May 21st, 2013, 06:09 AM | #81 |
Fast-Guy wannabe
MOTM - Jan '13
If you know what your doing and can easy into it then you can hard chatter a bike pretty bad and still have a cushion before tucking the front. If your bike is pourly setup like my bike as in way to soft then it will chatter very eary in its potential traction so its easy to control. But for example if my fine tuned R1 superbike chattered at all I was already past the limit and I would be aleady trying to save it from crashing. When I raced chuckwalla my 250 had hard chatter in "every" corner so I'm rather comfortable with controlling it but I will say its rather annoying and does kill some of the fun after awhile.
Oh and chatter doesn't only happen going into the corner while hard on the front end. The 250 would chatter through the entire turn from initial tip in, though the apex and while I was full throttle through the sweeping corners at full lean. The chatter would cease only after I got the bike unloaded from the turn and rather vertical. |
May 21st, 2013, 06:16 AM | #82 | |
Depends on feel, corner and but basically one of 3 things
Front - (most everyone agrees on these) Continue throttle roll and loosen up on the bars Quote:
Loosen up on the bars (most everyone agrees here) If it's mild, just ignore it or be loose again (most everyone agrees) Some say, throttle modulation Some say a touch of rear brake does the trick (you hear it as "settles the chassis") [Me] I prefer a smooth roll off and/or upper body goes farther forward and head down even more (Everyone has heard of kiss the mirror but what if your already there? Then try to stick the bar in your ear lol) [/me]
May 21st, 2013, 06:19 AM | #83 |
Thank you both !!!
May 21st, 2013, 06:55 AM | #84 | |
May 21st, 2013, 07:01 AM | #85 | |
CVMA#747 Ⓓⓜⓔⓝⓣⓔⓓ ⓡⓐⓒⓘⓝⓖ
Join Date: Sep 2011 Motorcycle(s): 09 250R * 09 Yamaha R6 * 08 CBR 1000RR * 04 NSR 50 * 02 KX 250 Posts: A lot.
that is how mine likes to act... but i've slowly been getting rid of it. I hope you get your bike sorted soon. you already know you're due back at chuckie.
**CVMA#747**AFM#747R**M1GP#77**LeoVince*RaceTech*Hotbodies*Cyclemall*Bridgestone * Motorad*Dainese*PolyMoto*Woodcraft**Visit The Dmented Racing Youtube Channel* |
May 21st, 2013, 07:21 AM | #86 |
I found two interesting videos about rear end chatter
May 21st, 2013, 07:22 AM | #87 |
Fast-Guy wannabe
MOTM - Jan '13
I wish suspension was just a simple science we could solve with calculations and it is for the most part. Then you introduce the human factor and it becomes an art form with no correct answer and only vague guidelines for reference.
Damping from my 250 is from the suspension completly bottoming out and thus the tire becomes my suspension and the last I checked tire manufacturers don't make good suspension parts . More dampening would only delay my chatter then most likely make it even worse. |
May 21st, 2013, 07:36 AM | #88 | ||
You can see that the tire does more for the up-down movement than the suspension; then, it is transmitted to the front tire. Quote:
May that be the root of the chattering?
May 21st, 2013, 08:46 AM | #89 | |
It gets tricky right here when turning to get rid of the chatter at mentioned in the video about "chatter explained" since suspension works 100% as it should when it is upright and not leaned over at an angle. Either way you would still adjust rebound and compression to alleviate the situation you are encountering. I would think that most suspension tuners tune the bike to the demands of what the rider experiences in the turns since that is where most time is gained or loss in a race. More traction and power to the ground translates to faster lap times in most cases. Fast rebound: wheel returns to the ground too fast and tire bounces up (chatter po-goin') Slow rebound: bike squats, runs wide out of turns since front forks are extended. soft compression: same thing as a slow rebound. hard compression: rough riding as the rear kind of just jumps over bumps and just gets worse when you go faster as the rear end doesn't want to squat.
May 21st, 2013, 08:52 AM | #90 |
What do you mean by squat? On a sportbike under ideal conditions, the rear of a bike doesn't squat under throttle application, it rises...
May 21st, 2013, 08:58 AM | #91 | |
edit: You are essentially right, Chris: http://www.suspact.com/Anti_Squat.html I've learned a lot about suspension from off-roading trying to build 4 link and 3 link suspension
May 28th, 2013, 11:44 AM | #93 |
clutch
Join Date: Jul 2011 Motorcycle(s): L1 GSXR600 Posts: 543
June 5th, 2013, 06:44 AM | #94 |
Fast-Guy wannabe
MOTM - Jan '13
Here's what I did to get rid of my chatter
http://www.ninjette.org/forums/showt...200#post695200 |
June 5th, 2013, 07:21 AM | #95 |
[visordown.com] - Front End Chatter | Ninjette Newsbot | Motorcycling News | 0 | March 20th, 2014 04:00 PM |
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal | 1LoneWolf | Items Wanted | 3 | July 8th, 2013 02:50 AM |
Front End Chatter | Lychee | 1986 - 2007 Ninja 250R Tech Talk | 34 | November 4th, 2012 11:27 PM |
[superbikeplanet.com] - Ryder Notes: Chatter From The Front...Row | Ninjette Newsbot | Motorcycling News | 0 | August 25th, 2012 11:40 AM |
Front end clanking/chatter noise | indr | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 21st, 2010 03:40 PM |
