Go Back   ninjette.org > Marketplace > Motorcycle-related
Old May 13th, 2014, 09:35 PM   #201
Jaife86
Jaife86's Avatar
Motorcycle(s): 2009 Blue Ninja 250
Just arrived today
IMAG0241 by jeff9ninja, on Flickr
Jaife86 is offline   Reply With Quote
Old May 14th, 2014, 04:53 PM   #202
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Wooooo who... FedEx got one right ( I don't like them ) but I got a box who ray
Old May 14th, 2014, 04:54 PM   #203
Old May 14th, 2014, 05:38 PM   #204
Olie
New Old Guy
Olie's Avatar
Motorcycle(s): 2011 250R SE
Came home for lunch to find my package just waiting for me to open. The weekend can't come fast enough!!!
Olie is offline   Reply With Quote
Old May 19th, 2014, 02:16 PM   #205
Haven't forgotten about you all; hoped to film this Sunday night but time got short before the kidlets were asleep. I imagine this just raises the suspense.
Old May 19th, 2014, 02:37 PM   #206
kbryant
Area P
kbryant's Avatar
No worries from my standpoint. The suspense isn't killing me as much as it may with the others.. Good luck to all participants!
Old May 19th, 2014, 02:38 PM   #207
Old May 19th, 2014, 06:55 PM   #208
JohnnyBravo
So if the suspense kills everyone else; I win? I can wait a long while
I'm very impressed with my exhaust! The suspense of waiting to pick up a tuner and get it all put together may make me sick :/
Old May 19th, 2014, 07:37 PM   #209
Jaife86
Jaife86's Avatar
Very pleased with my system as well. Will have to fiddle with the jets/carbs a little more, as this is my first venture into carburetors. Everything seems pretty good so far though.
Old May 19th, 2014, 07:45 PM   #210
JohnnyBravo
Yea, I got a few extra parts, an some little things to do, then add a tuner to the package an put it all together! It looks amazing though! An the weight savings, an extra horses won't hurt! Wish mine was easy as a jet kit an some tinkering, oh well fuel injection is pretty swell.
Old May 19th, 2014, 08:53 PM   #211
Olie
New Old Guy
Olie's Avatar
I love the new exhaust and carb set up. Of course more fine tuning is in order but it's runs and sounds great!
Old May 20th, 2014, 07:21 PM   #212
JohnnyBravo
I look about like my profile pic every time someone asks if my exhaust is on yet. Santy claws needs to come over
Old May 20th, 2014, 08:56 PM   #213
Daniel_Malloy
Daniel_Malloy's Avatar
... I did the responsible thing and told myself I cannot install my exhaust until I replace both CV axles and all front ball joints on my car first... Needless to say the suspense is killing me!!! And the sucky part is I have to stare at the beautiful exhaust every time I walk out the garage, Lol.
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Daniel_Malloy is offline   Reply With Quote
Old May 20th, 2014, 11:26 PM   #214
Olie
New Old Guy
Olie's Avatar
Any news?
Old May 21st, 2014, 03:35 PM   #215
rasta
Your face
rasta's Avatar
Which of the DIYs is best for rejetting carbs? There's so many of 'em, I'm not sure which to use
Old May 21st, 2014, 05:22 PM   #216
allanoue
allanoue's Avatar
MOTM - Sep '14
does kkim have one?
Old May 21st, 2014, 06:41 PM   #217
Olie
New Old Guy
Olie's Avatar
step 1: create a new gas tank that lets you access the carbs easily with the tank off, put a fan in front of the bike pointing at the radiator. turn the fan on high.
step 2: warm the bike up. check where the idle is and make a mental note. with the bike running and the tank off you should be able to access the mix screws on the carbs. with the bike running, turn each screw a quarter turn one direction. did the idle go up or down? if it went up, keep turning in that direction until the idle reaches the highest. if it went down, turn the screw in the other direction. if you get to either end of the mix screw (wont go in any more, wont go out anymore), make a paper note about which way, and what pilot screw you were in.
step 3: try another pilot jet. pick a direction, its safer to go richer instead of leaner first. try that jet, repeat step 2 with that pilot jet. dont touch the idle nob this entire time or you will throw off your results. can you get it to idle higher with that pilot jet? then that pilot jet is better. keep going that direction until it stops getting better. did it get worse with that pilot jet? go the other direction. pick the jet that gave the highest idle after tuning the mix screw for that jet. if your idle is getting too high (higher than 4k rpm) you can start turning it down, just remember that all the numbers will be skewed. remember to take that into consideration when making and reading your notes.
step 4: after you have chosen the correct pilot jet, adjust your idle nob down to 1500rpm.
step 5: put in the largest main jet you have.
step 6: put the tank on, get the bike ready to ride, warm it up and take it for a ride. while you ride make mental notes about the way it performs with wide open throttle at max rpm in a specific gear. always use the same gear. use a higher gear. if you have an area where you can take it to redline in 5th or 6th gear, thats ideal because you will notice the difference in power the most. just do it where you wont get a ticket (where its legal and you arent going to die) take a few passes to be sure its consistent. dont worry if it struggles at mid-range rpm or half throttle at this point only focus on wide open max rpm power here.
step 7: when you get back to the garage, write down what you thought of the power with that jet on paper. put in a smaller jet and try step 6 again. continue until the top end stops getting better or if it starts getting worse. pick the jet that felt the best. (most power) if two jets feel the same, pick the larger of the two.
step 8: if there is any stuttering, clunkyness or roughness during an rpm climb from wide open throttle through the rpm range of 5 to 9k rpm, your fuel curve isnt right. the needle height adjusts the needle curve. if it feels jittery like the engine wants to cut out usually that means its too rich, so drop the needle down. feeling lean is a little bit harder, just doesnt have as much power but not as clunky as a rich condition
doing plug checks will tell you if you are lean or rich at any time.
