Old March 3rd, 2012, 10:36 PM   #1
DIY R1 mirrors on a 250
So I was reading on faq.ninja250.org on how to get better looking mirrors for my bike, because I really hate that dumb elbow joint in the oem mirrors, but they really don't give much info on it, so I figured a DIY was necessary. My original plan was to modify the bracket to get it to work, but once I finally saw the mirrors, I realized that was not happening, so I did it the way they suggested, and illustrated it for you all. This is my first DIY, so bear with me, and pardon the mess; I was doing other stuff that day as well.
NOTE: nothing done to the bike in this DIY is permanent. If you decide to do this, and don't like the result, you can easily take your ninja back to the way it was before. Also, the method I used for mounting these mirrors is also how you'll want to install other universal fairing-mounted mirrors if you find another style you like better; the only difference will be possibly the nut you need, and the wrench to tighten said nut.
What you'll need:
  • R1 mirrors
  • two 10mm nuts
  • 10mm wrench
  • about a half hour of time
These are basic R1 aftermarket mirrors from D2 moto. $20, not a bad deal. They also come in carbon if that's what you're into. The oem mirrors are on the top, R1 mirrors are on bottom:
First step: take off the windscreen, removing the fairing is optional.
The next thing you'll want to do is take off those dumb rubber seals that the oem mirrors are mounted on. They pull right out, without any damage. It will look like this:
Test fit the mirrors, you'll notice that they fit in the existing holes, but the posts on the R1 mirrors are skinnier than the holes in the frame. This leaves wiggle room. You'll also notice that it's going to be a b***h to get a nut on the lowest post. I forgot to take a picture, but my solution was simple. I wrapped the lower post in teflon tape so that it wouldn't wiggle in the hole. Then I used a nut to tighten on the top post. This keeps the mirror on solidly, without wiggling
here's the technique that I found easiest to get the nut started. It really helps to have small hands
Now it's time for your 10mm wrench. You're going to have to tighten the nut one partial-turn at a time. Kind of annoying, but really doesn't take too long.
Congrats! now you have one mirror secured onto the bike. Repeat this for the other mirror, and then re-install the windscreen, and you're done. It should look like this when you're done with both mirrors:
Note on re-installing the windscreen: Make sure to start, but not tighten all screws so that all the holes can be aligned without putting stress on the screen. Then tighten them lightly, starting with the center-most screws, working your way outward.
So far, the visibility doesn't seem to be any better than the oem mirrors (just from sitting on it in my garage ) but hopefully I'll have a better gauge on that later this week after some test-riding.
EDIT: The view of the rear is about the same as the oem mirrors. The shape of the mirror is a little different though, so it takes some getting used to initially, but I have no gripes with these mirrors. They don't vibrate, they look good, and they aren't expensive at all.
Last futzed with by choneofakind; March 12th, 2012 at 03:08 PM.
Old March 3rd, 2012, 10:44 PM   #2
zCasanova
zCasanova's Avatar
Motorcycle(s): '10 Ninja 250r
Can we get pics of the aftermath?
zCasanova is offline   Reply With Quote
Old March 3rd, 2012, 10:56 PM   #3
@zCasanova, the last picture has the finished product I'll get some more pictures hopefully next time I'm out. I don't feel like more garage pictures.
Compare the R1 mirrors on the bike with the oem mirrors on the bike seen in this picture:
They're more round and slender, without those dumb looking elbow joints built into the stalks
Old March 3rd, 2012, 11:02 PM   #4
gilmorec61
gilmorec61's Avatar
Dont see any after picture?
gilmorec61 is offline   Reply With Quote
Old March 3rd, 2012, 11:02 PM   #5
C L
Motorcycle(s): 2014 300
I see no pictures
C L is offline   Reply With Quote
Old March 3rd, 2012, 11:06 PM   #6
Any better? Album was private. Now it's public in an attempt to get these pictures to show up. I've seen my own pictures the whole time
EDIT: Anyone? pictures working?
Old March 3rd, 2012, 11:35 PM   #7
C L
still no pics show up for me
Old March 3rd, 2012, 11:37 PM   #8
Well I just uploaded the pictures to ninjette today, so maybe that has something to do with it. Maybe @Alex can help diagnose the picture problem if they still aren't visible tomorrow. They still look good to me
Old March 3rd, 2012, 11:38 PM   #9
C L
They're up now
Old March 3rd, 2012, 11:39 PM   #10
Pictures seem fine to me.
Old March 4th, 2012, 02:19 PM   #11
darn those random picture gremlins
Old March 4th, 2012, 02:22 PM   #12
not bad, chodeofakind
Old March 5th, 2012, 05:59 PM   #13
Can we get a good front shot of them fully installed?
Old March 5th, 2012, 07:21 PM   #14
yes. tomorrow. If it warms up. If not tomorrow, then Wednesday.
Old March 8th, 2012, 03:04 PM   #15
Jono
Jono's Avatar
It is Thursday! What the hell choneofakind. I want to see a quality pic of these mirrors. NOW.
Old March 8th, 2012, 05:14 PM   #16
Hang on!! I got them Wednesday in my ride!!
...I just might have forgotten a little bit to put them up because I went straight from working on the bike to going to dinner with my girlfriend.
