#2281 | |
Join Date: Jul 2012 Motorcycle(s): 09' Ninja 250R Posts: 48
#2282 |
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250 Posts: 179
Rode it
09 Metallic Diablo Black; BikeMonkey Integrated Tail Light, HotBodies Fender Eliminator, Proton Flushmounts, MBRP Ceramic Black Exhaust, Chrome DB Windscreen, Silver Rimtape |
#2283 |
Chris
Join Date: Aug 2012 Motorcycle(s): BLACK!!! '08 250R Posts: 957
rode it to the Yamaha Demo Truck Event at Matthews Fun Machines.
I rode the FZ8 ![]() ![]() ![]() ![]() Great event and a chance to ride some nice bikes on the road with a group of enthusists. Check the schedule on the link and go if you can.... http://www.yamaha-motor.com/sport/mcy/demo.aspx
Some roads are too good to waste on four wheels! ![]() Riding in a car is like watching a movie... Riding on a motorcycle is like being in one.... |
#2284 |
I cleaned the rims, lubed my chain, and waxed that sexy biotch
#2285 |
put a tank pad on
#2286 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Scored some Rotella T-6 and Sea Foam on sale at the local O'Reilly's, going to do oil changes for both the 250 and ZX6R this weekend.
#2287 |
Chris
New chain.... but the zip tie on the master link... bright red so I can inspect it easily.
loved on it some... ready for a week of riding tomorrow... ![]()
#2288 |
Join Date: Jun 2009 Motorcycle(s): 09 Ninja 250R Posts: 23
Shimmed carb needles, & removed snorkel.
#2289 |
Certified looney toon
MOTM Jul '13, Jul '14
Finally got in some of the plastics, so installed front cowling, side cover, and rear fairing. Discovered front cowling stay was still bent. But did wire up my i5motorcycle flush mounts and used one of the busted cowlings to see how they look properly wired and all.
My frankenbike is slowly coming together. ![]()
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
#2290 |
shogun frame sliders installed
#2291 |
Join Date: Sep 2011 Motorcycle(s): 1986 Goldwing, 1996 CR500, 2011 Ninja 250, 2009 Harley Heritage Softail, 1941 Suzuki Gerbil 250 Posts: 427
I finely got my 15T/41T installed. I think they shipped it from Kentucky to California via the south pole. What a pain in the rump to get that front sprocket off. I would have less trouble rebuilding the motor. I blocked the rear tire with a 2x4 and used a breaker bar. No luck. I finely bought an impact wrench (I needed to replace my old one anyway) with 750 foot pounds torque, poof right off.
I know there's a 7th gear here somewhere... Changing to 15T/41T, now I'll get that 7th gear, lol. |
#2292 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
Scraped my pegs
I can not be a true player by playing around. |
#2293 |
Installed hella supertones.
Gonna scare some people, I'm sure of it. |
#2294 |
Installed the front stay (new) and mounted the instrument cluster and cowling, the front cowling and headlight, and then discovered Plasti Dip!
Blacked out my windscreen, then touched up some of the black plastics by sanding and spraying.
#2295 |
Tested out the GSXR shock. It's a night and day improvement over stock but it makes the front feel even worse. Swapped back on stick shock until I have new links made and get my intiminators from home.
#2296 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Are you changing the fork springs as well?
#2297 |
I will have to see if I need them or not after I install the Intiminators. The install with the intiminators requires 5wt fork oil so it going be interesting as to how they will perform.
#2298 |
#2299 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
New tires, new thermostat and coolant, new oil, new windscreen bolts, general wipedown.
#2300 |
Join Date: Sep 2012 Motorcycle(s): 09 Ninja 250 Posts: 6
Changed the oil for the first time.
#2301 |
Fixed the damn choke plunger that I forgot to screw on when I did my Area-P and FP Stage 3 install. Found out that the battery died so I went to get a Battery Tender Jr. For only ~$23 it seems like it's just a good thing to have around rather than rushing off to AutoZone to have them charge it.