Old May 26th, 2014, 05:05 PM   #218
rasta
Your face
rasta's Avatar
Anybody else have clearance issues? My can pushes up against the swingarm...there's not even close to enough room...
Old May 26th, 2014, 05:26 PM   #219
What side do you have the band on?
Here is mine from a year or so ago.
Old May 26th, 2014, 05:36 PM   #220
kbryant
Area P
kbryant's Avatar
Hi Wes, If you would like to PM or contact me at sales@areapnolimits.com, I'll be happy to help you. Normally on the 250 standard system, it's from simply having the body clamp on backwards, which puts the "offset" closer to the swingarm. Very easy to remedy and make adjustments. Simply send me a pic and we'll get you dialed.
Old May 26th, 2014, 05:38 PM   #221
Thanks Kerry!
@rasta I called it a "band", Kerry calls it a body clamp so let's go with him. But we are both referring to the same thing.
Old May 26th, 2014, 08:11 PM   #222
rasta
Your face
rasta's Avatar
Thanks for the offer Kerry. I'm actually going to revert back to the original pipes for the time being, but once I get back to installing the Area P, I'll definitely reach out
Old May 27th, 2014, 07:38 PM   #223
JohnnyBravo
I don't think my plan of the suspense killing off the competition is workin
Old May 28th, 2014, 04:25 PM   #224
dave42
dave42's Avatar
Motorcycle(s): ninja 250, ZX6r, RSV4, Caponord Rally
Or has it....
dave42 is offline   Reply With Quote
Old May 28th, 2014, 08:19 PM   #225
Old May 31st, 2014, 07:28 PM   #226
Daniel_Malloy
My exhaust is now officially installed! I removed the stock airbox and installed the K&N pod filter that fits our bikes (think 0990?), removed the kleen air system and last but not least rejetted the bike. Started with the largest main, 110, will work from there but it is noticeably better than a stock bike now... Very pleased!
-Albert Einstein
Old June 1st, 2014, 08:43 PM   #227
Alright party people; the little monsters were in a good mood tonight, and we had a successful drawing. With some help from the better half, this was a "Frozen-themed-musical-chairs-with-plates" event. Traditional rules. Here's the first video....
Old June 1st, 2014, 08:51 PM   #228
Daniel_Malloy
... And the suspense grows even more!
-Albert Einstein
Old June 1st, 2014, 08:52 PM   #229
rasta
Your face
rasta's Avatar
The suspense is killing me!! Your kids are very talented dancers
Old June 1st, 2014, 08:59 PM   #230
And here's the 2nd video (of 3)...
Old June 1st, 2014, 09:21 PM   #231
rasta
Your face
rasta's Avatar
Drumrollllllllll
Old June 1st, 2014, 09:31 PM   #232
Olie
New Old Guy
Olie's Avatar
It was good to see my name in there....thought mine was the plate that went under the fridge!! LOL
Old June 1st, 2014, 09:56 PM   #233
JohnnyBravo
this is a lot more fun than a name out of a hat!
Old June 1st, 2014, 10:37 PM   #234
And now for all the marbles....
Old June 1st, 2014, 10:51 PM   #235
Olie
New Old Guy
Olie's Avatar
That was awesome! Congrats!
Old June 1st, 2014, 10:58 PM   #236
mania
mania's Avatar
Motorcycle(s): 2013 250
Too Cool & Congrats Johnny Bravo
mania is offline   Reply With Quote
Old June 2nd, 2014, 12:00 AM   #237
rasta
Your face
rasta's Avatar
Woooo! Thanks to Kerry for being awesome enough to do this. And congrats @JohnnyBravo!!!!!
Old June 2nd, 2014, 01:12 AM   #238
dave42
dave42's Avatar
Haha, nice! Grats to JB, and thanks for an entertaining and unexpected way of drawing, Alex.
Old June 2nd, 2014, 04:17 AM   #239
Gratz! Well done Alex and family.
Old June 2nd, 2014, 04:20 AM   #240
JohnnyBravo
Best plate picking ever!!! I'd like to thank everyone! This is pretty freaking amazing!!!
2014 Koso Group Buy! RaceTech Electric Motorcycle-related 19 April 24th, 2014 01:39 AM
Group Buy: PREGEN- Area P Full Exhaust System kkim Motorcycle-related 170 October 9th, 2012 12:19 PM
Area P Group Buy WhiteRice Motorcycle-related 141 December 17th, 2011 10:28 AM
Group Buy: Area P Race System (Completed!) kkim Motorcycle-related 208 May 15th, 2011 07:55 PM
