April 27th, 2015, 04:20 PM | #1 |
Biggest Weaknesses?
Who looked at this section of the forum to go slower today?
I am interested today in is... What is your biggest weakness? We all need to be honest with ourselves while riding. So I will go first.... I suck at the hip flick. For example; in a chicane or connected corners, I am late getting my bum over ahead of the bike but... a "true" hip flick is a VERY advanced and hard technique. I find myself moving to the middle (directly on the seat) instead of sliding to the other side as one solid movement. I know what I need to do, but I just can't make my body do it at that moment in time.
April 27th, 2015, 05:11 PM | #2 |
Private Joker
MOTM - Mar '14
Mentality
It's easy to get caught up in the physical mistakes, which for me would be corner entry. I suck at reading corners and reading the speed at which I can enter them. I also suck at side to side transitions which is more or less an extension of the initial vision/steering issue that I have. Back on topic mentality wise I am a very aggressive and confident rider, almost to the point of overconfidence. This isn't an issue, as I do know my limits and can feel for what the bike is doing next to me, until you factor in other people. I am easily annoyed when stuck behind someone who is flying in the straights and parking it in the corners and I try to find any way through that I can, which naturally invites others to do the same to me. Basically I suffer from racing mentality at times as opposed to a learning mentality that I should
April 27th, 2015, 05:37 PM | #3 |
Track Clown
MOTM - Sep '15
Flexibility/mobility.
April 27th, 2015, 05:46 PM | #4 |
Low-speed maneuvering. Much harder on a supersport than on the Ninjette.
But then I'm not going at low speeds all that often....
April 27th, 2015, 06:15 PM | #5 |
sammich maker
MOTM - Apr '15
Many...
Let's go with mental - my bike has not been set up the same way for 2 seasons. So, I always feel like I am getting use to the bike. Next, I hate dirty roads and they freak me out a little when one a spirited ride.
https://www.brocksperformance.com/VZ...0035+C450.aspx |
April 27th, 2015, 06:52 PM | #6 |
Join Date: May 2013 Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol Posts: 222
Confidence to push harder and enter turns faster!
April 27th, 2015, 06:55 PM | #7 |
Thanks everyone so far! Keep em coming please.
April 27th, 2015, 06:58 PM | #8 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
braking hard and late. I normally brake hard earlier than necessary and find myself getting back on the throttle before I turn in. I'm extremely confident in my ability to brake in emergency straight line stops because I practice emergency stops from speeds ranging from 20-100mph on a closed road but I just do not feel comfortable braking into a turn. I need more track days to learn braking.
April 27th, 2015, 07:02 PM | #9 | |
I know how much you have progressed in a short time on track.
April 27th, 2015, 07:06 PM | #10 |
Private Joker
MOTM - Mar '14
Where are you looking while braking, and where are you looking as you decide to brake?
April 27th, 2015, 08:19 PM | #11 |
Motorcycle Nurse?
Most of the time as far into the turn as I can see. I just have a mental block keeping me from progressing. I don't feel comfortable pushing my comfort zone on the backroads.
April 27th, 2015, 08:32 PM | #12 | |
Private Joker
MOTM - Mar '14
What I've been doing to work on entry speed at the track is to focus on the apex (or another reference point, so long as it stays the same lap to lap) once I start my braking and use it as reference for my speed and turn in point. I'm still seeing the exit with peripheral vision but my focus isn't on it until I turn in.
April 27th, 2015, 09:38 PM | #13 |
cadd cadd cadd
MOTM - May '15
On unfamiliar roads, very rarely do I go in too hot for a corner. For those rare occasions where there is a decreasing radius turn that caught me off guard, I know exactly what I need to do....I need to relax, get my chest lowered, move my torso off the bike some more, maintain throttle position and push forward the handlebar more to lean more.
But mentally, I'm scared. I'm afraid I'll crash. I tense up and think "oh sheet". My inside elbow isn't as bent as I like it to be (especially on right turns). And sometimes, during the "oh sheet" moment, I instinctively ease off the throttle trying to slow things down so I have more time to think and react....that usually makes me go wider.....which puts me in a more panic state. I know, I have A LOT A LOT A LOT more lean angle since my chicken strips are around 3/4" thick. But I'm just afraid to lean it more. And to make matters worse, on right corners, there's usually a guard rail on my right....and if I lean my head over too much, I'm afraid my head will hit the guardrail and I get decapitated. But in reality, I'm probably 5ft away from the guardrail. Right corners are also an issue because when I try to look through the turn....look where you want to go....I can't see the exit point of the road because the guardrail is in the way of my line of sight. I really really really need to do a track day. I found a track day program for first timers for $100 (either NJMP or Poconos). I just need a trailer (and install a hitch on my car) as I don't feel comfortable riding back from the track being completely exhausted. It's extremely frustrating for me because I know (or think I know) what I need to do (lean more while holding throttle or roll on more throttle gently)....yet, my head isn't allowing me to do it.