Also did a spark plug check and found that the plugs looked awesome and I'm content with my current jetting. Going to let the battery fully charge, reinstall, and then give the bike a much needed wash. Bike has been sitting for about 3 weeks, I have some leftover Seafoam from treating my ZX6R and will run it through the remaining ~2 gallons in the 250 and hope that there isn't any significant gunk in the carbs. |
#2303 |
Well I wired up a a cigarette lighter and ran a usb cord all the way up under the windscreen to charge my iphone and future accessories. I also have a pocket air compressor under the rear seat.
#2304 |
Rode it for the first time in around a month.
First mistake = downshifting into 1st while rolling at around 20mph and letting the clutch out. Thought I had a flat since the bike felt so low and narrow, I would kill for a flared-out tank on the 250. |
#2305 |
I'm actually planning on doing the same thing... I'll buy the quick disconnect thingie off amazon tho, so I can hook up a battery charger to it as well...
#2306 | |
#2307 |
rode it and she liked it
#2308 |
Actually neither do I, but off late my battery's drained on me at least twice... So I figured I'd rather have it than not... I think my hids are taking a toll on my battery...
#2309 |
I did this!!
![]() Yay, got my paint in! (ouch it was from ColorRite but no one local could mix up the right color for Candy Lime Green.)
#2310 |
I ordered BT-45s 120/140 set at chapparalmotorsports for less than $200
#2311 |
#2312 |
Biker
Join Date: Nov 2011 Motorcycle(s): 2010 Ninja 250 SE Posts: 723
I looked it up. $199.26 is the total, shipped!
#2313 |
Yessirs! about $196 if i recall correctly. They didn't have a 110 front but I couldn't complain about the price for the 120.
#2314 |
Went from 112.5 mains to 115's and re-did the idle mixture screws due to poor performance when commuting at night at around ~55-60F temperatures. Might also fiddle around with the needle height next week if the mid-range is lacking. It ran like a dream when it was jetted during the summer heat when riding temperatures were around 85-90F, so I figured the lower air temperature was making it run lean. Did a plug check and found out that cylinder #1 was running slightly leaner than cylinder #2 so I'm planning to do a carb sync sometime in the future.
On a side note, I invested $5 to get one of those telescoping magnetic pick-up tools and used some foil to catch any falling bolts from the fuel bowls. Lots of headache avoided. |
#2315 | |
Chris
Pic and a link please....
#2316 | |
#2317 |
ninjette.org mafioso
Join Date: Jul 2012 Motorcycle(s): 2009 Ninja 250R Posts: 337
Took her for the last ride of the season. Filled her up, added stabil, rode home. Installed spools and got started winterizing.
#2318 |
pushed it out of the way to start work on getting a Virago running to hopefully flip in spring. And then went for a short ride just up and back down the road since I hadn't since lifting the front end back up and putting my clipons under the tripple tree. It handles a lot better but my back is going to kill me when I go on a longer ride... I don't have any impressive stories about falling out of helicopters or getting shot or anything, I just lifted a Honda Civic motor myself and ever since, it's bugged me.
I got a new RK X ring chain and JT gears in the mail (like $108 shipped off amazon), I have pod filters coming, I removed the baffles from my stock pipes. So it will be in need of jetting come spring... I have stainless allen head screws and stainless washers I got off McMastercarr.com for cheap and jets from Jetsrus already.
Motorcycle noob, feel free to ignore me. |
#2319 |
Join Date: Oct 2012 Motorcycle(s): 2010 Ninja 250 Race, FZR 400 Race Posts: 12
Installed an Area P custom Dyno Jet kit after cleaning up the carbs. Tmrw, install the carbs, remove the kleen air system, remove the snorkel and backfire screen from the air box, and install the Area P mid-high mount race exhaust!
#2320 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
Broke 1k miles and cleaned and lubed the chain
VROOOM vrooom >.> |
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
