolcatjames | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 23rd, 2012 06:25 PM |
carb issues | peeweecollins | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 20th, 2011 09:06 AM |
