January 20th, 2012, 01:12 PM | #481 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
Sorry for not being completely clear, I thought there might be some confusion about this. What I meant is, I used the Acceleration cable and wrapped around the pulley in the correct direction (counter clockwise in my case since the TB is upside down) however, instead of attaching it to the slot in the pulley where it's supposed to go (all the way around, where if you do, it doesn't allow the TB to fully close) I attached it to the Deceleration tab, only backwards. This allows me to control the pulley the way it's supposed to be turned, and solves the issue of not having enough cable length.
ATGATT |
January 21st, 2012, 11:24 AM | #482 | |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
I got my bike up and running last few days. been good. Feels alot faster, smoother pulls, and louder. Its nice . had some battery issues (not related to the efi kit) had a few broken cells inside, has causes the bike to turn off on me during turns or not down shifting throught the gears. But besides that the learning process has been really good. just need to adjust my idle a bit higher, right now 1000-1200rpms. so just a bit of tweeking. Just need to take it on the freeway and test it on there now. And i love the cold start, starts right up even with a crappy battery.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
January 21st, 2012, 12:20 PM | #483 | |
This is the first pre-94 bike being converted. It did require some communications between me and him to sort out the issues. EFI related or not related. Now we know for sure, it can run pre-94 bikes. And later on, the harness will be pin-ed exactly for pre-94s. So we will have 3 versions of harnesses: new-gen, pre-gen, pre-94. Hopefully nobody will convert 1987-or-before bikes. Those bikes have different stators and pickups, and are not compatible with this EFI kit. |
January 21st, 2012, 12:57 PM | #484 |
Regarding keeping the lengths of tubing as short as possible, is it more beneficial to keep the high pressure hosing shorter or the regular fuel line when in a compromise? I only ask because the way I have it set up, I can either move the pump to a position for short high pressure lines (to the injectors), or short normal lines (from the tank and the return lines)
ATGATT |
January 21st, 2012, 01:05 PM | #485 | |
January 21st, 2012, 04:27 PM | #487 |
where is the stock ignition controller and what does it look like? I have no idea what I'm looking for. Trying to install that CDI plug
EDIT: Never mind... I found it, in the rear of the bike behind the battery NEW QUESTION: Which one is injector 1 and which one is injector 2 lol? Remember my TB is upside down, I'm just not sure which one goes where. Does being upside down even make a difference? Is injector 1 ALWAYS the left cylinder (as when seated on the bike) and injector 2 is ALWAYS on the right? also, @ecotrons is there an adapter for the connection between the kit and the computer for a USB or something? I see it in some of the pictures of the kits, but that's something I did not receive. I don't have a connector for that type on my laptop. I can't get it to work so far. I've connected the CDI plug, I connected the map sensor, I connected injector 1 on the left cylinder and injector 2 on the right cylinder (still waiting for some confirmation as to whether or not this is the correct way), connected the positive and negative of the harness to the battery, connected the power to the fuel pump, the tubing for the fuel system is correct, I've fixed all fuel leaks, engine and air temp sensors are installed... I turn the key and the fuel pump works the way it's supposed to, but I crank the starter and the cylinders will simply not start combustion.
ATGATT Last futzed with by Scattcatt; January 21st, 2012 at 08:28 PM. |
January 21st, 2012, 08:23 PM | #488 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
Everything associated with the left cylinder should be considered #1 (Injector #1, o2 sensor #1) no matter how you have the throttle body installed.
There is a serial port attached to the wiring harness that is used to interface with the ECU. You will need your own usb to serial adapter if you don't have a serial port on your laptop. |
January 21st, 2012, 08:33 PM | #489 | |
Does the map sensor HAVE to go to cylinder 1? Cylinder one already came pre plugged for me, so I threw the map sensor onto cylinder 2. I'm going to reverse these anyway for the heck of it to see if that changes anything, also, turned out I didn't have the throttle position sensor attached, still not sure if that's the cause of my problems but I'll give things a shot here once I get everything fixed
ATGATT |
January 21st, 2012, 09:02 PM | #490 |
Make sure the car is NOT running.
