July 8th, 2021, 10:22 AM | #1 |
Join Date: Jul 2021 Motorcycle(s): 1989 Suzuki gsxr1100 1990 Honda VFR750F 2012 Kawasaki ninja 250r Posts: 3
Hello from la puente ca
Hello everyone. I'm new to the small bike world.
Just got my 2012 2fiddie fired up. Had to derust the tank and clean the carbs. Finally have it not leaking fule out the carbs. I now have it stumbling off idle and stalling. |
July 8th, 2021, 10:37 AM | #2 |
Hello Jorge, welcome to the board!
Stumbling off idle is a very common problem, usually caused by not fully clean carbs. |
July 8th, 2021, 10:53 AM | #3 |
The carbs just came out of an overnight soaking in a brand new bucket of Chem dip!
But I can put them in another night! |
July 8th, 2021, 11:39 AM | #4 |
That's good, but soaking usually won't do the job. Threading a wire through each small passage in the idle circuit can help, as can ultrasonic cleaning.
July 8th, 2021, 04:05 PM | #5 |
Join Date: Jul 2013 Motorcycle(s): 2007 SV650S 2005 EX250F Posts: 487
Jim's dead right. I could never get these 250s to run properly until I went through all the passageways with copper speaker wire. They're like any other carb'd bike... just WAY more sensitive to cleaning!
Don't think, look! |
July 8th, 2021, 07:23 PM | #6 |
Welcome
"It ended up being the loose nut behind the wheel" |
July 9th, 2021, 12:29 AM | #7 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
Welcome
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package |
July 9th, 2021, 08:49 AM | #8 |
So she runs out nice now
July 11th, 2021, 12:16 PM | #9 |
Hello and welcome!
July 11th, 2021, 12:45 PM | #10 |
Greetings! Please share your experience.
July 17th, 2021, 02:55 PM | #11 |
Welcome!
July 31st, 2021, 09:03 PM | #12 |
Welcome!
August 4th, 2021, 04:10 AM | #13 |
Retired motorcycle Mc.
Join Date: Jul 2021 Motorcycle(s): 2012 Kawasaki Ninja 250R, 2021 CSC TT250, 1977 Triumph Bonneville 750cc,2001 Honda XR650L. Posts: A lot.
A person in the city I was born in ! How about that ! HAHAHA
Welcome. yep stumbling off idle means dirty carbs I don't care if you cleaned them with Kryptonite !, or sent then to Nasa to be repaired...their still dirty ! I found some neet tiny brushes on Amazon for carb cleaning but in the past I usually just used a OXY/Accet. torch tip cleaning tool... which is a little set of wires with file stamped into them... they work great... that and compressed air.... I never had much luck using the DIP method although they do look cleaner on the outside when your done... do a thuro cleaning... every thing that can be removed remove ! and make sure you can get air down each passage. ! I just had to do the same thing to my Ninja and now it runs great when it's warm make sure you set the airscrews ( I set mine a little rich and it wasn't quite enough) .... Welcome aboard ! Bob.......
Its too late when you've gone too far ! |
