April 26th, 2014, 05:09 PM | #1 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
Rear sprocket question
Since my two local shops are unable to install a 15 tooth front sprocket. I have to change my rear. So my question is, if I go to a 43 tooth rear sprocket will that do the same as going to a 15 in the front? Or would I need to go to a 42?
April 26th, 2014, 05:39 PM | #2 | |
http://www.dropbears.com/u/utilities/sprocket.htm 14/45 (stock) = 3.21 14/44 = 3.14 14/43 = 3.07 14/42 = 15/45 = 3.00 You may need to shorten your chain. Again, you are following the wrong path for no reason, just bad advise. The bigger the smallest sprocket, the less stress on the chain.
April 26th, 2014, 05:48 PM | #3 |
15/45 has the same ratio as 14/42.
April 26th, 2014, 06:35 PM | #4 |
You're missing the point. Avoid both shops that are feeding you crap. Heck, there is a DIY thread at the top of our tech section that can walk you through installing the correct 15 tooth up front.
April 26th, 2014, 06:56 PM | #5 |
Join Date: Mar 2014 Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE Posts: 59
Standard set up is 14/45, I think I will eventually be going up one tooth to 15 on the engine sprocket for my 2012 ninja 250.
No reasons why there should be any problem doing that. |
April 27th, 2014, 08:45 PM | #6 | |
WTF? I gotta hear the reason for this.
April 27th, 2014, 08:48 PM | #7 |
April 27th, 2014, 09:29 PM | #8 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
I tried a 15 tooth sprocket, but found that I didn't like the increased vibration. The stock counter sprocket has a rubber insert that helps isolate vibration. I went back to the stock sprocket and instead changed to a 41 tooth rear sprocket. I had to remove 3 chain links, as I remember.
To each their own.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
April 27th, 2014, 09:36 PM | #9 | |
Interesting note, I like the stock gearing on a pregen vs. 15/45 on a new gen. Go figger', never really thought about it.
Chain and Sprocket Question | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 25th, 2014 01:44 AM |
JT Sprocket 42 tooth Rear Sprocket | lolibater | Motorcycle-related | 36 | February 25th, 2013 12:30 PM |
JT Front Sprocket Question | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 27th, 2012 04:45 AM |
Sprocket question from a newbie | cryllyn | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 16th, 2012 10:25 PM |
Stupid Sprocket Question | demp | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 7th, 2010 01:32 PM |