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
January 21st, 2012, 09:41 PM | #491 |
Why's that? Too many amps with the alternator spinning? I was worried that might be the case, I'll be sure to leave it off. MAP sensor is on cylinder 1 now, cylinder 2 is plugged, the TPS is connected. I don't think I'm missing anything here... Jumper cable time...
Still no joy after trying the jump... Is engine flooding a possibility here?
ATGATT |
January 21st, 2012, 09:56 PM | #492 | |
Is the engine cranking at all?
January 21st, 2012, 09:58 PM | #493 | |
*later in the evening* Okay gave it another shot with the jumper cables, the bike backfired one me twice which gave me a glimmer of hope, then the throttle body blew off from cylinder 2 with a puff of white smoke... I'll reconnect the TB tomorrow, not in the mood for getting frustrated further lol...
ATGATT Last futzed with by Scattcatt; January 22nd, 2012 at 12:04 AM. |
January 22nd, 2012, 04:59 AM | #494 |
Could be something with the ignition timing
January 22nd, 2012, 08:17 AM | #495 | |
January 22nd, 2012, 08:18 AM | #496 | |
January 22nd, 2012, 08:26 AM | #497 | |
So in general, its a bad idea to jump from a running car. However, its probably not the end of the world if you do once or twice.
January 22nd, 2012, 08:52 AM | #498 | |
If the sensor is on cylinder #1, you will need to get a new programming file from Matt and update the ECU. If you have the option to put it on cylinder #2 that is what the stock programming is setup for. |
January 22nd, 2012, 11:08 AM | #499 |
I'll just stick with the car off for the jumping for now, and I'll even disconnect the battery from the car which isolates the battery entirely from the car (no chance of that circuit spike damaging the car then). I'll go ahead and reverse the MAP sensor... AGAIN It's such a pain dealing with that little MAP sensor for an upside down TB. So there you go! For those of you who haven't started the installation yet, you might find it much easier to deal with some of the things by installing the TB right side up.
ATGATT |
January 22nd, 2012, 02:31 PM | #500 |
okay, after the changes listed above, the bike started up briefly (never achieved full idle power, more like a pocket of fuel made it through, that's all) then sputtered out. I'm assuming that's a plus for my connections now at the very least. Several attempts after this though, the bike simply will not start, it cranks, no pops or anything, no leaks, no kinks in the hoses, the pump works fine (you can hear it working) no back fires, and the TB is holding fast the way that it should.
@ecotrons I'm having issues with ProCAL, I have tried windows XP service pack 2, 3, and windows 7 for compatibility just to see if any would work, I've moved the .A2L and the .cal files over into the program folder but I still don't have the menu on the left side. Is there something else I could be doing wrong? Ha! Got it! 3rd or 4th uninstall/reinstall somehow managed to get it to work lol!
ATGATT |
January 22nd, 2012, 03:14 PM | #501 | |
Sorry to reply a little late, not on this forum for one day. Next time anybody has some trouble, and want a fast reply, please shoot me an email to info@ecotrons.com. From what you have so far, it looks like the Pickup / MAP sensor are not synchronized. Meaning the ECU could not detect which is the cylinder #1. It could cause misfire: meaning your ignition timing is totally wrong. That's why you can not start. MAP sensor is used to detect cylinder #1. I need to double check what software is in your ECU. Now please log some ProCAL data for me. For ProCAL to work, you need to load A2L and CAL file into ProCAL (click "open" in menu... and reading the manual always helps). Matt |
January 22nd, 2012, 03:17 PM | #502 | |
http://youtu.be/Ms8fQm8bZiE |
January 22nd, 2012, 05:34 PM | #503 |
Mission Accomplished! Thanks a ton @ecotrons for the email help! Turns out if you have the MAP on cylinder 2 (since the TB is upside down) the tubing used to connect the TB to the MAP sensor can hit the screw used to sync cylinder 1 and 2, preventing the throttle from fully closing. Mine was stuck at about 16% open as I found out through ProCAL, this didn't allow the engine to start. Once I moved the MAP sensor tubing out of the way slightly (it's not kinked, I'd imagine kinking the tubing would be bad) the engine roared to life on the first crank. Going to put the seat on and give things a test run around the neighborhood then fix that rich spot down on the low end rpm (she pops when the throttle is let off) overall, very satisfied so far!