Riding it like I financed it. |
April 27th, 2015, 09:46 PM | #14 |
the red mist
something happens, i get mad. instead of saying "oh well", i need to give em what for. bad idea. very bad idea. except for getting hit by a car, every single one of my accidents has had this as a contributing factor. i crash when i'm angry.
April 27th, 2015, 09:48 PM | #15 |
^^^ was the main reason for my crashes, all brawn... no brains.
April 27th, 2015, 10:07 PM | #16 |
MOTM - July '15
My biggest weakness is my lack of ability to say "Okay, physics. Don't **** me on this." and ride out entering a turn too fast. I've never crashed doing this but thinking about the times I almost did make me squirm.
April 27th, 2015, 11:04 PM | #17 |
Motorcycle Nurse?
Ben there's a nice roundabout and a little road I know where going 35-55 is enough to be enjoyable. I know the feeling though. It used to be fun to cruise at 75-90 down a slightly winding road but now it feels boring.
April 27th, 2015, 11:49 PM | #18 |
Motorcycle Nurse?
@cadd Track day is your best bet. You'll be able to push your own limits in a safe environment. My first track weekend I played around a lot with how much input I could give the bike leaned over and how far I could lean it over. Multiple times I slid the rear from too much throttle and had I been on a street I would have wrecked. I think I went off the track about 5 times that whole weekend. But I came out with so much knowledge of what my bike is capable of and what I can make it do if I ever need to. Those 3 track days taught me more than a whole year of riding experience I had of just street before it.
April 28th, 2015, 01:06 AM | #19 |
Join Date: Jan 2015 Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold. Posts: 338
I am nearing fifty, and started riding less than a year ago. I learn so slowly, it's infuriating. So, weakness? Everything.
Screw the inscrutable, eff the ineffable. |
April 28th, 2015, 06:29 AM | #20 |
dirty boy
MOTM - Apr '14
looking through the turns. getting better but still the main thing I feel I need to work on
April 28th, 2015, 08:18 AM | #21 |
Fighting Texas Aggie '05
Corner entry, specifically trusting the front to settle and bite with minimal brake application at speed.
April 28th, 2015, 08:23 AM | #22 |
It is interesting to me, as I have the same mentality about on road hard riding. I just flat do not want to do it anymore, not worth it. I ride hard on the track and ride overly cautious-responsible on the road with very very few exceptions.
April 28th, 2015, 12:12 PM | #23 |
Awesome guys/gals! No wait... ahahahahahah We all have weaknesses. Thanks again for ya'lls input, it's more helpful than you know. My goal for this thread isn't for it to become a big advice thread, but instead for a bit of honesty and to hear in "the rider's own words" what concerns you the most.
Like many riders, I have more than one weakness. I also suck at consistently doing the faster throttle roll while picking the bike up on exit. Sooooo many seconds lost for me. If I think about it more, the habits I have developed racing the 250 has had an effect here. On exit, I normally have the 250 pinned, but this is not the case on my r6's and I forget to roll harder when I pick the bike up. :\
April 28th, 2015, 04:37 PM | #24 |
Corner entry speed for me, more so on left turns.
Whether sweeper or 90* angle I feel I a) go to slow in b) more nervous in lefts To practice A) I don't know yet b) stay in middle of lane more or possible right tire line.
My replies are intended for street riding only, plz do not provide track only replies. Visit my new MotoVlog Channel !! |
April 28th, 2015, 05:30 PM | #25 |
Join Date: Dec 2013 Motorcycle(s): 2007 Ninja 250 "sold" 2014 ninja 300 "Gold" 2000 DRZ400S (Sold the POS) K7 GSXR600 (Also POS...see a pattern? Posts: 207
Right hand turns dammit! Idk what it is about them, but I just dont feel as confident In them. I could take the same turn to my left way faster then my right. Thankfully it is getting much better I think it is because I sit a little crooked on the seat lol
April 28th, 2015, 06:01 PM | #26 |
Join Date: Jan 2015 Motorcycle(s): 2014 Ninja 300, Yamaha TTR 125 Posts: 124
I have a hard time trusting my brakes and tires. Always brake way too early when going into a corner. Also, I get way too disappointing when things aren't going the way I want them to, which only makes me mess up more
April 28th, 2015, 06:15 PM | #27 | |
Private Joker
MOTM - Mar '14
Moral of the story is, everything seems to come more down to vision than anything else
April 28th, 2015, 06:32 PM | #28 |
Urban Legend
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250R SE - Circe Posts: 542
Mine like some of the others would be confidence. I was afraid of riding before I started and there would times when I don't want to try anything new or do something that I have done before because I am afraid that I would fail.
