March 23rd, 2016, 07:15 AM | #1 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 478
Bike died ?????
OK, so took bike for a spin to bed in new brake pads before annual inspection.
So bike was run for a couple of hours on bench adjusting carb vacuum & idle. Next day was run for about 45minutes to warm through & check new clutch with some pull aways. A couple of hours later, I took bike out on the ride, went great until I pulled up at a stop sign & it just died. Would not restart, had breakdown come out to recover it, the mechanic decided to have a good go at getting it working, to no avail. Now its home I've had a look, but a bit perplexed as was he. Bike has;- 1. Fuel, supplied from a funnel in the feed hose, its fresh. 2. Spark, pulled plugs, bopth give health fat sparks. It cranks easily on fresh charged battery. Coughs now & again but does NOT catch & run. Bike had carbs stripped & cleaned prior to the first startup, so should be good as it ran for approx 3.5 hours before it died. Any ideas ? Thanks |
March 23rd, 2016, 07:28 AM | #2 |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
Give it a compression test. There is also a possibility it sucked in a peice of filth into the pioltjet or pilot circuit, so its worth cleaning the carbs again.
Because Unregistered sucks at riding. |
March 23rd, 2016, 07:33 AM | #3 |
Check boots on both sides (airbox and intake) to make sure they didn't slip off, fold or are leaking air.
Unplug spark plug wires and turn it over a few times. Remove plug... check for wetness. If they are not wet, you have a fuel delivery problem. Hope it's something simple fore you and good luck!
March 23rd, 2016, 07:35 AM | #4 |
I'd agree with that as a possabilty if it was one carb, but both at the same time ?
I changed over to CoP's a month ago & know that it will run on one cylinder as one was faulty & confimered by swapping to other cylinder, bike ran equally well on either cylinder. Carbs were spotless when reassembled, in fact they were pretty spotless when pulled out which surprised me, no gunk, nothing and it had been laid up for a year, due to me having a crock knee |
March 23rd, 2016, 07:39 AM | #5 |
OK, so plugs were wet when pulled yesterday after attempts to start it when I got it home.
Did a compression test & both registered 125psi on 4 pumps, new gauge, so no idea how accurate it is. That was full throttle, no spark plugs. i guess that's where Kawasaki get that 470rpm comp test figure from, as rev counter went half way to 1 |
March 23rd, 2016, 07:42 AM | #6 |
PS, used a bore scope to look in plug holes, both pistons are intact, no dents, marks or other anomalies
March 23rd, 2016, 09:01 AM | #7 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Timing?
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
March 23rd, 2016, 09:03 AM | #8 |
Possible, but as it was running fine & was going slow when it stopped I'd be surprised, but I will check it.
March 23rd, 2016, 09:06 AM | #9 | |
Vintage Screwball
MOTM - Mar '16
125 is low.
Goin' fast on slow bikes! |
March 23rd, 2016, 09:17 AM | #10 |
agreed 125 is low, but manual spec is for a hot test & this was a cold test. I can understand one cylinder going out of spec, but not both simultaniously ! Could happen if bike was running badly, but went from great to dead in like 2 seconds !
I'm going to pull the carbs & check it all over, as the downside to the ZZR is you can't work on it with the fairing on |
March 23rd, 2016, 09:27 AM | #11 |
If the plugs were wet and it stumbled but wouldn't start, it would seem you are getting too much fuel for some reason.
Have you tried cranking with the throttle open a little - or a lot? It is odd that it ran for quite a while, then quit. Is the tank spotless inside? Are you running a fuel filter? Could be possible something made it's way down to the float valves and is stopping them from closing. In general it sounds carb related to me. |
March 23rd, 2016, 09:40 AM | #12 |
Its been cranked wide open & closed with choke, no apparent differenc ein attempts to start. Now & then it coughs, but does not catch
Tanks is spotless inside, no corrosion nor any muck. Tank flows loads on prime position, so not tank related. Will look at carbs again, as spark is easy to test. |
March 23rd, 2016, 01:34 PM | #13 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Intake tract and exhaust tract clear of obstructions?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
March 23rd, 2016, 01:50 PM | #14 | |
It does seem odd that it would all of a sudden start running extra rich though. |
March 28th, 2016, 12:06 PM | #15 |
Join Date: Mar 2016 Motorcycle(s): 2010, Ninja 250R, FI Posts: 3
Could it be some old / bad quality fuel you supplied?
April 4th, 2016, 09:19 AM | #16 |
Not had a chance to look at this since I got it home, spent all of easter gutting & refurbing a bedroom, now she's happy I have to clean the garage, before I can start work on it, so will get round to it one evening this week.
my bike died | joshuafrench | !%@*#$%!)@#&!%@ I crashed! | 4 | June 19th, 2014 12:38 AM |
Ok, so my bike just died on me. | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 16th, 2013 04:35 PM |
On my way to work my bike died!!!!!! | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 23 | June 15th, 2012 02:32 PM |
My Bike's Battery Died, What Should I Do? | Jiggles | General Motorcycling Discussion | 28 | November 18th, 2011 03:04 AM |
Bike died while riding | zem | 1986 - 2007 Ninja 250R Tech Talk | 44 | June 1st, 2011 02:09 AM |
