May 1st, 2013, 10:55 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 2005 Ninja 250 Posts: 24
Idle Speed, High beam not working
So today i bought an 07 ex250, 12,000 miles. bike runs good other than it idles once warmed up at 3000 rpm no choke and i either have the idle spd screw set so that it idles under 1000 or at 3000. What gives. Also the Headlight wont turn on for highbeam but it does for lowbeam. Im thinking new bulb? What bulb can i get thatd be brighter. The highbeam indicator on the dash turns on.
May 2nd, 2013, 05:16 AM | #2 |
Gratz Seth!
Try the simple stuff first. Check your airbox/filter and have a look at all the vac lines but honestly sounds like a slightly dirty carb. Any mods to the exhaust or pods? Seafoam might help but don't expect magic. I would try a new bulb before going any further with the headlight.
May 2nd, 2013, 05:25 AM | #3 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
The part # for the bulb is 92069-1002 should be about 10 bucks.
May 2nd, 2013, 07:45 AM | #4 |
When in doubt with funk idle/warm up, clean the carbs.
low beam or high beam brighter? only choose one | passive101 | General Motorcycling Discussion | 3 | July 26th, 2013 06:27 AM |
Low Beam Good, High Beam dead | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 21st, 2013 03:44 PM |
make high beam into low beam? | DaMan22 | 2008 - 2012 Ninja 250R Farkles | 2 | July 12th, 2012 06:34 PM |
HID Low and High Beam | Pudge Ate Me | 2008 - 2012 Ninja 250R Farkles | 7 | November 29th, 2011 09:52 AM |
Headlight lo-beam not working; burnt bulb? | HorizonXP | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 14th, 2010 02:39 PM |
