#41 |
Join Date: Oct 2023 Motorcycle(s): Ninja 650 ninja 250 Posts: 36
I have a prejen components I own one
#42 |
The weird thing I’m finding as it’s not hanging or dipping
#43 |
have you synched the carbs, usiing a manometer?
#44 |
I have not synced them. I have the tool but I left the settings as they were. Since it just started idling bad out of nowhere. It’s strange I followed all the write ups following dynojets instructions too. I tested the coil packs too. Odd because it idles fine now but as I said when you take off it feels like you hit a wall sounds like a tractor and then it starts building power high rpm’s it loves sounds normal. I can try syncing them but wouldn’t the idle be bad too as well as high rpm?
#45 |
suggest a return to the better clip/needle setting experienced prior. A synch couldn't hurt, just to verify cylinders drawing equally, no?
#46 |
I GOT IT!!!!!!!! I moved the clip down one position and two washers on top perfect response no more tractor sound
#47 |
Finicky bike
#48 |
I mean I could probably dial it in more a tad it had a slight hiccup from one stop but it seems fine
#49 |
My guess was it was too rich than too lean dirty carb didn’t contribute
#50 | |
Congrats! Using one washer (thus "shimming" the needle) would offer the next step in further tuning, but if you are now happy, let it go.
#51 |
Would playing with the idle air screws contribute?
#52 |
I’ve never tuned a bike so I’m curious raising the needle pulls it out of the pool aren’t the pilots for fine tuning then then? Won’t make big noticeable differences.
#53 |
adjusting the needles vs pilot screws effect different areas of throttle positions
needles = midrange approx 1/4 to 3/4 pilots = idle to approx 1/8-1/4 throttle main jet approx 3/4 to wide open
Idle issues | Matthew243301 | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 15th, 2018 03:41 PM |
Having Idle issues, only running on choke..??? | rubber duckie | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 14th, 2017 08:31 AM |
Idle issues - Idle is different every time I start up. | 106 | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 13th, 2014 04:57 PM |
Idle/running issues | SDninja | 1986 - 2007 Ninja 250R Tech Talk | 15 | August 19th, 2010 02:09 PM |
Idle issues | Gyrene | 1986 - 2007 Ninja 250R Tech Talk | 15 | May 4th, 2010 11:43 AM |
