Old February 25th, 2012, 12:16 PM   #1561
iceknyght
Recalculating. . .
iceknyght's Avatar
Motorcycle(s): '09 250 (sold) '12 Ninja 650
Originally Posted by CZroe View Post
It's not wellnuts in general... it's Kawasaki's wellnuts. If you look at the parts fiche, you'll see that hte two that are exposed on your windscreen have different part numbers despite being the same size. That's because they can't allow the ones you are looking at to rot before your eyes or you might think less of them. Instead, every single one that's out of sight and out of mind (until you take something off) rots. Perhaps they thought they'd be fine if they weren't in the sun, but they were wrong. The ONLY two of the others I found on my bike that weren't rotted were on my right side fairing prompting me to believe that the service guys replaced them when they took the fairing off once before I did. The two under the seat, the two on the undertail near the battery box, the two on the LH lower, the two behind the dash that you were having trouble with, and the two on the headlight, were ALL completely rotten.
Whatever the reason, it's crap! I did notice that the 2 top ones on the windscreen were in decent condition, although I still replaced them as well... Just in case...
All I know is I will be replacing all the oem wellnuts as I take stuff off...
jasontracewell.com
iceknyght is offline   Reply With Quote
Old February 25th, 2012, 01:07 PM   #1562
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Originally Posted by iceknyght View Post
*Finally* got my Danmoto exhaust on! I had to widen the holes on the strap, which I needed a new grinder for my Dremel and when I was tightening the bolt for the exhaust clamp, the bolt broke (it's a piece of crap bolt! I hadn't even finished tightening it yet!), so I had to buy a new one... A 20 minute project ended up taking me forever because of that... Grrrr... But it's finally on! It has a small leak, but I have read it might seal up on its own after a few rides, so we'll see how that goes...
I'm going through the same sh!t here...but I don't know how it took you only 20 minutes...I've been grinding a single hole for the past 10 minutes and the progress is barely noticeable. Here's a pic...am I right in using the cone-like grinder for the dremel?...my back is effin' killin' me!
EthioKnight is offline   Reply With Quote
Old February 25th, 2012, 01:19 PM   #1563
EthioKnight
Super Noob
disregard my last...switched to using the drill bit...seeing more metal chips flying off...
Old February 25th, 2012, 01:20 PM   #1564
iceknyght
Recalculating. . .
iceknyght's Avatar
The 20 minutes was the time *not* including the widening of the hole and getting a new bolt... Taking off of the old exhaust and putting the new one on (after the mods) took about 20 minutes tops!
Looks like you're using the same method as me for widening the holes... Probably took me about 30 minutes total on those... I was using a diamond head bit that seemed to cut through better than just my normal bit I had... Used a bit of elbow grease as well, pushing as I would go around the hole...
jasontracewell.com
Old February 25th, 2012, 01:59 PM   #1565
Crank that dremel up to like 30,000 rpm. That will grind through metal in no time with a decent bit
Old February 26th, 2012, 08:29 AM   #1566
wandyhee
wandyhee's Avatar
Motorcycle(s): 2010 250R FI, 2006 ZX10R
installed Jardine GP1 exhaust
http://www.youtube.com/watch?v=Odji1Zg79o8
I'm Selling wider (4.5" & 5") aftermarket Wheel for N250r/N300r/Z250/Z250r
wandyhee is offline   Reply With Quote
Old February 26th, 2012, 10:07 AM   #1567
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
I took the wife out shopping for Ninjettes and then went home and did some work on the mistress. I really do miss having the 250 in the stable and am looking to remedy that very soon...so I stole a ride on a friend of mines 2006, man I miss the light weight and genuine fun factor. Nonetheless here is some moto-porn to make the post worthy
Mori-Waki radiator grilles installed:
Took out the very restrictive factory airbox.....
Cleaned out the dirt and one unlucky honey bee:
And replaced it with a carbon/kevlar/glass race box from TurnOne carbon australia (lost a ton of weight up high and gained considerable power (~8rwhp):
Then I starterd her up to make sure I didn't ruin anything:
http://www.facebook.com/v/10150542465647000
2001 SP1 RC51- #62 -Akrapovic Ti, PCIII, Colin Edward's first baby tooth, Honda Racing sticker, some Japanese doods best attempt at Engrish scribbled on my engine block, little touch of soul.
DarC is offline   Reply With Quote
Old February 26th, 2012, 02:01 PM   #1568
skip
skip's Avatar
Motorcycle(s): 2009 250r
Cool Downed a tall tan
Had a budweiser and then went on 25 mile bike ride
skip is offline   Reply With Quote
Old February 29th, 2012, 11:58 PM   #1569
EthioKnight
Super Noob
Too impatient to wait for the JIS screw driver bits and replacement hex screws for the carb cover to do the shim...I put my Danmoto slip-on today and took my baby out for a ride. Weird enough, the bike warmed up much quicker, didn't even need to use the choke and it was a bit cold outside and overall, I am not suffering from the lean symptoms I expected...I guess my bike could have been a bit rich from factory...but am still going to do the shim and desnorkel. Another thing, I had trouble with was the hanger...couldn't really bend it sit flush with the exhaust, but it's very stable in its current position. How is it with you guys (guys with the Danmoto of coarse )
Old March 1st, 2012, 01:05 AM   #1570
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Worked on some more jetting, worked on fixing that squeaking noise from the front tire. Won't know if its gone till later when I get to ride.
