December 27th, 2014, 10:46 AM | #41 |
Join Date: Dec 2014 Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100 Posts: 185
My suspension guy is doing what he call a "Frankenshock" for my 300. It's parts from a GSXR shock mixed with parts from a ZX6r shock, plus some custom valving. He said it is much better than the stock GSXR shock conversion. Having ridden his 250 I can say that it really does seem to work well. Will let you know how it is once I get mine on the track, which will hopefully be in a week or two.
January 6th, 2015, 09:01 AM | #42 | |
Join Date: May 2014 Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F Posts: 588
My problem is that our club racing for the 250 supersport class (and Ninja 250 Cup) allows modifying the rear shock, but does not allow modifying the airbox (which is needed for the ZX6) and the links have to be stock as well. So unless the ride height is about the same and it can go in without interfering with the airbox, I can't really use it. It looks like most of the other 250s in the area use a GSXR shock and just deal with the slightly lower ride height. |
January 6th, 2015, 10:34 AM | #43 | |
Fighting Texas Aggie '05
January 6th, 2015, 05:47 PM | #44 |
Keith Hertell at Road & Track (San Antonio) is who I use. I believe he did say that the airbox was going to need to be modded, which in my case is not a problem because I am going to switch to a pod filter.
January 6th, 2015, 09:59 PM | #45 |
If you don't mind pm me the cost and contact info, and or anything else you care to share about your hybrid
January 7th, 2015, 10:42 AM | #46 |
January 9th, 2015, 05:13 PM | #47 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
The only mod you will need to make is to remove the flap under the fender and relieve a little plastic.
I've built about 20 of these shocks in the last few years for the 250 and 300's. The OEM GSXR shock is too short. We use a combo of parts from a zx6 shock and gsxr shock to make it the proper length. Revalve it and add a spring and spacer. We also machine the clevis and provide some custom spacers. Depending on certain things they run anywhere from $300 to $450 |
January 9th, 2015, 06:06 PM | #48 |
Is that providing the two shocks cost?
January 10th, 2015, 07:04 PM | #49 |
R&T Suspension
The $300 version is you sending me the shocks and not wanting the the bells and whistles like the torrington bearing, new shock spring, spacers etc.
February 5th, 2015, 05:45 AM | #50 | ||
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
Here's a link to a "how to" that I did the other day for mounting the Gixxer shock https://www.ninjette.org/forums/showthread.php?t=214238
GSXR rear shock upgrade | psych0hans | Ninjettes At Speed | 18 | May 10th, 2024 08:45 PM |
gsxr shock | alex.s | Ninjettes At Speed | 1 | October 17th, 2013 12:03 PM |
TRADE: GSXR REAR SHOCK + MISC for OEM PARTS | Nemesis | Motorcycle-related | 18 | April 4th, 2013 09:21 PM |
2005 GSXR 1000 rear shock | jasle | Motorcycle-related | 0 | February 19th, 2012 02:25 PM |
F/S: GSXR REAR SHOCK MOD + hardware | Nemesis | Motorcycle-related | 4 | February 10th, 2012 04:12 PM |