EDIT: here's the pictures of the final result. They're stable and don't move up to speeds of about 90
I think they look loads better than the stock mirrors. very happy with my work
Old March 8th, 2012, 05:54 PM   #17
Wow! What a difference. I see you already have Asian Cycle flush mounts, integrated rear signals, ZG double-bubble, and fairing mesh. Now you just need to get a green cowl-line seat cover, black out the exhaust, polish the rims, de-sticker the bike (once rims no longer match), and paint over the outer bubble of that double-bubble!
OK, I guess that's a lot, but I WANT TO SEE IT! :P
Old March 8th, 2012, 06:09 PM   #18
no. the green doesn't match. no. I like the polished aluminum on my slip-ons, no. I like the purple. no. ditto. plus that would leave me with a random purple chin fairing that matches nothing. no. I've seen some pictures of that, and it looks goofy.
hahaha any more suggestions?
Old March 8th, 2012, 06:22 PM   #19
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Definitely looks better, and is obviously much more functional than the stock mirrors!
Good job
MikeBudd is offline   Reply With Quote
Old March 8th, 2012, 07:09 PM   #20
I appreciate that MikeBudd, but they really aren't anything fancy in the functional department. They're the same view of my elbows
Old March 8th, 2012, 09:56 PM   #21
...I've seen some pictures of that, and it looks goofy.
You sure about that? Then try painting the stock windscreen.
You can make a custom-shaped headlight that doesn't look "goofy"
Old March 8th, 2012, 10:16 PM   #22
Jono
Jono's Avatar
Thank you!!! The mirrors look GREAT!
Old March 9th, 2012, 12:03 PM   #23
eh, more money than I want to spend... I like making mods that look like they came from the factory that way, and once you start into custom headlight shapes and cutting into fairing and whatnot, that adds up quick. Not to mention, if I had that kind of money, I would be doing the new-gen suspension and newgen woodcraft bars swap instead of a new headlight. Likely an EFI conversion kit with the UK TB as well
(I still think that looks kinda goofy and I use my camera through my windscreen, so that would kinda kill my video ability)
I really can't see the headlight when I'm riding.
I like them too. Definite improvement when you get rid of those elbow joints
Notice how clean and pretty she is also
Old March 9th, 2012, 02:48 PM   #24
I understand, but don't tell me you wouldn't want to turn a few more heads while you're at it!
Old March 9th, 2012, 03:02 PM   #25
Hey don't forget that I'm with the bike also whenever it's out and about. Trust me; heads turn
Old March 9th, 2012, 10:21 PM   #26
I bet they do! "What was that hideous beast doing to that pretty green Belle?!"
Old March 9th, 2012, 10:22 PM   #27
no. They definitely wonder who the sexy beast on that FIIIIINE lime green Kawi is
EDIT: awwwwwwh! you called my green bike pretty!! isn't yours blue?? Color traitor!
Old October 26th, 2012, 11:32 PM   #28
Bump on this thread. I just looked at the link I have for mirrors in this DIY. It looks like D2Moto is constantly changing their stock and no longer has those R1 mirrors
Old November 19th, 2012, 11:00 AM   #29
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
As it looks like D2 has discontinued those mirrors, based on your install, do you think these would fit well?
http://www.ebay.com/itm/For-04-05-06...cd22d1&vxp=mtr
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old November 25th, 2012, 09:17 PM   #30
Yeah, those should work! They're just basic R1 mirrors. I think '05 was the year mine were for. Give them a try. I like the look on mine a ton better.
Old December 10th, 2012, 11:58 AM   #31
lolibater
lolibater's Avatar
Thanks for the write up! Made my installation real simple
Old December 10th, 2012, 12:00 PM   #32
Good! Post your pics here if you want.
Old December 10th, 2012, 12:20 PM   #33
lolibater
lolibater's Avatar
Will do. I'll go snap one when I go pick up lunch.
Old December 10th, 2012, 12:49 PM   #34
lolibater
lolibater's Avatar
Old December 10th, 2012, 01:14 PM   #35
nice
Old December 10th, 2012, 01:31 PM   #36
hmmm.... I don't use my R6 mirrors anymore, wonder if they will fit. I bet they will. Will update.
Old January 13th, 2013, 09:27 AM   #37
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
Any cool aftermarket R1/6 that would be awesome on a Ninjette?
WANTED for 88-07 Ninja 250:
Corbin Gunfighter & Lady seat
iplante is offline   Reply With Quote
Old January 13th, 2013, 01:23 PM   #38
Idk, I'm sure the aftermarket ones will work fine, but I chose the stock R1 ones because I liked the look.
Any DIY's on fitting a PC5 to my ninja 250 ? Jason5885 2008 - 2012 Ninja 250R Tech Talk 3 December 2nd, 2014 08:24 AM
DIY Keyless Ignition for 08 250 garth285 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2014 01:39 PM
DIY: Installing Universal Mirrors with turn signal leds muzkur 2008 - 2012 Ninja 250R Tech Talk 20 April 6th, 2012 06:07 PM
Any do DIY DRL's on their mirrors? websniper 1986 - 2007 Ninja 250R Farkles 14 August 15th, 2009 10:42 AM
DIY - ebay universal fit / Bike It Trojan Style Indicator Mirrors Gregular 2008 - 2012 Ninja 250R Tech Talk 34 June 28th, 2009 10:50 AM