But I beat that feeling down, rip, punch, bite, claw and all......well most of times anyway
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up." -Baron |
April 28th, 2015, 06:40 PM | #29 |
Whataburger.
Another one for right handers. I just don't practice them enough.
April 29th, 2015, 06:11 AM | #30 |
lol .... Whataburger is a gift .... not a weakness lol
April 29th, 2015, 06:14 AM | #31 | |
May 4th, 2015, 06:04 AM | #32 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
Ok where to start.......
Went on my first event ride, usually I ride alone. During it I took note of some things I found to be an issue. First and biggest, when riding outside I find myself feeling much more confident with my riding, this is probably cause I'm use to always riding on the left side of the road. So when it came to riding inside I found myself over worried which lead me to tense up in corners and brake more for corners. Also, I felt less pushed on keeping up when I rode in the pack of cruisers, when I was with the other sport bikes I felt like I was being pushed to keep up, even though regardless I wasn't falling behind. This lead me to feeling that I was coming into the corners at to quick a rate and had to brake a lil harder. I have footage of it all that I will be looking over to see what else need to work on then.
Spoiler for topic:
May 4th, 2015, 10:34 PM | #33 |
Do werk Nick!
May 11th, 2015, 09:34 PM | #34 |
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 787
Didn't have a chance to read all of these just yet but I suck at high speed corners, often turn 1 at various tracks. Laguna, Mid Ohio, Fontanta, Sears Point, Barber, The Ridge etc.....My vision tends to narrow down in these high speed corners and I have to constantly remind myself to look into the turn BEFORE i actually turn the bike. If you put a recorder in my helmet you would hear me screaming, "LOOK..........TURN.....for the corners and reminding myself to push my vision out wide and not let myself target fixate on those type of corners.
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
May 12th, 2015, 05:33 AM | #35 |
MOTM - July '15
Mens' asses.
And riding at night scares me a lot. No idea why. Driving at night is fine. |
May 12th, 2015, 05:38 AM | #36 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
I been feeling much more confident lately with leaning the bike more. Still got to work on riding on the right side.
Spoiler for topic:
May 12th, 2015, 06:51 AM | #37 |
Join Date: Mar 2015 Motorcycle(s): gsxr 600 2012 Posts: 120
Too much head knowledge without application and too little practice
Motorcycles are stable, I am not. RELAX-Keith code |
May 12th, 2015, 09:35 AM | #38 |
Fogwalker
Join Date: Mar 2015 Motorcycle(s): '09 Ninja 250 "Matilda" Posts: 124
That would be me. I've found that low speed mastery helps me with everything else. If you can manage to ride smoothly at low speeds, then doing it at a higher speed (on a much more stable machine) is gravy.
Dragging knee in first gear while doing circles is very educational. Add in using the turn signals and horn as you do it if you really want to challenge yourself. "I live my life a quarter mile (an hour) at a time!" Weaknesses? Attractive women and alcohol. Preferably together. Ride on, J~
Take care of new riders, for we were them, and they will be us. Y. Hong 2004 |
May 12th, 2015, 09:38 AM | #39 |
MOTM - Mar '13, Jun '14
More alcohol makes them all attractive!
May 12th, 2015, 10:35 AM | #40 |
Private Joker
MOTM - Mar '14
*husband walking out of house*
"Honey, don't forget to get something that makes me look pretty" - wife *guy comes back with a case of beer*
What is the biggest | reroka | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 26th, 2014 08:03 PM |
[crash.net - WSBK] - WSBK Monza: Rea negates Honda weaknesses for fourth | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2013 10:50 AM |
I think I have the biggest one | eddiekay | General Motorcycling Discussion | 24 | May 13th, 2010 05:54 PM |
Greetings from the biggest little! | smcbride11 | New Members | 17 | March 30th, 2009 04:11 PM |