*Later* The system is on the bike and working. Just got home from the first test run. The bike starts up great! No problems there whatsoever, the idle is perfect per the tach on the dashboard (1400-1500 on ProCAL though, no worries here though) The power curve is very wild though, there is a pretty good lag from idle to anything over about 25% throttle which I'm assuming is because it might be running rich. Trying to blip the throttle on downshifts is not possible with this throttle lag, perhaps with the oxygen sensors this will auto correct, but I'm going to check it out on ProCAL and see if I can fix it myself for now. As for any additional power, for now it feels like there's less power than with the carbs, I'm hoping after fixing the power curve up this will change. This power curve also caused the engine to die at stop signs, I got around this later by carefully manipulating the throttle to keep it alive, but this is an obvious problem. I'll let you all know how it goes after I fiddle with ProCAL
ATGATT Last futzed with by Scattcatt; January 22nd, 2012 at 07:20 PM. |
January 23rd, 2012, 07:29 AM | #504 | |
I'm having the same low end problems as you. I don't have it logged with procal yet (tonight). If you find the solution, post it up here. |
January 23rd, 2012, 11:17 AM | #505 |
Did you try the eco/rich switch just for the heck of it? That's one thing I didn't think about, since the mapping for rich is obviously going to be richer than normal, if the performance decreases then we'd be able to say for certain that our problem is being too rich. (though I'd imagine the popping, smell of gas, and light smoke are already enough signs that it's a rich problem). I'll give it a shot later tonight for the heck of it though. I'll be sure to post my findings up (if any) through ProCAL when I get to it later tonight, I have class during the week so my progress may be minimal due to time constraints
ATGATT |
January 23rd, 2012, 11:37 AM | #506 | |
Looking at the procal recorded data will tell you if you are rich or not. If the o2 sensor output is constantly reading above 450mv then you are rich. The O2 sensor should be bouncing high-low the entire time. |
January 23rd, 2012, 02:20 PM | #507 | |
ATGATT |
January 23rd, 2012, 04:06 PM | #508 | |
So I approximated at what engine temperature it started running poorly and adjusted the warmup factor to stay at that value for the rest of the table. This effectively made the whole map richer for the warm temperatures. The bike was perfeclty ridable like that, but mileage was poor ~35 mpg. With O2 sensors installed, I expected the warm running problems to be effectively eliminated but I need to do a little tuning to get it right. I will post back when I've worked a solution. |
January 23rd, 2012, 04:18 PM | #509 |
I havent installed mine yet... soon soon been super busy... but I thought the stock map provided by ecotrons was supposed to be pretty stable and the O2 sensors are supposed to help fix all these rough situations by auto adjusting.
Is it really necessary to mess around w/ the map or can you just run it a few times and let the O2 auto adjustments fix itself?
January 23rd, 2012, 05:10 PM | #510 |
I have emailed Matt recordings of my bike running. My bike is running rich being that just at idle the o2 sensor reads over 800. Hopefully Matt will get back with me soon.
January 23rd, 2012, 05:35 PM | #511 |
Where did you guys end up putting the engine temp sensor?