I'm pretty sure that you are supposed to put both sides of the hanger on the same side when you bolt it on (normally the side closest to the exhaust. That will create a tight fit. You shouldn't really have to be bending anything to make it flush as I do believe that exhaust is made for the bike. Angle it a little more vertical and screw the hanger on the same side onto the mounting point, and you should be good to go.
MikeBudd is offline   Reply With Quote
Old March 1st, 2012, 01:34 AM   #1571
cuong-nutz
cuong-nutz's Avatar
What ^^ said lol
HalfFast Racing Team
Old March 1st, 2012, 06:27 AM   #1572
EthioKnight
Super Noob
Right-o gents! Thanks!
Old March 1st, 2012, 07:07 AM   #1573
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
The way you did that hangar looks a couple of shades of F'ed up mate.
saxnbass is offline   Reply With Quote
Old March 1st, 2012, 08:21 AM   #1574
EthioKnight
Super Noob
...come now, what's with hitting the dude while he's down and out?
on a related note though, did any of have some leakage where the slipeon meets the pipe?
Posted via Mobile Device
Old March 1st, 2012, 10:04 AM   #1575
iceknyght
Recalculating. . .
iceknyght's Avatar
I agree with the other guys, need to put the hanger ends both on one side... When you first line it up, it looks like it won't fit that way, but once you get the bolt in the two holes and lined up correctly, it'll all fit snug together!
Also, I haven't done the shimming yet either and I too have noticed very little choke time is needed now, and before, I was needing it for at least a couple minutes during the warm up... I have ridden a few hundred miles with it like this so far, and overall, it seems pretty nice! The whole power band and deceleration seems smoother overall...
jasontracewell.com
Old March 1st, 2012, 10:13 AM   #1576
only way to know for sure if raising the needles is beneficial or detrimental is to raise the needles and see if it feels better or worse
better; try another. if that's better, try another, etc
worse; well common sense would say go back to the way it was before.
Old March 1st, 2012, 10:17 AM   #1577
iceknyght
Recalculating. . .
iceknyght's Avatar
Oh, I still plan on trying the shimming... I have the washers and stuff ready, I just need time to actually do it!
jasontracewell.com
Old March 1st, 2012, 01:06 PM   #1578
MikeBudd
MikeBudd's Avatar
The first time is the worst, definitely gets a crap lot easier when you have done it 10+ times O>O
Make sure you have the right tools, and it shouldn't be a problem. If you still have trouble cracking the bolts on the carb covers, I would just suggest taking them off and doing it... You really don't want to strip those f***ers.
PS: Don't get angry, one of mine was so stuck it broke in half when I was taking it out and I had a huge problem as half the bolt was stuck in the carb.
Old March 1st, 2012, 07:07 PM   #1579
EthioKnight
Super Noob
Even though it shames me to admit, it took me 3 freaking days to get my danmoto slip-on on! Most of the time was spent widening the holes on the hangar (crappy Dremel had be recharged every 10 minutes or so ), gloomy weather and no garage were also contributing factors, but all that is overshadowed by mine own thickheadedness when it came to proper installation.Oh well, thanks to you folks, I was able to get it done. I salute thee 'o great and wise seers of ninjette.org!
Old March 1st, 2012, 07:40 PM   #1580
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
Did the DIY fender mod today,
DIY Fender Eliminator by Benji Reynolds, on Flickr
thisisbenji is offline   Reply With Quote
Old March 4th, 2012, 02:36 PM   #1581
I did a lot
I cleaned up the edges of my modified intake lid by using a blowtorch lightly on all the edges
I installed R1 mirrors
http://www.ninjette.org/forums/showthread.php?t=97660
I installed Galfer SS brake lines Check out the difference in color from my old DOT 4 fluid to my new DOT 5.1 fluid! it was definitely time for a fluid change and line change, because the SS lines are rock hard now
I also started looking at how to get my CBR250 hugger on my pre-gen. Not so sure if that's going to work. There's really a limited space in there due to the oem undertail... I might have to fab something up with just the hugger portion of it instead of using the whole swingarm thing. more futzing time later. I'm not in the motorcycle futzing mood at the moment.
Old March 4th, 2012, 02:44 PM   #1582
mar3s24
mar3s24's Avatar
Motorcycle(s): 08 Ninja 250r
First time working on my ninja yesterday...changed oil, flushed the radiator, and cleaned the chain. Remove & Reinstall all fairings. Did everything myself with a some guidance from my BF. No missing screws or leftover screws. I'm proud of myself! I did all of that while recovering from a left sprained ankle.
Also modified the carbs and took out the snorkel from the air box.
