December 18th, 2014, 04:40 AM | #41 | |
Join Date: Aug 2014 Motorcycle(s): 2013 ZX6R and a 2009 ZX6R Posts: 148
First time I met csmith12 I thought I was going to see dirt flying. He saved it, it wasn't pretty but he did save it.
December 18th, 2014, 05:05 AM | #42 |
Awesome first impression aye? I don't always blow corners but when I do, I make sure to miss the braking marker at 155mph at the end of 3000ft of straight.
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; December 18th, 2014 at 12:36 PM. Reason: just for fun! |
December 18th, 2014, 07:12 AM | #43 | |
dirty boy
MOTM - Apr '14
He says, "all weight on bars", ok got it. "No weight on feet", ok got it. Then says something along the lines of "It is easy to pick your butt UP OFF THE SEAT when you have no weight on your legs" which also means feet by association ? Well then what the hell are you using to pick your ass up if you are not using your legs or your feet? See the physical impossibility here To pick your butt up off the seat you would need to put some weight into your legs at least and probably down into your feet into the pegs I just don't see a way around this to where it would actually make sense as a riding technique what so ever.... ya dig?
December 18th, 2014, 08:08 AM | #44 |
December 18th, 2014, 09:26 AM | #45 | |
December 18th, 2014, 10:45 AM | #46 | |
Track Clown
MOTM - Sep '15
December 18th, 2014, 11:09 AM | #47 |
dirty boy
MOTM - Apr '14
even then, no weight through your legs or feet, pick your butt up off the seat ? only thing connecting you to the bike that is not mentioned as having no weigh are your hands. So somehow you are picking your entire body up through your arms from the bars?
Maybe you fart and that picks your butt off? cock push up? IDK?
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. Last futzed with by subxero; December 18th, 2014 at 01:03 PM. |
December 18th, 2014, 11:59 AM | #48 |
well you're braking at the rate of a motogp bike on the r6, so you have a lot of force pulling forward, like 18G minimum. that's more than a fighter jet! so it's like doing a handstand pushup on the bars while simultaneously operating the brake lever and clutch and shift pedal. it's EASY to pick up your butt and move it in that situation.
December 18th, 2014, 12:23 PM | #49 |
lol, let's just say some things get lost along the way of a VERY literal translation.
December 18th, 2014, 02:59 PM | #50 |
January 22nd, 2015, 12:09 PM | #51 | |
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 787
Hehehehe, this thread had me cracking up. Great discussion!
Here is my take on it. After a long straight where there is heavy braking I'd move my body over first and squeeze the tank with both knees. Some people use just the outside knee as Alex so perfectly describes below but I like to keep both knees firmly locked to the tank to prevent me from sliding forward and putting extra weight on my arms. From there, I'd downshift, initiate turn in and once the bike began to turn i'd just let my inside leg flop into the turn. Most instructors/racers out there would agree that you want to move around on the bike as little as possible, hence the reason why you get into your hang off position BEFORE the corner) and that extra weight on the handlebars should be avoided. Now, having raced AMA for two years and experienced some pretty heavy end of straight braking before, I'd say that no matter how hard you squeeze the tank with your knee or knees and how relaxed you manage to keep your arms there will still be SOME weight on your arms and hands, because you're just going that f'in fast.... The idea here is that you get your body into position before you begin your braking, you squeeze the tank with your outside knee or both knees and you move around on the bike as little as possible. Quote:
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
January 22nd, 2015, 06:15 PM | #52 | |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
My coaches always commented positively on how early I set my body position before a corner. It made the other inputs easier to manage when I didn't have to worry about putting too much physical pressure on my bike. I trust my bike (and physics) more than myself ( though I trust me, too, just not as much ), so I tend to like to get myself out of the way as soon as possible so then, on the track, there is less to worry about. Physics is the exact same every time. Barring a mechanical, rubber, or pavement failure, a bike will perform the same way in the same corner every time. A rider, however, is the wild card. Get iffiest part out of the way first, and trust the other **** to fall into place. The times I've relied on myself and forgotten that, the bike and I have suffered.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
Next dumb suspension question | adouglas | General Motorcycling Discussion | 27 | December 15th, 2014 09:28 AM |
Today's dumb suspension question | adouglas | General Motorcycling Discussion | 55 | December 8th, 2014 03:01 AM |
Hey guys, another dumb question! | Melcoal | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 5th, 2013 02:06 AM |
dumb question, but serious | cmSAE | General Motorcycling Discussion | 8 | March 15th, 2012 05:58 PM |
probably a dumb question | gsxrninja250 | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 31st, 2011 07:26 PM |