January 23rd, 2012, 05:42 PM | #512 |
I put it where @forbitel put it, right on top of the engine. I took one of the screws out of that green cap thing on the top of the engine cover (not the cover bolts themselves) http://www.flickr.com/photos/forbite...4273/lightbox/
ATGATT |
January 24th, 2012, 07:06 AM | #513 |
January 24th, 2012, 02:59 PM | #514 |
Alright, out working on tuning the ECU and I got some good results from doing only one basic thing. It solved my stalling issues for the most part it seems (rpms did dip low, but only ONCE while I was test driving) All I did was change the fuel cut off rpm from whatever it originally was (1820 or something like that) and set it to 15300 for all of the cells. Since our engines normally cannot rev that high to begin with, this means that the fuel is always flowing at all rpms similar to the carbs we're all used to. With this I can now blip the throttle as I downshift, and the engine is more stable when coming to a stop or disconnecting power to the wheel in general (aka, disengaging the clutch, or putting it in neutral, if that's your thing). I suppose this is not necessary, you could simply increase the number slightly if you are having stalling issues so the engine will come back to life earlier which should also correct for the stall. However, this may not allow you to blip the throttle depending on where you set this rpm. Overall with the change, I'm very pleased! I feel more confident on the road and with the system as a whole, more than enough for me to even ride the bike to class tomorrow and show her off to my friends! Wait... What friends...? Well that's besides the point... I'm very excited to continue working with ProCAL now that I have a tiny grasp of what I'm doing, and I'll post back once I get her running even more smoothly. So far though, by far my favorite benefit of this product is when the rpms are about 3 or 4k and in 6th and then flooring it. Do you hear that? Of course you don't! That's the sound of no more popping! shout out to @ecotrons for helping me out with ProCAL, I can only imagine how much time we're probably all taking up of you with our needy emails all of my emails have been responded to in an extremely timely manner! And thanks for developing this kit! I'm getting more and more eager as I learn to see what I can make it do! It's only a matter of time before things are as close to perfect as humanly possible!
ATGATT |
January 24th, 2012, 03:39 PM | #515 |
Good going scattcat. I may try that.
January 24th, 2012, 05:48 PM | #516 |
Hey I just started the install but got stuck installing the throttle body. The air filter side doesnt fit the throttlebody even with the included hose. Did anybody use the stock airbox? If you used pod filters, what part did you find worked best? If you could include also where you purchased it that'd help me out as well. Thanks.
January 24th, 2012, 06:17 PM | #517 | |
ATGATT |
January 24th, 2012, 06:24 PM | #518 |
@Scattcatt Interesting. Did the boots fit snugly? The adapter fits into the airbox boots a little too loose. I can tighten the clamps all the way and still slide the adapter out no problem. I know after everything is put together, there isnt room for movement so I'm not worried about it falling out but I'm concerned about air leaks. I wonder if I can just seal it up with silicone caulking or something. Heh. There isnt much pressure there so I dont think it's that big of an issue.
Ideas?
January 24th, 2012, 06:36 PM | #519 | |
ATGATT |
January 24th, 2012, 06:47 PM | #520 |
I haven't gotten that far yet, I am still working on the cable mounts and pulley. However, I did notice that the airbox tubes are bigger on one end than the other. You might check to make sure you have them going the right way.
OEM Fuel Injection Kit and other 250 race mods | Shadowwolf1117 | Motorcycle-related | 0 | April 3rd, 2015 10:51 PM |
Ecotrons EFI (Fuel Injection) kit Group Buy: June 2013 | n4mwd | Motorcycle-related | 94 | October 12th, 2014 08:36 PM |
Ecotrons EFI Group Buy: March 2013 | n4mwd | Motorcycle-related | 124 | May 20th, 2013 10:15 PM |
Ecotrons EFI for ninja 250 (GROUP BUY) | ninja_thresh_hold | Motorcycle-related | 101 | March 4th, 2013 05:45 PM |
DWG Waterproof audio kit group buy. | Buffalony | Motorcycle-related | 0 | March 1st, 2009 11:57 AM |