"I don't mind living in a man's world as long as i can be a woman in it. " ~Marilyn Monroe
Last futzed with by mar3s24; March 6th, 2012 at 12:12 AM.
mar3s24 is offline   Reply With Quote
Old March 4th, 2012, 02:50 PM   #1583
@mar3s24 isn't working on your bike a thrill in it's own way?? It gives you a real sense of accomplishment and makes you feel like a total badass for being handy enough to do work on your own.
Old March 4th, 2012, 08:28 PM   #1584
MikeBudd
MikeBudd's Avatar
Added my emission block off plate
Old March 4th, 2012, 08:35 PM   #1585
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
I lubed my swingarm, shimmed the cush drive, changed rear sprockets from a 41 tooth to a 33 tooth and shortened the chain. I'll test ride tomorrow.
greenaero is offline   Reply With Quote
Old March 4th, 2012, 09:43 PM   #1586
oh rats! that's what I was going to do today! ugh. I'll get it eventually...
Old March 4th, 2012, 10:08 PM   #1587
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Finished adjusting the brake side rear set so everything fits with the exhaust and fairings, then put the bike back together. Gave her another nice cleaning/polishing and put a nice 2 stage polish on the carbon fiber exhaust can :P This east coast rainy weather is killing me
Old March 5th, 2012, 10:55 AM   #1588
coolbreeze
coolbreeze's Avatar
Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA
That's a huge difference (to me). Have you noticed any difference?
coolbreeze is offline   Reply With Quote
Old March 5th, 2012, 12:42 PM   #1589
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
Got the motor back in my bike Sat night, fired right up and purred like a kitten.
Now just waiting on an accessory fuseblock so i can get to work tidying up this mess of wires for my aftermarket goodies. That and order some connectors from Eastern Beaver if I can find out what the tag light plug is and if he sells it.
kamikaze is offline   Reply With Quote
Old March 5th, 2012, 12:47 PM   #1590
I replaced the screws on my on my front master brake reservoir since I stripped one screw and had to dremel a slot in it to get it out when I installed my ss lines. I also noticed that I left a couple nicks in the reservoir cap when I used the dremel I might replace that later since I'm anal. The new screws are nice and shiny, and are hexz key heads so I don't have to worry about any more stripping.
I also replaced the M5x10 screw that holds the throttle cable bracket to the carbs since that stripped a while ago.
Old March 5th, 2012, 11:38 PM   #1591
mar3s24
mar3s24's Avatar
Yup! I agree...
Old March 6th, 2012, 04:28 PM   #1592
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
took it out of the house and back to the garage, went for the first ride of the year just around the block,got all my winter mods done except for the jet kit so I didn't want to ride it to much, but once I started it up for the first time to hear the Area P, I couldn't resist a quick spin. Going to drop it off later this week at a local shop and have the jet kit installed and DYNOed.
kevheads is offline   Reply With Quote
Old March 6th, 2012, 04:47 PM   #1593
I got to ride it!!
Started on the jetting to compensate for my intake mod, and took out the silencers in my slipons. 108 mains = perfect. 2 washers is a little lean, I'll try another one tomorrow.
I also LOVE all my winter mods +2 teeth on the rear, and Galfer SS brake lines, and an opened up intake lid.
Old March 6th, 2012, 06:29 PM   #1594
cmlilley
The morning commute
Rode to work for the first time this morning. I didn't care if it was 37 when I left.
cmlilley is offline   Reply With Quote
Old March 6th, 2012, 06:37 PM   #1595
saxnbass
saxnbass's Avatar
@oreX and I cleaned our bikes so they're all clean, pretty, shiny and ready for Bike Week.
My Mods | My Bike's Ninjette Thread
Old March 6th, 2012, 08:08 PM   #1596
iceknyght
Recalculating. . .
iceknyght's Avatar
Lookin' good!
jasontracewell.com
Old March 6th, 2012, 11:58 PM   #1597
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
what did you do with the exhaust at the beginning of the video? I like the sound of it.
Kstorm21 is offline   Reply With Quote
Old March 7th, 2012, 06:13 AM   #1598
Domagoj
I changed that little rubber knob on the gauges, the one covering travel reset button. It rotted away and I was afraid water would leak inside while raining.
I also checked fork alignment again, and finally concluded that everything is ok with the bike, it's the roads which are messed up. I don't know yet if that is good or not.
Old March 7th, 2012, 11:15 AM   #1599
Oddly enough some of the paw prints came back after the seat dried... uggg me and animals.
Happens to me with nearly any mark I find on the seat.
Old March 7th, 2012, 06:54 PM   #1600
kevheads
kevheads's Avatar
I swear nothing goes easy for me. I got my EOM rear seat cowl in the mail today, go to put it on tonight and the gap looks pretty good around it but the rear over the taillight is off center to one side by 1/4 to 1/2 inch where one side has a gap from the tail section and the other side starts to hang over the tail section. I'm guessing when I installed the Targa Fender Elim. kit last summer, I got it off of center. Never really noticed it with the seat on until I put the seat back on now. Story of my life, one step forwards and 2 steps back.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
